09-30-2018, 08:57 PM | #29 |
Drives: 2018 Gt86
What data elements does the logging function capture from our cars over the CAN/OBD? Throttle position/brake pressure, steering angle?
Edit: So this little thing will capture all these parameters(from another AIM threat) and overlay it with GPS coordinates, G force data and video? Wow. Wish it worked.
09-30-2018, 10:58 PM | #30 | |
Drives: Fr-s
10-01-2018, 08:22 AM | #31 | |
Drives: 2016 White Pearl BRZ Premium
The firmware update for our cars now has it capturing all of the data promised. Mine works great now (cough, took forever, cough). |
The Following 3 Users Say Thank You to Joesurf79 For This Useful Post: |
10-02-2018, 02:48 AM | #33 | |
At a basic level, look at your speeds. From there, you could go into all sorts of detail. PM me to order an AIM. |
10-02-2018, 07:06 AM | #34 | |
CSG mike is correct that it just collects data, the interpretation is up to you. But once you have aim data to share and others share with you, you can start to make some general judgements on where you're losing big chunks of time looking at your lap on screen side by side compared to others. The key is that you need to be experienced enough to be consistent lap to lap, or else your changes will just get lost in the noise. Check this book out if you're willing- it's a great primer on this topic. https://www.amazon.com/Practical-Gui...words=bob+knox |
10-03-2018, 05:10 PM | #35 | |
Drives: Nevermorange FRS
Spend a couple hours on James Colborn's channel and you'll be a pro at analyzing data with Race Studio. He's a brilliant racer (a brilliant man) and his videos are well put together for learning how to get the most out of the software. https://www.youtube.com/playlist?lis...8iHBjjNDnCNCTf Make sure you are using the data for good and not bad. What I mean by that is: Good: Data illustrates bad behavior or poor car setup. It can be used to identify talent gaps or help you understand why that thing you think is fast, is actually slow. Bad: The data says your car has a 1:39 in it when you're doing 1:43s so without any car or driver development you just go out to do 1:39s and run into things or other people.
SCCA T4 - FRS
10-10-2018, 11:55 AM | #36 |
Drives: 2018 Gt86
Thank you for the book recommendations. Looks like it's going to be intense. The videos are excellent and pretty accessible. The gps overlays of his different lines when he overcooks a corner are illustrative.
Does this thing have any engine diagnostic uses? Can I add oil pressure logs to it? Edit- answered my own question again. It can't. Need an Aim MXL or something. The rabbit hole gets deep quick with brake pressure monitors, tire and brake temp sensors ect. Last edited by dpaqu; 10-10-2018 at 12:46 PM. |
10-10-2018, 12:32 PM | #37 |
Drives: Subaru BRZ
Ok, the intermittent rebooting/flickering is solved now once I got the 86Nanny installed. When I did the pedal dance and had to turn the car on and off a couple of times with the Solo DL hooked up to the OBDII port, the Solo got confused I guess.
The only problem with the Solo now is that it stays powered on when the car is shut off even though I think I have it set to a 5-minute shut off. If I shut it off manually, I come to the car later to find the Solo turned on by itself, wtf. |
10-10-2018, 02:20 PM | #38 | |
10-10-2018, 03:20 PM | #39 | |
Drives: Subaru BRZ
It cannot be shaky because the Solo works fine during a super shaky session and then the car is parked/stationary with no movement whatsoever. The 86Nanny OBD connector is firmly on, if it were not, my guess is that all the nannies would turn back on. The Nanny OBD port extension is also solid, I have to wiggle the Solo OBD connector a bit to uncouple it from the Nanny extension. |
10-13-2018, 02:35 PM | #40 | |
Drives: 2014 BRZ
The Following User Says Thank You to Sleepless For This Useful Post: | Code Monkey (10-13-2018) |
10-27-2018, 10:37 PM | #41 |
Drives: Fr-s
Anyone willing to share some data with can channels with me so I can get some familiarity with the software over the winter?
10-28-2018, 11:20 AM | #42 |
Drives: Subaru BRZ
Shit still not working the way it should for me. With the 86Nanny, AiM sometimes turns on when I start the car, sometimes it does not. The SmartyCam turns on when the AiM turns on automatically, but when I have to start the AiM manually, the SmartyCam does not turn on automatically, I have to press the power button.
Yesterday the AiM worked for the first two hpde sessions, then it shut off in the middle of the third session and the SmartyCam stayed on. Very frustrated with the setup. |
The Following User Says Thank You to Code Monkey For This Useful Post: | dpaqu (11-08-2018) |
Similar Threads | ||||
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
First FR-S in Ottawa Solo2 Event | Klinn | CANADA | 0 | 06-12-2012 11:13 AM |
