08-18-2018, 08:31 PM | #15 |
Drives: Moped
Do it!!!!
08-18-2018, 08:32 PM | #16 | |
Drives: Moped
08-18-2018, 09:28 PM | #17 |
09-09-2018, 03:07 PM | #18 |
Sorry for the lack of progress. Still waiting on parts. I got in some fittings and picked up a cooler for the transmission which I will detail more when I install it. I'll just have 2 pics here... AC compressor adapter and -AN adapters for the transmission cooler
The Following User Says Thank You to Ashikabi For This Useful Post: | Sportsguy83 (09-10-2018) |
09-09-2018, 06:34 PM | #19 |
Is that the factory corvette ac compressor? What year? 01? 02?
09-22-2018, 01:17 PM | #20 |
09-22-2018, 01:24 PM | #21 |
Making some progress today although still not what I wanted. Most of my parts will be here Monday, like my mounts, then things can get crazy.
Fuel hardlines are as follows from top to bottom (or firewall towards the radiator) port inject, evap, direct inject. More posts to come today and many in the following week Last edited by Ashikabi; 10-15-2018 at 09:55 PM. |
09-22-2018, 01:30 PM | #22 |
Heater outlet compression fittings, one is stepped down as the heater inlet is the same on both sides.
I had to trim length on all the heater compression fittings. Water pump->heater is the larger, front port. Heater->water pump is the smaller rear port. I believe the heater core inlet is closest to the battery if I remember my hoses correctly. Last edited by Ashikabi; 10-15-2018 at 10:00 PM. |
09-29-2018, 11:29 AM | #23 |
Engine bay prepped for paint. No more brown primer. Going with Electric Blue II Effect used by Mini. Transmission tunnel is ready for paint. Had to "modify" both sides, cutting part or the bracing out and hammering on the lower half towards the front. Remember I'm using the TR6060 from a 2010 Camaro SS. Shifter looks like it will line up fine. I'm adding steel plates to the interior to brace the mounts for the new transmission. You could weld them in on either side of you wanted but I don't have a welder avoidable nor am I willing to gut my interior to do it. I'll bolt them in. I'll post pics of this later when I get them in.
UPDATE: when you modify the tunnel, cut out ALL the stock bracing Last edited by Ashikabi; 08-05-2019 at 09:23 PM. |
09-29-2018, 11:36 AM | #24 |
Broke the MAP sensor off this little offshoot unit fitting the motor. Turns out my new ECU, the Hydra Engine Management System has an internal MAP so I'm deleting this elbow looking thing. This elbow, which mounts the MAP also feeds the brake booster and another vacuum line, is right up against the stock heater hardlines. I didn't get a pic of this but it's gotta go. The LS6 has this same unit but the LS2+ does not. I'm going to drill and tap vacuum ports somewhere less troublesome.
09-29-2018, 12:12 PM | #25 |
Edited for fuckup. Please ignore
The Following User Says Thank You to Ashikabi For This Useful Post: | DustinS (10-01-2018) |
09-29-2018, 04:34 PM | #26 |
Installed the new ECU. Just unplug the old and plug in the new. Still have to run a vacuum line for the MAP though. Lost my glove box too. This thing is much larger than the stock ECU. Might be able to stash it if I tore out the dash board, but I'm not willing to do that
The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | DustinS (10-01-2018), Sportsguy83 (09-30-2018) |
10-01-2018, 12:42 PM | #27 |
Got the new drive by cable gas pedal figured out. Mounting it anyways...
This plate attaches to the stock pedal mount, new pedal attaches to the plate. I thought I had a picture of that but apparently not, so here's a picture of my cat instead |
The Following User Says Thank You to Ashikabi For This Useful Post: | Merc (10-01-2018) |
10-01-2018, 11:16 PM | #28 |
Drives: Subaru brz 2013 LS1 swap
Very nice, i am about to do the same on the gas pedal. What cable/length cable did you use. Any other pics of how you are attaching to the regular pedal setup?
