Software Tuning Discuss all software tuning topics. |
04-18-2020, 06:06 PM | #1205 | |
Closing the throttle to about 20% is ecutek inbuilt overboost protection in Radeon 10 and above. I'd check you MAP sensor is ok, then can fail and read incorrect boost levels. Also your waste gate actuator may be stuck or the boost line leaking or blocked |
04-21-2020, 02:43 PM | #1206 |
PhoneFlash by EcuTeK
04-21-2020, 08:02 PM | #1207 | |
Also, what version RaceROM do you use on your tunes?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
09-02-2020, 06:45 PM | #1208 |
Hi All,
We just released a new update, version 31.50. In this release we have updated the following. 1. Drivability down low between 2000-4000 RPM. 2. More LSPI updates down low, helps a fair amount of vehicles. 3. Better AFR closed loop control under WOT. 4. Better tip in performance 5. Better boost ramp in at low RPM's. 6. Improved Traction Control (optional upgrade) for cars even with 700+ hp 7. Improved AFR's for 17+ ECU's, since the control is a bit different 8. Flex Fuel blending improved, not just a linear adjustment. Regards, William Knose Delicious Tuning |
10-12-2021, 09:23 PM | #1209 |
That Guy
Drives: 2013 asphalt FRS MT
Not sure if you're even still active here but I thought I'd check.
My last tune was in 2016. No major changes to the car but I'm wondering what changes you've made to the tune since then. Mods are an ACE CS400 header, high flow cat in the front pipe, and that's about it. I might still have an aftermarket air filter, but I can't remember. |
10-10-2022, 02:45 PM | #1210 |
New updates on our Stage 1 and Stage 2 tunes:
Latest revisions offered by Delicious Tuning: Stage 1 Reflash (91,92,93, 94 octane, 95,98 RON, E85 and FlexFuel)): New Version 18.50 - Stock header manifold - Stock intake manifold 13-16 or 17-20 - Stock intake or your choice of intake (does not matter) - Stock or aftermarket exhaust system. - More details, click here Stage 2 Reflash (91,92,93, 94 octane, 95,98 RON, E85 and FlexFuel): New Version 18.50 - Designed to accommodate your preferred choice of header. - Revised intake, exhaust, timing, ignition advance, fueling, DI and PI maps - More details, click here |
10-18-2022, 01:57 PM | #1211 | |
Drives: 2017 Subaru BRZ Limited Performance
02-27-2023, 06:05 PM | #1212 |
We have some updates to our Stage 1, Stage 2, Flash & Go and All FI application tunes. The Stage 1 & Stage 2 required some small changes are to the idle control and startup conditions on speed density and some work is still in progress (below), so we will retain the same enumeration on the naturally aspirated applications. Where as the Flash & Go tunes have made quite a few changes (see list below) to our latest version which will also include, Edelbrock, Harrop, Innovate, and Jackson supercharger kits.
We seem to have found a small bug within the latest (and previous versions), while on speed density only, that in certain conditions (warm engine) on some 86's (does not affect all vehicles), the vehicle will start and die. This is something we have been reviewing with EcuTek and a few cars that have the issue. Otherwise the idle control should be a bit more stable now when running 100% Speed Density, with a lot less likely chance of receiving a high idle code as in previous versions of the tune. Latest revisions offered by Delicious Tuning: Stage 1 Reflash: New Version 18.50 - 100% Speed Density (any intake works) - Stock header manifold - Stock intake manifold 13-16 or 17-20 - Stock or aftermarket exhaust system. - More details, click here Stage 2 Reflash: Version 18.50 - 100% Speed Density (any intake works) - Designed to accommodate your preferred choice of header. - Revised intake, exhaust, timing, ignition advance, fueling, DI and PI maps - More details, click here Flash & Go (all forced induction applications) Version 33.50 - 100% Speed Density Enabled - Low speed acceleration from a dead stop. - Low speed stock throttle, with Race Throttle or higher speeds. - Improved Direct (mid RPM range) and Port Angle injection (low speeds) - Improved CAM Angles (better top end power) - Better tip in response for Speed Density - Improved off throttle burble (add-on) - Improved Flex Fuel (Ethanol) performance output - Improved Idle Control for more applications - Improved Mid Throttle / Mid RPM response and AFR ratios/targets - More Details: Click Here Regards, William Knose Delicious Tuning |
03-10-2023, 11:07 PM | #1213 | |
Any ideas or timing on when the gr86 will be supported?
Similar Threads | ||||
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK | DeliciousTuning | Announcements, Contests, Giveaways | 5 | 08-26-2013 02:33 PM |
