Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Subaru BRZ > Subaru BRZ General Forum
Subaru BRZ General Forum All discussions about the Subaru BRZ coupe
Old 10-16-2019, 09:53 PM   #15
soundman98
Boost is Whack. N/A4LYFE
soundman98's Avatar
Drives: '14 brz limited
It has nothing to do with the year, some to do with being blown, and mostly to do with engine speed.
An oil pressure gauge along side a temp gauge will motivate any sensible person with a stock engine to look into an oil cooler. Don't cheap out. Get a good one.
the real question is where to mount pressure sender? apparently there's a number of high and low pressure spots within the system
i haven't seen a good answer for that
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
soundman98 is online now   Reply With Quote
norcalpb (10-16-2019)
Old 10-16-2019, 10:08 PM   #16
Decep
Drives: 2013 FR-S Series 10
Doesn't get too hot around here so even with FI there's no need for oil cooler if you're not tracking. I don't think i've seen my temps past 235, 240 degrees. Most of the time it's ~220.
2013 FR-S 10 Series ~50k
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger
Decep is online now   Reply With Quote
Old 10-16-2019, 10:19 PM   #17
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
Dug through some old pics pre-boost and found my coolant temp has always been right in the middle (it was 115 outside that day). Oil Temps need to be addressed.
Just for grins the Pic in the owners manual...
Sent from my SM-N960U using Tapatalk
tfp is offline   Reply With Quote
Old 10-16-2019, 11:17 PM   #18
soundman98
soundman98's Avatar
that image is some sort of diagnostic screenshot. 13v battery voltage either means that your charging system is failing, or is being run off of a poorly regulated charger/external power supply.
you should be seeing a battery voltage of either 12v when the vehicle screens are on but the motor is off, or you'll see a battery voltage of 14.2-14.4v with the engine running.
any deviation from 14v means there's something wrong.
hidplanet build log
Old 10-16-2019, 11:33 PM   #19
tfp
tfp's Avatar
Um... It's from the owners manual.
Old 10-16-2019, 11:55 PM   #20
soundman98
soundman98's Avatar
yes, i know, i'm just specifying not to use it as a reference for anything other than their own description, as at least one of the indicated levels is not a typical vehicle condition.
hidplanet build log
Old 10-16-2019, 11:57 PM   #21
Ultramaroon
fun police
Ultramaroon's Avatar
There are only a couple practical places to measure pressure. The service manual gives one data point, 73 PSI @ 176 F to be measured at the port for the idiot light switch
https://demos.starbase7.net/t3Portal...00T5102GX.html
This is a good thread where I was inspired to reproduce a test of the difference between pressure at the stock port and at the tap just upstream of the mains gallery. The whole thread is a good read but if you want to cut to the chase, see post 89.
I'm happy measuring at the mains. It's a convenient spot and the numbers are especially meaningful after seeing how much more the downstream pressure fluctuates with temperature. I don't bother looking at temp anymore. I can deduce it on the fly by comparing pressure against engine speed.
Ultramaroon is online now   Reply With Quote
jcw99 (10-17-2019), korhun (11-21-2019), soundman98 (10-18-2019)
Old 10-17-2019, 12:38 PM   #22
Grady
Grady's Avatar
Drives: BRZ Yellow, 00 outback, 05 Colorado
Not on a 17+ the charge logic will cut the alternator at idle when hot and battery is fully charged. I see that voltage on mine all the time. It does not stay there long. This will reduce fuel usage at idle and should increase battery life.
The Following 3 Users Say Thank You to Grady For This Useful Post:
jcw99 (10-19-2019), soundman98 (10-19-2019), TunaNoCrust (10-22-2019)
Old 10-18-2019, 10:03 PM   #23
Humbleambulancedriver
Drives: 2017 BRZ
My NA 17 gets to this anytime it's over 100F and freeway driving. Hard uphill canyon driving I can get up to 250ish but not for long. I would say 200 to 220 is pretty normal. The first few pictures... Probably too hot.
Humbleambulancedriver is offline   Reply With Quote
The Following 2 Users Say Thank You to Humbleambulancedriver For This Useful Post:
jcw99 (10-19-2019), tfp (10-19-2019)
Old 10-19-2019, 10:32 AM   #24
BRZ FTW
Drives: 2017 Subaru BRZ
Press and hold center button on right steering wheel control to change scale of coolant temp on gauge.
My oil temp on stock 17' can easily get past 250F.
BRZ FTW is offline   Reply With Quote
The Following 4 Users Say Thank You to BRZ FTW For This Useful Post:
DaBoBo21 (10-19-2019), Grady (10-20-2019), ScoobsMcGee (10-22-2019), Semiihcircle (10-20-2019)
Old 10-19-2019, 04:34 PM   #25
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: '17 BRZ Limited, '15 Cooper S
Same, since new. Hello from SAT btw!
DaBoBo21 is offline   Reply With Quote
The Following User Says Thank You to DaBoBo21 For This Useful Post:
BRZ FTW (10-22-2019)
Old 10-20-2019, 05:28 PM   #26
Semiihcircle
Drives: 17 BRZ
Oil Temp seemed great this morning otw to work. Was low 50's outside.
Might as well plan on getting the Jackson oil cooler since they got all my money so far with my boost build .
no thats normal coolant temp if you hold the center dot on the right side of the steering wheel it will tell you that that level is 190F
Semiihcircle is offline   Reply With Quote
Old 10-20-2019, 05:31 PM   #27
Semiihcircle
Drives: 17 BRZ
You just push and hold for a few seconds, and the guage also adjusts to the lower mark, as in the on my dash 190F is that lower mark as shown but to everyone else without the labels on the side, their coolant temps are also or just around 190F.
But also the using the other unlabeled method the cold coolant light turns off as soon as you can see the slightest red line on the coolant section, meanwhile for me since i use the labels mine does not...
Old 10-22-2019, 12:36 AM   #28
tfp
tfp's Avatar
Thanks for that coolant gauge tip!
Search this Thread:
Advanced Search
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 09:21 PM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 03:57 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
