Old 04-08-2016, 03:05 AM   #155
CSG Mike
CSG Mike's Avatar
Originally Posted by CxG View Post
if someone had plans to build their FA20 to rev out to 9k, would the C38 still be within operating RPM on either pulley?
That's gonna be an awful lot of boost
CxG (04-08-2016)
Old 04-08-2016, 09:58 AM   #156
CxG
Drives: Pearl White '13 ZN6
that's the point I'm just wondering if the unit will be able to keep up.
I understand that it has a maximum impeller speed of 90,000 rpm.
I understand that with stock pulley and engine at redline impeller speed is @ ~70.5k rpm
I understand the HBP or an increased redline will up the boost and impeller rpm
What I don't understand is by how much.
What would Impeller speed be at a 9,000 redline and stock pulley?
let's say it's that maximum of 90,000 rpm. Would the HBP just bring the torque curve in sooner or would it over spin the SC and destroy it?
Is there a fix, work around, or other kit for this that uses a centrifugal SC?
CxG is offline   Reply With Quote
Old 04-08-2016, 11:41 AM   #157
CSG Mike
CSG Mike's Avatar
You have enough overhead to use a standard 110mm pulley. You do not for a 100mm pulley.
Do you currently own a C38 JRSC?
CxG (04-08-2016)
Old 04-08-2016, 12:01 PM   #158
CxG
No I do not, I want to buy a kit soon but I don't want something that won't have the over head needed for my long term goals.
Sent from my D5803 using Tapatalk
Old 04-08-2016, 12:31 PM   #159
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
With a C38 there will be enough overhead.
JDMChris is offline   Reply With Quote
Old 04-08-2016, 01:27 PM   #160
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
@CxG The C38 will have sufficient overhead for long term goals. The engine will be the weakest point. If you would like to work on your engine, don't hesitate to contact us for specific internals for your build. Thanks!
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
CxG (04-08-2016)
Old 04-08-2016, 02:01 PM   #161
CSG Mike
CSG Mike's Avatar
9000x1.29x7.5 = 87075
9000x1.419x7.5 = 95782
Not enough for the 100mm pulley
CxG (04-08-2016)
Old 04-08-2016, 02:42 PM   #162
CxG
But it's probably the only kit that has a unit capable of keeping up and not snapping belts every 10k miles.
Any way to calculate the boost it'd be making at peak?
The Following User Says Thank You to CxG For This Useful Post:
Bykov (04-08-2016)
Old 04-08-2016, 05:27 PM   #163
CSG Mike
CSG Mike's Avatar
Boost is dependent on restriction, but if it were, theoretically, a stock engine, you'd theoretically be seeing 20-24psi at 9000 rpm.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Bykov (04-08-2016), CxG (04-08-2016), SPCorBUST (04-18-2016)
Old 04-09-2016, 04:01 AM   #164
Lord09
Drives: 2015 BRZ
Aside from cost, any downside ordering the C38 kit instead of the C30 kit?
From my understanding to fully take advantage of the C38, I'd need a built engine, which isn't something I plan on.
I'd probably just happily drive with the standard pulley and CARB legal tune, though the idea of the HBP + E85 is very appealing.
Regardless it seems like ordering the C38 kit would be wise, just in "case" of big power dreams.
I'm only concerned if the tune on the C30 kit is superior or if the power delivery is drastically different due to the blower sizes.
For the CARB tune, peak power has been been advertised as being the same, but how's the power below the peaks?
Is one kit more responsive than another?
Lord09 is offline   Reply With Quote
Old 04-09-2016, 08:25 PM   #165
Bykov
Drives: 2014 Monogram FR-S Whiteout
Cost is the only disadvantage and in the grand scheme of things and how much the system costs in total, the extra cost is drops in the bucket. Power delivery is identical and I am willing to be even the tune is identical. The C38 is also quieter. This a plus for some and a negative for others (like me). The C30 is 11.2 pounds and the C38 is 13.2 pounds so there's a disadvantage there. E85 would make equal gains on both systems until you start swapping pulleys so that falls into the big power dreams you mentioned. Peaks are the same but according to charts I have seen the C38 is better below the peaks. That's only according to boost pressures read at the MAP and I am sure the difference isn't measurable, especially if the tunes are in fact the same. The only reason the system has a different CARB EO is because it uses different parts and every iteration has to be re-certed. I hope this helps. I was going to buy the C30 myself but ended up going with the C38 system instead.
Bykov is offline   Reply With Quote
The Following 4 Users Say Thank You to Bykov For This Useful Post:
CxG (04-09-2016), JEFFSTYLE (04-13-2017), KalbiCool88 (04-22-2016), menikmati (04-09-2016)
Old 04-18-2016, 06:27 PM   #166
byun
byun's Avatar
Drives: 2015 BRZ CWP
Jackson Racing C38-81 Supercharger - CARB legal
I just added got custom tuned and my car doesn't see more than 7psi of boost.
What's the standard boost level for the C38 w/ standard pulley?
Was wondering what other owners are seeing their boost levels at with the standard pulley?
byun is offline   Reply With Quote
Old 04-18-2016, 08:15 PM   #167
Bykov
Depends on altitude. Here at 4400 feet-ish that's what we are seeing and of course it will continue to drop as you get higher. You can check what altitude you are at and if you are not at such a high altitude then you may or may not have an issue. If you got custom tuned, what was your baseline and what did you make with the SC?
Old 04-18-2016, 08:25 PM   #168
byun
byun's Avatar
I'm pretty much at sea level. Wasn't able to get a baseline. Ended up with 236whp mods are JRSC c38 w/ ace header 250 and greddy supreme sp catback.
I think a stock brz on there dyno is around 135-140whp
FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal spitz Cars for Sale/Trade 3 02-04-2016 11:59 PM
Jackson Racing CARB supercharger+oil cooler LA blahblah Engine, Exhaust, Bolt-Ons 9 12-30-2015 12:33 AM
(SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA *LongFella Cars for Sale/Trade 27 04-11-2015 12:35 PM
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 07:50 PM
