02-11-2019, 07:34 PM | #4005 | |
Drives: FRS
Bought 4 used pirelli p7 and my 20mm hub centric spacers to convert to the 5x112 pattern. Once they're all mounted up I'll post up pics. No suspension mods as of yet just camber bolts Sent from my iPhone using Tapatalk |
The Following User Says Thank You to vladniko86 For This Useful Post: | Leonardo (02-11-2019) |
02-14-2019, 12:20 PM | #4006 | |
Drives: 2013 FRS
Based on the wheels directory for a 9" wide rim to achieve perfect flush I'd need a wheel with +48 offset on the front and +38 on the rear (dropped 1"). Now... My wheels are +42, that means that with a 5mm spacer in the front I'll get to +47 and be close enough ok being flush? But then the rear needed +38 and I have +42?Something is not adding up cause you used 10mm+ spacers to achieve flushness |
The Following User Says Thank You to Rhyuk For This Useful Post: | Leonardo (02-14-2019) |
02-14-2019, 12:40 PM | #4007 | |
Country Boy 4 Life
That's not how offset works. Also, the wheel directory does not take into account that most people want a bit of negative camber. A 9" wheel that is +48 offset requires coilovers to fit. A 9" +45 wheel is what I would consider the inner limit. Meaning it will hit the spring perch. A 9" +42 wheel generally clears the spring perch. (depending on car and tire) A spacer adds distance between the spring perch and the wheel/tire. Negative camber decreases the distance between the wheel/tire and spring perch. I have 18x9 +42 wheels. I have added 12mm front and 15mm rear spacers. This makes my offsets +30 front and +27 rear. For positive offsets; you subtract the spacer. A +42 wheel with a 5mm spacer makes it essentially a +37 wheel. A 1" drop will net you -1.5 to -2 rear natural camber. My natural camber from 1" drop springs was -1.8 left and -2.2 right. This didn't cause any uneven tire wear; I drove it 65,000 miles this way. LCA will fix this issue if you want. You will need some front camber to at least match the rear. Camber bolts are around $20 and easy to install. They are good for about -1.5. This is good for DD. A 1" drop, 18x9 +42 wheels with a 10mm spacer, and a set of camber bolts will look good. You may not need spacers at all, depending on what you consider flush and how wide of a tire you choose. The wheel directory is a great resource; I look through it all the time. via Imgflip Meme Generator
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | Vital (02-15-2019) |
02-14-2019, 01:28 PM | #4008 |
Drives: 2013 FRS
Leonardo, I wish you were in FL so I can pay you a few beers. What's LCA? For 10mm spacers I'll need longer studs right?
I'll get those camber bolts. Tire I'll use will be 245/30/18 Thanks a million man!!! Last edited by Rhyuk; 02-14-2019 at 01:29 PM. Reason: Missing info |
02-14-2019, 01:50 PM | #4009 |
Drives: 2015 BRZ
LCA = Lower Control Arm. It will help you fix your rear camber as there is no camber adjustment on these cars. And yes with 10mm spacer you most likely will need to run extended studs.
The Following User Says Thank You to Vital For This Useful Post: | Leonardo (02-14-2019) |
02-14-2019, 01:57 PM | #4010 | |
Country Boy 4 Life
Thanks man! I would take you up on that if I was closer! But, Florida is a bit of a drive from Oregon... LOL LCA = Lower Control Arms. Good lower price LCA - not 100% necessary, but really nice to dial everything in. https://www.ebay.com/itm/SPC-Adjusta...MWZo:rk:1:pf:0 Yes, extended studs are needed. I suggest these. https://www.rallysportdirect.com/par...l-studs-5-pack Cam bolts https://www.ebay.com/itm/81305-SPC-P...S!-1:rk:1:pf:0 These spacers are a great deal! https://www.ebay.com/itm/4pcs-12mm-5...!-1:rk:15:pf:0 I have 245/35/18's. They are stock diameter and fit nicely on a 18x9. This is the size I would suggest. Thanks again for the kind words!
I LIKE TIRES! |
02-14-2019, 04:33 PM | #4011 | |
Drives: FRS
Hey Leonardo, my hubcentric conversion spacers came today and my wheels look good on em. However, how can I verify they are hub centric? There is a lip that goes on the hub, but it still moves around a bit. I'm guessing when I throw on the lug nuts it came with it will center it and prevent movement? Sent from my iPhone using Tapatalk |
The Following User Says Thank You to vladniko86 For This Useful Post: | Leonardo (02-14-2019) |
02-14-2019, 04:46 PM | #4012 | |
Country Boy 4 Life
Cool post some pics of what your wheels look like on your ride! What spacer/adaptors did you get? Did you order spacers with a 56.1 hub bore? If they are 56.1, they should slide on the hub with almost no side to side movement at all. If you bought a different size, like with a hub bore of 57.1, they would possibly need hubcentric rings like these... https://www.amazon.com/Hubcentric-Ri.../dp/B01N2M92QP Or figure out the ID of the wheel adaptor and get ones that fit them. I can help if you can't figure it out.
I LIKE TIRES! |
02-14-2019, 04:48 PM | #4013 | |
Drives: FRS
I got 56.1mm. It's very minimal play and the lug nuts it came with are like a cone on the side that touches the spacer so I assume once all 5 are on it will center and be good. My sparcos are tireless, FedEx delayed shipping should come tomorrow, pics then till then I gotta replace 10 studs on the rear haha Sent from my iPhone using Tapatalk |
02-14-2019, 04:55 PM | #4014 | |
Country Boy 4 Life
Cool, 56.1 is the correct size. I think you should be good. THe studs on the rear are a bit harder because you have to remove the hub. If you don't have a 32mm axle nut socket, you will need one. (I had to run to autozone in the middle of my project) Hopefully the install on the rear goes smoothly and you get your tires soon. I look forward to seeing some pics!
I LIKE TIRES! |
02-14-2019, 04:56 PM | #4015 | |
Drives: FRS
How are you doing it? I got all of em off without taking the hub off and have got them back on numerous times. They keep stripping and breaking so I'm doing all 10 Sent from my iPhone using Tapatalk |
02-14-2019, 06:15 PM | #4016 |
Country Boy 4 Life
Ok, my bad I was thinking of 50mm extended in the rear. If your extended studs are OEM length (or only 5mm longer) you can install them without removing the rear hub.
I LIKE TIRES! |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
