Old 09-11-2014, 09:33 PM   #183
enjetek
Drives: 93.5 supra t & prius
enjetek is offline   Reply With Quote
Old 09-11-2014, 10:39 PM   #184
PhoKingCool
PhoKingCool's Avatar
I am seriously laughing right now. This thread is such a waste of time to skim though but I must return just to see what absurd and irrelevant remarks are left.
PhoKingCool is offline   Reply With Quote
Old 09-11-2014, 11:48 PM   #185
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
@Jaden
Your PM is fascinating man. For privacy purposes...I will not tell people what you told me..but I will say if he can get his idea to work...it will be awesome.
But one thing about this argument...
You do not represent the average backyard mechanic.
Your argument brings me back to the surgeon analogy...
I don't tell people they are stupid because they didn't do their own cardiac cath.
Very few people on this planet can do what I do...
That said...the last time I changed my own oil...I had to buy a new oil pan (forgot crush washer...doh)
I think you are totally qualified to build up a car yourself.
The thing is...you are a pro.
Let an average backyard mechanic year old try to do this them self...and they end up with a car that will indeed blow up and probably come apart and kill someone.
To say someone is "foolish to pay someone to do something that they can do them self" is a little misleading.
Most of us here who can either do a build them self (like a mechanic) or can PAY someone to do a build for them (someone who can afford to drop 70k into a toy car) are all professionals in SOMETHING.
Rather than try to crack my engine open and fiddle around in there and break something...I rather pull a little extra call...make a few grand over a weekend and do what I know how to do...and then use that money to pay someone who knows what they are doing.
Atropine is offline   Reply With Quote
Old 09-12-2014, 12:12 AM   #186
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by Atropine View Post
@Jaden
Did he tell you his idea for a perpetual motion machine?
DylanFRS is offline   Reply With Quote
Old 09-12-2014, 01:16 AM   #187
Atropine
LOL no.
Not wanting to "give it away", but it essentially boils down to an extremely efficient turbo system that would reduce friction and lost energy.
Now as far as his claim on not stressing internals...I don't see it being able to do that.
But more efficient engines/turbo systems are doable.
But I also think it goes into the classic car guy saying...
Speed, inexpensive, reliable... Pick two.
Also my point is...of course someone who can fabricate parts them self or they work at a junkyard and can get parts for super cheap...yeah they can do things for cheaper than a guy who does not have those alternatives.
While in military...I got to fire all kinds of big weapons for "free". That doesn't mean that if I want to unload with an M-60 or a SAW (think belt-fed M-16) for an hour...it will cost me a lot in rental fees and in ammo.
The whole, "build a twin to be a Z06 beater" falls into that same thing.
Sure, if you dad is the guy who runs Cobb tuning...I bet you can get a "deal".
Just like how CJSporl can keep dumping money into his BRZ...some people just have more options for various reasons.
The Following User Says Thank You to Atropine For This Useful Post:
BadBRZ (09-12-2014)
Old 09-12-2014, 07:18 AM   #188
Twin4Life
Twin4Life's Avatar
Drives: '14 Genesis Coupe 3.8 Grand Touring
I re-tooled at home, my Huffy has become a Ducati killer.
Twin4Life is offline   Reply With Quote
Old 09-12-2014, 12:06 PM   #189
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
LOL no.
Sure, axial compressors are cool (and very efficient at large scale, though they generally don't scale down well due to tip clearance issues and the large stage count required to get a good compression ratio), but that still doesn't avoid the isentropic heating, it'll still require an intercooler, and the air coming out the back will still be very hot.
In addition, modern turbos run at or near their peak efficiency point already run at >75% efficiency. Sure, a really good axial compressor can maybe do better (although I'm not convinced of that - see the next paragraph for details), but you're trading off a lot of complexity and cost to achieve that. An axial flow compressor can only achieve a pressure ratio of 1.2-1.3 or so per stage, you'll need a 3-5 stage axial compressor to get 15-20psi of boost. Efficiency is highly dependent on tip clearance too, which will require some pretty high end materials and machining (since you want to maintain as close to zero tip clearance as possible while spinning at very high speeds and across a wide range of temperatures).
In addition, although in large applications (jet engines, power plants), axial compressors are without question more efficient than centrifugal, I'm not convinced that's the case for small ones. Issues with achieving the right spin speed and tip clearance on a small compressor can wipe out almost all of your efficiency gains, and you also have a much longer driveshaft to balance and support at extreme RPM (and if it starts flexing, you can crash your blades into the housing, since you want as little blade clearance as possible for efficiency). The physical size of an axial compressor is also a lot larger than a centrifugal for the same flow and pressure ratio. These factors are enough of a problem even on larger engines that many smaller turbine engines (especially helicopter and turboprop engines) actually still use centrifugal compressors. The Pratt and Whitney PT6 is a good example of this.
That having been said, if you do get around to making this design work, I'd be curious to see pictures/details. Even though I doubt the gain is worth the amount of effort it will take, it still sounds like a fun engineering project.
chrisl is offline   Reply With Quote
Old 09-12-2014, 12:56 PM   #190
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
The axial compressor, was NOT what I was referring to..
The axial compressor supercharger is NOT what I was referring to.
It's an entirely different project.
Jaden
Jaden is offline   Reply With Quote
Old 09-12-2014, 01:06 PM   #191
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Is it a comprex? lol
murdoc is offline   Reply With Quote
Old 09-12-2014, 01:35 PM   #192
Jaden
Road-hole
I made a huffy a Ducati Killer...
I easily made a Huffy a ducati killer, by strapping a parachute on my back...
Jaden
Old 09-12-2014, 10:04 PM   #193
inertia
inertia's Avatar
For all you Z06 lovers and engine-swap-haters out there... look up some of these fabulous builds:
@JoeDrifter @jet86 @Drift&Drag @WTF @slicktop @puma @OmarGC @SmsAlSuwaidi @FullBlown
inertia is offline   Reply With Quote
The Following 3 Users Say Thank You to inertia For This Useful Post:
jet86 (09-12-2014), OmarGC (09-13-2014), slicktop (09-14-2014)
Old 09-13-2014, 12:58 AM   #194
fatoni
its not that those builds arent great. its just that they arent going to go as fast as the vette for as long as the vette while being as cheap as the vette
Old 09-13-2014, 01:53 AM   #195
abraxis
Drives: many
Fwiw, the article I recall had an Evo with about $12k in mods beat a stock GTR round the track.
Twins are obviously superior to any low mileage C7's with blown engines, faulty brakes and airbags. Go GM! /thread
abraxis is offline   Reply With Quote
Old 09-13-2014, 02:58 AM   #196
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Here's my c7 z51 (not z06 but who cares), and my frs.
Size:  311.6 KBName:  ImageUploadedByTapatalk1410589761.441116.jpg
Both are amazing cars. The only point I'm going to make about these cars is this: The frs is liked more by guys, and the corvette is liked more by the ladies. No matter what modifications you do to your frs, it's probably not gonna pull much ***** compared to the corvette (unless you like high school girls). Let's not forget about resale value and all that junk. The frs, no matter how much money you put into it, will never be even a base model c7 stingray. They feel totally different in good ways. Anyway, enjoy the hurt feelings.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
DeeezNuuuts83 (09-13-2014)
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
2015 86/BRZ vs 2015 Eclipse botbs FR-S / BRZ vs.... 55 04-16-2014 04:07 AM
Is it just me or Twins are everywhere now? DrawingWaves Scion FR-S / Toyota 86 GT86 General Forum 93 03-20-2014 09:31 PM
The twins pnig BRZ Photos, Videos, Wallpapers, Gallery Forum 2 02-06-2014 06:52 PM
The Twins!! iaclimber4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 10-03-2013 02:20 AM
