Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-23-2011, 11:40 AM | #29 | |
- Andrew |
12-23-2011, 11:56 AM | #30 |
Rocket Surgeon
Drives: PSM GGA OMG
As near as my forensic math skills can tell, you didn't square the front motion ratio, you applied the rear motion ratio inversely and didn't account for the fact that the spring rates are per corner, not per axle. But I could be wrong.
12-23-2011, 01:14 PM | #31 | |
Kuruma Otaku
I'm not using one that deals with motion ratios. It separates the fitted rate and leverage, so it's not 100% accurate as the suspension goes through its travel (fitted rate changing, although there is an appendix on how to calculate/graph this as well). And in that case it doesn't matter on the fronts as the MacStrut's leverage of 1 is still 1 when it's squared. The rear suspension leverage confuses me, and from what I'm hearing here I wonder if it is a mis-print. They are given as AB/CB with A being the hub-side pivot, B being the chassis-side pivot and C being the spring mounting point. So MacStrut=1 and Wishbone-type link >1. I'm using the calculations from Allan Staniforth's Race and Rally Car Sourcebook. (don't have it with me at the moment so I'm not 100% sure if I did the AB/CB thing right...) Strong possibility that I goofed, though...
Because titanium. |
12-23-2011, 03:04 PM | #32 |
Drives: too many to name
I think we need to take a double take on the front suspension again. My not-recently-calibrated eyeball doesn't think the motion ratio looks like 1. The control arm mounting locations have been pushed outboard, the strut top is inboard compared and the strut is nearly vertical when compared to all the other strut suspensions I have looked at.
That would make the wheel motion to spring motion ratio closer to 1.5 than 1. Changes the calcs pretty dramatically. |
12-23-2011, 03:10 PM | #33 |
Dang...sure are a lot of GT5 threads.
12-23-2011, 03:17 PM | #34 | |
Kuruma Otaku
Going through the spreadsheet I made, I'm guessing that you guys and Mr Staniforth will tell me that I need to divide the fitted rate by the leverage^2... Revision with curb weight halved and appropriate leverage: Front: 2.04Hz Rear: 0.73Hz (way less accurate than front guess because of leverage variable) Could be Polyphony Digital just used a modified Mk3 Supra physics model with less weight and different power (wheelbase and f/r distribution are similar, double wishbones f/r but the rear shock mounting is very far outboard) as they didn't have any solid info on the FT86C at the time. And then they just re-did the body model and adjusted the weight and power again for the GT86/FR-S? Or they got it backwards? 2/6 gives front 1.20Hz, rear 1.265Hz. I started to lose faith in GT5 when I learned about how 'easy' it is to adjust camber on a solid axle rear suspension such as the AE86. (It involves an oxy-acetylene torch.) This isn't helping. But Forza let me change the driveshafts of FWD cars so
Because titanium. |
12-23-2011, 03:35 PM | #35 | |
That's exactly how it drives in GT5 |
03-27-2012, 01:05 PM | #36 |
Drives: 1994 BMW 318i
The spring rates on the game might be a little extreme (or maybe not?), but the spring rates are normally higher in the front because the engine is in the front and there is slightly more weight in the front AND the car can brake harder than it can accelerate.
This crowd sounds like they know what they are talking about though (seems like a lot of MEs here). |
03-27-2012, 02:30 PM | #37 |
^ Again, there's more to it than just weight distribution. Gotta look at the motion ratios too.
The spring rates in GT5 are incorrect anyway. - drew |
Similar Threads | ||||
Red Toyota 86 with factory aero kit and spoiler wing | DIG1992 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 112 | 02-04-2014 12:16 AM |
Factory Roof Rack? | \o/ | Scion FR-S / Toyota 86 GT86 General Forum | 92 | 02-15-2013 03:25 AM |
Just got off the phone with Scion... FR-S release date late spring 2012 | nate89 | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 12-03-2011 03:00 AM |
Official: Subaru BRZ Will Be Released in Spring 2012 | EyeZer0 | BRZ First-Gen (2012+) -- General Topics | 22 | 11-09-2011 01:14 AM |
FR-S to be priced at $22k and coming in Spring of 2012? | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 92 | 10-25-2011 09:06 PM |
