86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Tracking / Autocross / HPDE / Drifting
Old 08-13-2019, 03:40 PM   #43
Jordanwolf
żżżż
Jordanwolf's Avatar
Drives: 2017 900whp beast
Didn't you read? He's gotta keep the pressure up, not chill.
Chilling the oil will result in keeping the pressure up. Unless I have been misinformed thus far.
I have come to HUG YOU
BROOOOOOOOOOOOOOOOOOOOOOOOOO.
Jordanwolf is offline   Reply With Quote
The Following 2 Users Say Thank You to Jordanwolf For This Useful Post:
strat61caster (08-13-2019), Tristor (08-13-2019)
Old 08-13-2019, 04:12 PM   #44
Clutch Dog
Drives: 2015 Scion FRS Halo white, Saab 97X
or my favorite
"wing, what wi...HOLY COW SOMEONE RUINED MY CAR WITH A UGLY WING!!! now i need to spend thousands to change it back!"
I feel attacked...
I only spent 600 bucks to get the frs wing holes filled and new holes drilled for the ts wing and then paint..
good news if i wanted to sell it. i can do it as a whole piece.
the whole car. 20k XD
Clutch Dog is offline   Reply With Quote
Old 08-13-2019, 06:29 PM   #45
ZDan
Drives: '17 BRZ PP, '11 Cayman
Originally Posted by Tristor View Post
Using heavier weight oil can help with pressure drops and is recommended for track use or any heavy use, even in the owner's manual (0W20 is normal spec, heavy use spec is 5W30 for this platform). But the temperature issues on this platform are well understand and reported, an engine oil cooler is the best, simplest, and most basic protection you can take to bring things under control under heavy use. There is absolutely no reason to avoid installing one if you are tracking the car, and a bevy of reasons why you should.
I've researched this extensively, and I haven't seen any evidence that the "high" oil temperatures the stock cars see of ~270F is necessarily a problem for "casually" tracked cars. I have seen tons of people *assume* that it must be, though...
Reasons one might *avoid* installing one:
$$$$, time, effort expended, overcooling of oil in colder temps, additional potential failure points, fire risk.
An engine oil cooler is the first line in that defense... arguing against it while simultaneously pointing to the exact flaws it helps with is weird to say the least.
??? The thread I pointed to was about cavitation at high rpm, which they solved with a different pickup tube. I don't think that issue would be helped by an oil cooler.
Regarding pressure, here's some data from this thread:
https://www.ft86club.com/forums/showthread.php?t=91820
Note that while temps are 20-25F cooler with the oil cooler, the pressure is actually the same, ~7.5psi/1000-rpm for 5W30 oil, at ~250F with cooler or at ~272F without the cooler. I.e. any gain in pressure from running cooler oil is lost as pressure drop in the cooler.
My oil temps get up to ~272F, but always stabilize and never try to "run away".
In my opinion, the NEED for an oil cooler for limited tracking of stockish cars might be overstated...
I've mentioned this in other threads, but here it is again for reference only (not saying this definitely means anything for our cars!)
here's how Ford characterizes oil temperatures in '18 Mustang Factory Service Manual:
38-60° C (100-140° F) (low)
61-137° C (142-279° F) (normal)
138-146° C (279-295° F) (warm)
147-160° C (297-320° F) (hot)
ZDan is online now   Reply With Quote
strat61caster (08-14-2019)
Old 08-13-2019, 06:48 PM   #46
Leonardo
Row Row Row Your Boat!
Leonardo's Avatar
Drives: 13' FR-S, 07' MDX, 06' Ridgeline,
Measure twice (ok three times) CUT ONCE!
Don't add stupid mods that only a high schooler would appreciate, and you will be fine.
I screwed my side skirts to my car. There are holes on each side. My front bumper had a lip, I ripped it off; holes there too. Oh well. I also skinned the seats and added leather. It took long enough I would NEVER consider removing it. (I might not actually do it again, it was a PITA!)
Life is but a Dream!
Old 08-13-2019, 10:53 PM   #47
soundman98
Boost is Whack. N/A4LYFE
soundman98's Avatar
Drives: '14 brz limited
Originally Posted by Clutch Dog View Post
I feel attacked...
cheaper than me so far! bought a gt-r trunk lid for $600, replacement oem spoiler trunk lid for $300, and i still need to fill and paint it all...
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
Clutch Dog (08-15-2019)
newbie asking general question Shaungeez Subaru BRZ General Forum 15 08-30-2017 12:45 PM
general question Stewie Subaru BRZ General Forum 39 04-12-2015 08:57 PM
General PurePrice question schmidty Scion FR-S / Toyota 86 GT86 General Forum 55 04-02-2014 05:27 PM
General boosting question Pneub Forced Induction 8 10-30-2013 02:36 AM
General Detailing Question jpdesilva Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-11-2013 11:21 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
