Old 07-06-2017, 06:26 PM   #155
Astroboy
Astroboy's Avatar
Drives: None
Was the wireing difficult? Or did they make straight forward adapters for an ls swap on these cars already
Sent from my LG-H820 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-07-2017, 05:31 PM   #156
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm using the Motec package from @Pure Automotive and their solution is plug and play, so no need to mess with wiring.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Astroboy (07-07-2017), ILLSMOQ (07-27-2017), Pure Automotive (07-17-2017)
Old 08-01-2017, 01:38 PM   #157
Sportsguy83
Drives: Limited BRZ
Originally Posted by gtpvette View Post
Do you think one of sheet metal oil pans might give you enough room?? I.E. Sikky's or Moroso's
I have the Sikky pan with CX Racing mounts and the sway bar fits. Fitment varies per motor and setup obviously but in my particular case, Vette LS2, I needed a 1/4" plate to raise the engine a bit to clear the steering rack and sway bar, with the added benefit the oil fittings are now more accessible and will work and not need to modify the pan. The sway requires a slight grind on the rear oil pan webbing. The Sikky pan includes a rear transmission cover while the CX Racing pan does not.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
gtpvette (08-01-2017)
Old 08-01-2017, 02:13 PM   #158
all4spl
Vette LS2? are you referring to the oil pan? I thought it was the GTO pan that fit not the vette?
all4spl is offline   Reply With Quote
Old 08-01-2017, 02:40 PM   #159
Sportsguy83
Drives: Limited BRZ
Vette LS2 I meant the engine I have. I say this because from what I've gathered, the LS1, LS3 all fit slightly different while using the same CX Racing mounts.
Yes, the GTO pan is the only front sump OEM LS pan, all others are rear sump and do not fit with the stock steering rack.
Old 08-01-2017, 03:32 PM   #160
all4spl
Oh I see. That makes sense.
The Following User Says Thank You to all4spl For This Useful Post:
Sportsguy83 (08-01-2017)
Old 09-25-2017, 07:52 AM   #161
Sportsguy83
Drives: Limited BRZ
FYI the CX Racing mounts plus the Tremec TR-6060 from 2010-2015 camaro with it's OEM shifter puts the shifter just about 1" back compared to stock.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
all4spl (09-25-2017), DustinS (09-25-2017)
Old 09-25-2017, 06:58 PM   #162
all4spl
Which notch did you install the engine on? Second from the front?
Old 09-26-2017, 03:24 PM   #163
Sportsguy83
Drives: Limited BRZ
I don't remember, I think it was the first one?
Old 10-04-2017, 08:21 AM   #164
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Any progress?
ILLSMOQ is offline   Reply With Quote
Old 10-04-2017, 09:53 PM   #165
Sportsguy83
Drives: Limited BRZ
Originally Posted by ILLSMOQ View Post
Any progress?
Nothing new, waiting right now for the hard line from slave to outside of transmission that was cut on my transmission.
Old 10-04-2017, 11:42 PM   #166
ILLSMOQ
What’s the hold up on that? Nobody local can make the line?
I’m waiting for a set of headers...otherwise I’m ready to go. Think you’re closer to getting it running than I am though..... I’m impatiently waiting to see our cars up and running .
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Sportsguy83 (10-05-2017)
Old 10-05-2017, 07:43 AM   #167
Sportsguy83
Drives: Limited BRZ
Ordered the OEM one from a GM dealer, had like a 10 day waiting period, but it's already shipped and on the way.
Old 01-05-2018, 11:32 AM   #168
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (01-05-2018)
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
FS: (Sold) Sportsguy ArmRest kvnchu Interior Parts (Incl. Lighting) 22 03-13-2014 02:40 PM
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly Sportsguy83 Forced Induction 155 08-05-2013 06:17 PM
Motegi 126 customs kioton32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-26-2013 12:34 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
