go_a_way1
Old 06-01-2014, 03:49 PM   #2325
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
@FRSEVO
What lip kit is that?
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 06-01-2014, 03:59 PM   #2326
FRSEVO
Drives: Ultramarine FRS
@UltraMarine86 HTAuto front and BaysonR side skirt extensions
Instagram @nmgrizzlybear
Buschur built Evo VIII - SOLD
Ultramarine FRS
FRSEVO is offline   Reply With Quote
The Following User Says Thank You to FRSEVO For This Useful Post:
UltraMarine86 (06-01-2014)
Old 06-01-2014, 06:33 PM   #2327
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
Got an alignment today finally.
Started off with -10.5 rear camber, and then had my LCA's and toe set to the shortest length possible, and was able to get -9.2 camber with 0 toe. Ended up being exactly where I want the wheels to be. I only have -5.5 front camber right now, so need to get new plates or notch my coils to get closer to the -8 that I'm looking for.
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
HATED1 (06-01-2014)
Old 06-01-2014, 07:49 PM   #2328
Brndn704
Brndn704's Avatar
I'm just gonna ask a really dumb question. What tires do you run? Honestly, I have about -4 degree camber in the back and my tires don't last too long, I'm maybe getting about 3-4k miles out of the backs.
Brndn704 is offline   Reply With Quote
Old 06-01-2014, 07:53 PM   #2329
moomoopanda
Drives: Argento FRS
I currently have Federals in the rear..
But maybe consider getting an alignment? I'd guess that your toe isn't within spec, so its scrubbing away and eating up your tire. I don't really pay attention to how long my tires last, but I know they don't go bad that quickly.
Kosmos (06-01-2014)
Old 06-01-2014, 08:43 PM   #2330
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
When you go for an alignment have them zero out the toe. It will have minimal wear on your tires
Sent from my SM-N900P using Tapatalk
Kosmos is offline   Reply With Quote
Old 06-01-2014, 08:45 PM   #2331
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Originally Posted by Charky View Post
Wheels and tires specs ???
I have cosmis racing wheels x5-005R 18x9 with 25mm offset on federal 595s 215/45/17s
Old 06-01-2014, 08:47 PM   #2332
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Originally Posted by UltraMarine86 View Post
@FRSEVO
It's the gt style lip
Old 06-01-2014, 08:49 PM   #2333
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
I need help with camber for my fronts. What did you mean by notching your coils?
Old 06-02-2014, 08:16 AM   #2334
Johnny_MA
Drives: 2014 Subaru Brz Limited WRB
What profile tire you running? 35 or 40 series?
Johnny_MA is offline   Reply With Quote
Old 06-02-2014, 12:58 PM   #2335
moomoopanda
Drives: Argento FRS
If your camber bolts don't gain enough camber, you can slot the upper hole on the lower coilover mount. This will gain you a few degrees of camber depending on how much you want to notch the mount.
Basically make it look like this:
I have 17's in the front with 40 series. My rear battles are 215/35's, the blitz's are on 215/40's.
Few random shots while I was getting my car aligned yesterday.
Kosmos (06-02-2014)
Old 06-02-2014, 01:43 PM   #2336
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Oh okay great. Def makes sense although my camber bolts are made for the lower strut tower not the upper. Think I could notch the stock bolts?
Old 06-02-2014, 02:58 PM   #2337
moomoopanda
Drives: Argento FRS
You'd be notching the strut mount itself, so you wouldn't be touching the bolts..
Old 06-02-2014, 04:11 PM   #2338
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Yeah the hole. I meant if I could use the stock bolts for the upper strut tower when I notch it
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1742 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
