Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-13-2019, 07:12 PM | #15 |
06-13-2019, 10:01 PM | #16 |
Drives: Many
Well if he was troubleshooting the wiring it should be obvious...
It's on the transmission. The switch itself has a pigtail that runs up the engine bay, where it plugs in. The grey plug is for the reverse light -- just follow it back to where it threads into transmission. |
The Following 3 Users Say Thank You to e1_griego For This Useful Post: |
06-13-2019, 10:15 PM | #17 | |
ProCrastinationConsultant
also, you said that you bought it used. did you verify that the plug in the trunk is connected? it's possible the last owner had a different reverse light on it, and changed the visuals, without doing all the hard work of re-running the harness.
The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (06-13-2019) |
06-13-2019, 11:15 PM | #18 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
So how exactly did you check all the wiring?
Did you use a multi-meter? (probably not or you would know the exact problem...) Did you pull up the carpet and visually inspect? (probably not, it is a hassle) Did you know that lots of folks tap into the backup light wire for an add on backup camera? Since you are not the original owner you really cannot know what has been done over the years... Like already said: get a multi-meter and trace it down...
06-13-2019, 11:30 PM | #19 |
and also like already said, if you are either not so mechanically inclined, or have time constraints, many locations will be willing to do the work for you for monetary compensation.
06-14-2019, 12:01 AM | #20 |
Drives: 2015 FR-S
The Following 3 Users Say Thank You to Impureclient For This Useful Post: |
06-14-2019, 12:37 PM | #21 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
It's basically all been said already, but here's another version.
Perform visual inspection. Verify connectors fully seated and not corroded. Throw new bulbs in. They may look ok but still be bad. Check fuse. Swap with spare fuse of same amperage rating to know for sure it's good. Fuses don't always open completely. A handful of times I've found a fuse partially open, it looked ok but was only allowing 3-4 volts through. With key on, engine off test for voltage with a test light at the vehicle harness side of reverse switch connector. If you have battery voltage the problem is down stream of that point. Using a paper clip you can bridge the two terminals of the reverse switch. Don't let the paper clip touch any metal parts. If you have reverse lights doing this test, it's the switch. If not it's downstream of the switch. Using jumper leads and a DVOM test for resistance from power side of reverse lamp connector and power out side of switch connector (vehicle harness side). If it's less than half an ohm that wiring is good. Test for ground at ground side of reverse lamp socket connector. If it's less than half an ohm, suspect failed reverse lamp. That's all I got. Hope it makes sense. Don't do anything you're not comfortable with. There's nohying wrong with paying someone to fix your car. Better that than mess it up worse.
Work Hard. Play Hard.
2016 Oceanic |
The Following User Says Thank You to ActionMaxon For This Useful Post: | bobbinator (06-14-2019) |
06-14-2019, 12:56 PM | #22 | |
Drives: 2013 FRS Hot Lava
06-14-2019, 02:36 PM | #23 | |
humfrz |
06-15-2019, 01:34 AM | #24 | |
In which case you’ll need to buy this pigtail: Purchase RB26 wheel speed sensor here: https://www.wiringspecialties.com/rbspseco1.html You mentioned you bought the car used. It’s probably not on its original clutch right? If the mechanic doesn’t disconnect this cable then it can become damaged. Here’s what mine looked like after a clutch install by someone not used to the 86 platform vs the above brand new rb26 pigtail. What my fix looks like. After doing this my reverse lights, cluster R light, and backup Cam fired up all as they should. Hope this helps. |
The Following 2 Users Say Thank You to norcalpb For This Useful Post: | bobbinator (06-15-2019), gravitylover (06-16-2019) |
06-15-2019, 02:22 PM | #25 |
Drives: Many
I wasn't implying the plug was cut, it's just the picture I found.
My car had mouse damage which had been fixed, but I bought the W-S connector and wired that in. Posted about it in another thread a couple years ago. |
The Following User Says Thank You to e1_griego For This Useful Post: | Ultramaroon (06-15-2019) |
06-15-2019, 06:44 PM | #26 | |
Any kind of damage can render this exposed connector inoperable. Last edited by norcalpb; 06-15-2019 at 09:36 PM. |
06-16-2019, 06:31 PM | #27 |
If the tranny had been pulled to put a new clutch in or something maybe the plug wasn't plugged back in. I'm pretty sure that's why mine isn't working but I don't feel like dealing with putting it up on stands and such then crawling under there to figure it out. I've changed the fuse and both bulbs and done a cursory look through at everything else that I can see easily and all looks well. What clued me in is a random knock coming from almost directly underneath me that sounds like plastic banging on the underside of the car when I'm on the highway and the gear indicator on the dash doesn't register R when I'm in reverse.
03-24-2022, 12:49 PM | #28 |
Drives: best
If we're talking about lighting here, I want to ask: What light bulbs would you advise buying in the living room? My goal is to create an atmospheric and pleasant light.
Similar Threads | ||||
2013 BRZ Reverse Light (Reverse & Reflector) | kberkel | Exterior Parts (Aero, Lighting, Etc.) | 0 | 08-14-2016 01:14 AM |
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly | zeal86 | Exterior Parts (Aero, Lighting, Etc.) | 15 | 05-29-2016 10:01 PM |
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) | ZetaPerformance | Exterior Parts - Lighting | 172 | 11-13-2015 10:25 AM |
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! | Vicious LED | Exterior Parts (Aero, Lighting, Etc.) | 9 | 08-25-2013 07:26 PM |
