Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-16-2018, 06:21 PM | #57 | ||||
Drives: 2015 Scion FR-S
Nope, I'm an old guy, I've just always driven plain automatics until now. Thanks for your answer - it was already mentioned in this thread and it makes perfect sense. Not sure that it would take an AT a whole 1 or 2 seconds to downshift, but I get the point. |
09-16-2018, 10:03 PM | #58 | |
You're parked here, and pulling out with a right turn, so you need to turn the wheel a lot. Auto mode is certainly an option, but say you wanted to use manual mode for whatever reason. How exactly would you make the turn? I would use hand over hand steering and shift to 2nd partway through the turn, around 10 mph. And I would just use the stick since it's right there, instead of looking for the paddles. If it was paddles or nothing, I suppose I would keep it in 1st gear until the steering wheel had straightened out, with either higher revs or a lower speed than I would normally use. |
The Following User Says Thank You to Johnny Horsepower For This Useful Post: | Ultramaroon (09-16-2018) |
09-16-2018, 11:21 PM | #59 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | finch1750 (09-17-2018), FRSBRZGT86FAN (09-17-2018) |
09-17-2018, 08:22 AM | #60 | |
Out of curiosity, did Toyota/Subaru get it right on the stick shifter and make forward shift down? I've seen a bunch of manufacturers get it wrong and make forward shift up. |
09-17-2018, 11:09 AM | #61 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
No. It's backwards. But nothing 15 minutes swapping pins doesn't fix.
09-17-2018, 11:12 AM | #62 | |
The Following User Says Thank You to finch1750 For This Useful Post: | FRSBRZGT86FAN (09-19-2018) |
09-17-2018, 12:03 PM | #63 | |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
The Following User Says Thank You to Sasquachulator For This Useful Post: | FRSBRZGT86FAN (09-19-2018) |
09-17-2018, 12:05 PM | #64 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
In that case, leave it in auto. You know how that works already and it's familiar.
Using manual in every case, because racecar, is an added distraction. Keep your head on a swivel looking for other parkers pulling out without looking themselves.
"I gotta rock." -- Charley Brown |
09-20-2018, 03:55 AM | #65 | |
Drives: 2013 ARGENTO A/T
But I really like the constructive feedback in this thread. I've been meaning to post on how to be a better AT driver and find that perfect shifting balance. I drive sporty in M all the time but I feel like I've sunken into some sloppy shifting habits in the turns. I think because of the torque dip I keep the revs high, especially in exits. Maybe I'm not modulating the throttle enough but with lighter wheels and sticky tires things can get pretty snappy. I find that Im never above 3rd gear when I'm exiting through the apex and the car is at full weight momentum. That's where things get snappy on the throttle but I feel like if I push through in 4th than I lose the acceleration I need as soon as the car begins to straighten out. I'd like to hear your guys thoughts on gear shifting through the turns and the balance between momentum and RPMs. |
The Following User Says Thank You to Spacemane969 For This Useful Post: | Tcoat (09-20-2018) |
09-20-2018, 11:09 AM | #66 |
Geo Tyrebighter Esq
I've always been advised to select a gear before the turn.
Shifting in the middle will upset any balance you had going through.
The Following 3 Users Say Thank You to bcj For This Useful Post: |
09-20-2018, 01:26 PM | #67 | |
The Following User Says Thank You to ermax For This Useful Post: | Spacemane969 (09-20-2018) |
09-20-2018, 06:27 PM | #68 | |
Drives: 2017 86GT
09-20-2018, 10:14 PM | #69 |
Are we STILL discussing how to shift a car with an automatic transmission - ??
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | bkharmony (09-21-2018) |
09-20-2018, 11:23 PM | #70 |
I still cant get the paddles to work when I'm in reverse. Any suggestions? Do I need to pull harder? Or is there something else I'm doing wrong
The Following 2 Users Say Thank You to finch1750 For This Useful Post: | bkharmony (09-21-2018), FRSBRZGT86FAN (09-21-2018) |
Similar Threads | ||||
Is it possible to add shift paddles to the GT? | SunnyDay | Engine, Exhaust, Transmission | 34 | 08-28-2015 05:11 AM |
Learning to drift | FRS-Jonathan | Tracking / Autocross / HPDE / Drifting | 4 | 05-16-2013 04:50 PM |
CF Shift Paddles? | FRS_Ken | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 01-23-2013 11:05 PM |
I know the automatic has paddles, but..... | Jedi1 | Engine, Exhaust, Transmission | 34 | 10-02-2012 01:50 PM |
