Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
02-07-2017, 04:20 PM | #1 |
Drives: 2013 Scion FR-S 10 series
Custom one piece dash for double din
Ok so this is a continuation of an earlier post
http://www.ft86club.com/forums/showthread.php?t=114610 Where I customized my dash opening for a double din with bondo so that you didn't see the plastic dash kit. Not sure if this belongs here or in cosmetics but it revolves around the stereo so here goes. Again, credit where credit is due, idea came from DigitalAssassin's build thread. I pulled the dash back out, recessed the stereo a little bit by drilling new mounting holes in the bracket and contoured the stereo opening to match the face of the head unit. However, I also like the look of the one piece dashes so I joined the two sides of my dash trim with apoxy, added some bondo to smooth out the transition and wrapped it all in carbon fiber when I was done. I'm pretty happy with the way it turned out. Eman Last edited by Eman; 02-07-2017 at 04:27 PM. Reason: auto correct |
The Following 4 Users Say Thank You to Eman For This Useful Post: | DAEMANO (02-07-2017), Griever423 (08-06-2020), Juzzotec (01-31-2019), Racecomp Engineering (01-29-2019) |
02-07-2017, 04:21 PM | #2 |
The Gunshine State
Drives: '14 BRZ Limited
Nice work, I don't like the CF look but the one-piece design is nice.
Current DD: M235i |
02-07-2017, 04:30 PM | #3 |
02-07-2017, 04:43 PM | #4 |
Time Traveller
The Following User Says Thank You to DAEMANO For This Useful Post: | Eman (02-07-2017) |
02-07-2017, 05:05 PM | #5 |
Drives: Grrrr
That does look good
The Following User Says Thank You to Scrappydoo For This Useful Post: | Eman (02-07-2017) |
06-08-2018, 01:41 PM | #6 |
Drives: 2015 Scion FR-S RS 1.0 #384
Hey man do have the link to DigitalAssassin's walk through of this? I can't find it. I mean I appreciate yours but the more I can read the better
01-29-2019, 09:56 AM | #7 |
Drives: Toyota 86
Not bad dude. Looks interesting to me. I would like to add something for you 'Best Double Din Head Unit. This will make your journey more interesting.
Source: https://rocketcarparts.com/best-double-din-head-unit/ |
01-29-2019, 09:59 AM | #8 |
Wes
new ones come with a one piece dash. Do they not fit on the '13-'16s?
Instagram: @gt86ws
01-29-2019, 10:33 AM | #9 |
01-29-2019, 12:09 PM | #10 | |
Wes
EDIT: nevermind, I googled it and it's the head unit
Instagram: @gt86ws
01-29-2019, 12:26 PM | #11 |
Drives: '13 Scion FR-S & '17 Toyota 86
01-31-2019, 03:49 AM | #12 |
Drives: Toyota 86 GTS
That looks great man, can I ask how you knew the two pieces were lined up perfectly when you were gluing them together? Did you just lay them on a flat surface side by side?
08-05-2020, 12:18 AM | #13 |
Drives: 2014 FR-S
The stock piece isn’t actually supposed to look like CF. It’s a pattern the designers came up with using the vintage triangular Toyota emblem (same motif around window switches, climate controls and the brake light’s shape).
Similar Threads | ||||
Custom dash for double din stereo. | Eman | Electronics | Audio | NAV | Infotainment | 3 | 01-16-2017 11:55 PM |
WTB BRZ Double Din Dash Pieces | mikeTee | Want-To-Buy Requests | 4 | 05-05-2016 01:33 AM |
Double Din dash trim | jinyang1590 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-17-2015 02:57 PM |
* M Technica Aero Wheels / Two Piece and Three Piece Custom Wheels * | GuerillaRacing | Wheels and Tires | 110 | 02-25-2015 06:10 PM |
Idea to fix double din dash piece | Larkin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-22-2013 02:16 AM |
