Engine Swaps Discussion of engine swaps. |
11-15-2017, 10:39 PM | #1 |
Drives: 2013 FRS Whiteout
2JZ Budget Swap 2.0, Another One
We have acquired a 13 BRZ auto trans shell. What should we do with it? Are you silly, we're still gonna swap it!
Step 1 Acquire Car: Check Step 2 Find an engine. Well, we got lucky on this one, stumbled across a JDM VVti dropout from another shop's customer that went a different route with their Lexus build. Quite the score for $1000 Step 3 Pick a transmission. We've decided the best route to go for a manual in the swap cars is the CD009. Mainly based on price. Here's why> Called around town, found a used, semi high mileage trans from a 2006 for.... $475! Next, you need a CD009 to 2JZ adapter kit, we got an adapter kit for right around $1,000. We'll also need a clutch, shifter, and driveshaft, but we will address this later on. Update, She here! IMG_3117 by Brady Johnson, on Flickr Step 4 Get Some Mounts. Which mounts? How about the brand new prototype Pure Automotive Mount Kit? Sounds good! Stay tuned for more on this... hint hint check out our swapyour86.com facebook page for Black Friday deals...cough cough Step 5 Ready For Insertion (Andy **** from Old School voice) IMG_3098 by Brady Johnson, on Flickr Currently waiting on the trans and parts to arrive, should be any day now! Our game plan with this car is to install every piece of the the swap that we sell, outline these parts and the install, and show you that they do fit and we support them 100% because we have personally installed them all piece by piece. But what if I told you.......... We might sell this car as a complete running car when we are done..... Would anyone be interested? You would get to follow the build all the way through and see every part of it go together and then take it home when we're done. Thoughts? How Low Can We Go???? More Updates Soon! Last edited by Pure Automotive; 11-17-2017 at 04:10 PM. |
The Following 6 Users Say Thank You to Pure Automotive For This Useful Post: | CxG (03-16-2018), D_Thissen (11-17-2017), Irace86.2.0 (11-15-2017), R2RO (11-18-2017), Sportsguy83 (11-16-2017), Teseo (11-16-2017) |
11-15-2017, 10:53 PM | #2 |
Drives: 2017 WR BLUE BRZ
Another monster in the making!
11-16-2017, 11:49 AM | #3 |
Drives: 15 BRZ LTD, 05 FXT
This is so cool. You guys do a great job bringing the price down without compromising quality it seems. Even the Supra guys seem to like running these transmissions.
11-16-2017, 01:07 PM | #4 |
Drives: frs
Will be interesting if you guys can keep the project on a budget, whatever you put on the swap put the price of X part also help a lot. And finally, maybe we can see a complete kit?
11-16-2017, 04:37 PM | #5 |
11-16-2017, 05:03 PM | #6 |
I have almost finalized our "Complete Kit". It's pretty all inclusive and pricey as a result, but is is 90% of the hard parts needed to drop in and go. I can say it's going to be about $12-13k for the truly complete kit. Interested in being one of the first?
The Following User Says Thank You to Pure Automotive For This Useful Post: | Teseo (11-16-2017) |
11-16-2017, 05:09 PM | #7 | |
Drives: 2015 Brz
If you build a car for attention, to me, you aren't a car enthusiast. You're an attention whore.
11-16-2017, 05:15 PM | #8 | |
Drives: frs
11-16-2017, 05:29 PM | #9 |
LOL
11-17-2017, 12:30 AM | #10 | |
Drives: 2015 frs
If it would work with the LT4, completely eliminated FR-S can bus, included a AiM display, and a power distribution module to eliminate all the fuses, relays. Keep ac, power windows, power steering. Lol Good build, and I like the kit you developed. Definitely appeals to the masses more than what im needing. I enjoy reading your swap threads. Keep it up! |
11-17-2017, 01:29 AM | #11 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
How is the engine tuned? Will the swap retain all factory functionality? Seamless swaps interest me. Just wondering what sacrificies are made for something like this.
11-17-2017, 08:29 AM | #12 |
MoTeC Stand Alone, Everything factory works, read our other threads about other swaps we have done, it explains the functionality.
11-17-2017, 09:38 AM | #13 |
Drives: 2JZ BRZ
if you really want, you can reduce the price dramatically by going with ecu master, haltech or others with obd2 capability, display the info on a tablet for a gauge cluster and then you're able to remove abs module, since you'll have speed through the ecu and coolant temp, boost, afr, tach,... you can even wire up the sending unit as an input for fuel level.
This will be the direction I'll be leaning towards |
11-17-2017, 09:54 AM | #14 | |
Drives: 2013 Ultramarine FR-S
The Following 4 Users Say Thank You to DustinS For This Useful Post: |
Similar Threads | ||||
Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 08:53 AM |
Get Your Subscriptions In, We're Doing a Budget 2JZ Swap!! | Pure Automotive | Engine Swaps | 258 | 09-27-2017 02:41 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
$2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 11:23 AM |
There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 08:14 AM |
