Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-03-2016, 12:31 PM | #1 |
Drives: 2013 scion frs
Ark Design Exhaust Review
Came across the company via the forum here. After about a week of emailing back and forth (which all emails were responded to very quickly) i finally pulled the trigger.
It showed up in about a week. Packaging Exhaust came in a nice large box, with the ark design logo right on the front. Box was stapled and then wrapped in the plastic tie downs. Inside tons of foam and bubble wrap, and everything was taped. The tip even was covered with a cardboard cylinder and more bubble wrap. Even came with some hardware and a sticker !!!! WOOO !! +5hp here we come !! Welds/Workmanship So i am by no means a welder. All welds look great though and very well done. No problem areas that i can see anywhere. The exhaust has the logo engraved on the tip, and has a tacked on serial number plate on the back side. Fitment Coming Soon ! Sound Coming soon ! Overall so far i am very impressed. I have a very sneaky suspicion that this exhaust is made in the same factory that tomei and gruppe s is. Also made in Taiwan. Welds even look the same ! Should have this mounted up by weeks end. Will be pairing it to a gruppe s uel, tanabe overpipe and stock front pipe. Will also be testing if it fits with the Velox rear diffuser, and their new exhaust cutout cover they just released. Should be fun times !!
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you. – Jeremy Clarkson
08-03-2016, 12:32 PM | #2 |
more pics
The Following User Says Thank You to GT86Dan For This Useful Post: | Clipdat (08-03-2016) |
08-03-2016, 03:52 PM | #4 |
subscribed for sound. I'm debating the sound/drove issue. Just needs to be tolerable at highway speeds.
08-03-2016, 05:56 PM | #5 | |
Proud of BOXER
Drives: Subaru Boxer
Found this video [ame="https://www.youtube.com/watch?v=B7dRp4O2Sc0"]ARK Design Racing Spec Exhaust for Scion FR-S / Toyota FT-86 / Subaru BRZ (Single Outlet) - YouTube[/ame]
Nice that the piping is 2.5" versus the 3" on the Greddy and HKS single exit models, should help the sound be a little more reasonable for DD.
The Following User Says Thank You to Clipdat For This Useful Post: | GT86Dan (08-03-2016) |
08-04-2016, 05:05 PM | #6 |
Drives: 2013 SCION FRS
08-05-2016, 12:09 PM | #7 |
Update !!
Just installed the exhaust yesterday. Install went without any major issue.
Fitment Exhaust fit like a glove. No issues whatsoever. Piping is nice and tucked against the body and sits flush. The only issue that we had is with the Velox rear diffuser. The piping route swoops hard to the passenger side and the diffuser exhaust opening just was not big enough. Easy fix though as we just cut to accommodate the new route. Bolted everything back up and solid as when i first received it. Sound Coming from a cracked Dezod catback this one sounds very tame under 3k rpm It truly is a quality exhaust, having more of a guttural tone if that makes sense. Drone is nearly non existent. Driving around normally and cruising you almost forget its there. Until you put your foot down and the 4 horsemen of the apocalypse come charging out. Nice and loud but not annoying in any way. Very clean sounding, with the occasional downshift pop and gurgle It also passed the girlfriend test Final thoughts Overall i am extremely happy with the exhaust. I think Ark Design made a fantastic product and everyone should look into them. The exhaust is still brandy new so looking to add a long term review to this thread. Hopefully ill have no surprises like the last pile of tubing i had. I have a track day coming this next week and will have more footage as the week goes on [ame="https://www.youtube.com/watch?v=RaRtXJ707F4"]https://www.youtube.com/watch?v=RaRtXJ707F4[/ame]
The Following 2 Users Say Thank You to GT86Dan For This Useful Post: | ModinJapan (08-05-2016), Teseo (08-05-2016) |
08-05-2016, 12:33 PM | #8 |
great write up.
May i suggest adding washers on your diffuser to add clearance |
08-09-2016, 06:33 PM | #9 |
any other sound clips yet?
08-11-2016, 05:11 PM | #10 |
Drives: 15 BRZ LTD, 05 FXT
In other news, @GT86Dan s girlfriend is deaf!! Just kidding, but I'm not familiar with any other N1 style exhausts that pass the GF test.
Could we have a few soundclips of it revving out? Cold start is often loud, and idle is often quiet, so I'm hoping for some cruising and higher rpm's.
The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Cole (08-11-2016) |
08-11-2016, 05:36 PM | #11 |
Drives: 2013 FR-S, 2016 Miata Club
Still on my quest for a single exit exhaust option. My main concern is drone at highways speeds around the 60~70mph range. I'm not overly concerned about acceleration, just cruising. Any comments on this? Thanks for posting up.
08-11-2016, 06:45 PM | #12 | |
but if you have UL HEADERS, overpipe and non res front pipe, its always going to be louder |
The Following User Says Thank You to ModinJapan For This Useful Post: | JimmyMac (08-11-2016) |
08-11-2016, 11:23 PM | #13 |
Heres a fly by from my track day yesterday. Going to get a full exhaust vid soon. Cold starts, idle , interior , acceleration. Just give me the weekend. After having it on a week now, at highway speeds there is no drone even with uel.
[ame="http://https://www.youtube.com/watch?v=t8TmMyzrC-c&feature=share"]http://https://www.youtube.com/watch?v=t8TmMyzrC-c&feature=share[/ame]
The Following 3 Users Say Thank You to GT86Dan For This Useful Post: |
08-12-2016, 12:06 AM | #14 |
wow that sounds amazing. and at WOT, its was not obnoxious
Similar Threads | ||||
JDL Auto Design - 2014 Exhaust Products | JDLAutoDesign | Engine, Exhaust, Transmission | 1648 | 03-28-2018 09:53 AM |
Review: Pro Street Coilovers from Speed By Design | ericmpena | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 67 | 03-08-2015 12:00 AM |
Exhaust muffler design/placement vs mpg | vtmike | Engine, Exhaust, Transmission | 7 | 02-10-2013 01:01 PM |
Perrin Pulley review? Invidia Q300 exhaust review? | ScionFrsFan | Engine, Exhaust, Transmission | 4 | 12-10-2012 08:27 PM |
FRS Design Review | russv | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 09-27-2012 07:02 PM |
