Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 11-17-2019, 09:32 PM   #15
fun police
Originally Posted by localhost View Post
Yeah, definitely going back to the stock header is a good test - just a real pain haha. And yes, I do have the Ecutek cable and software.
I've emailed my local tuner to see if they can fit me in since I'm fairly certain it just needs to be custom tuned to compensate for the header but I'm not sure if they even do any tuning in the winter.
You can log with that stuff, right? Take a minute or so of cruising when it's all warmed up. Sample all the channels you can and post it up on datazap.me
https://datazap.me/u/ultramaroon/log...?log=0&data=38
Ultramaroon is online now   Reply With Quote
Old 11-17-2019, 09:35 PM   #16
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
Yep it can log but I don't have a laptop that can run the Ecutek software without being plugged in. But I also have my OFT from when I was still NA, so I'll probably just use that.
localhost is offline   Reply With Quote
Old 11-17-2019, 10:05 PM   #17
localhost
Datalog: https://datazap.me/u/rb28dett/nov-17-cruise
Short cruise after everything had warmed up. Very little throttle throughout, with one instance up to 4k RPM with light throttle as well.
Old 11-17-2019, 11:31 PM   #18
Decep
Drives: 2013 FR-S Series 10
The edelbrock tune is not for catless headers.
2013 FR-S 10 Series ~50k
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger
Decep is online now   Reply With Quote
Old 11-18-2019, 12:09 AM   #19
fun police
Certainly shows something out of balance. I'm still an amateur at this but lots of experienced people will see it.
localhost (11-18-2019)
Old 11-18-2019, 12:59 AM   #20
solidsnake11
Drives: brz
Its running very lean you will not smell gas, you will smell pistons burning.
Example: commanded afr 13.8 actual afr 16.33 Your fuel trims are way off in places. Maxed out adding fuel. Example: 3158rpm .8 lbs stft 33.2
Probably should stay off the skinny pedal in till you get it sorted out.
I would look for air leaks between maf and supercharger. Check wires and extension to maf. I had a similar problem when I had a broken maf wire. From the sale pictures of the supercharger the maf wire is laying on the pulley.
If leak was after supercharger you would be killing bugs with gas fumes.
solidsnake11 is offline   Reply With Quote
The Following 3 Users Say Thank You to solidsnake11 For This Useful Post:
kev0 (11-18-2019), localhost (11-18-2019), Ultramaroon (11-18-2019)
Old 11-18-2019, 10:32 AM   #21
toast
Drives: 14 BSP Edelbrock BRZ
An engine is basically an air pump. Your air pump can now flow about 20% more air because the outlet is less clogged. You can't run the tune designed for 20% less air.
It is difficult to drive because the throttle tables in the Edelbrock tune are left like they are in stock form - a small pedal input results in a large change in throttlebody opening. In stock form this is done so the car doesn't feel like a slug. When you have forced induction available this makes it very tough to keep the engine in vacuum.
Swap the headers or get a real tune ASAP.
toast is offline   Reply With Quote
The Following 3 Users Say Thank You to toast For This Useful Post:
Lantanafrs2 (11-18-2019), localhost (11-18-2019), Ultramaroon (11-18-2019)
Old 11-19-2019, 08:08 AM   #22
solidsnake11
Drives: brz
The maf doesn't see extra air entering the engine?
Old 11-19-2019, 11:30 AM   #23
toast
Headers change the VE. The calculation for load uses VE in the divisor, so for a given measured airflow the ECU will undervalue the engine load and will not add the appropriate amount of fuel until the AFR shows lean and then it will attempt to correct it up to the maximum fuel trim allowed.
I've never seen fuel trims over 27%, I didn't know they could go as high as his log is reporting. I guess that is also determined in the tune.
Old 11-19-2019, 11:15 PM   #24
solidsnake11
Drives: brz
What tune changes the ve values? But maybe these maps are not labeled correctly. They don't look like normal ve tables but maybe its because its drive by wire. With further research it seems ve tables are used with map sensor on speed density systems and limp mode. Maf systems rely on air flow and air tempature.
Here is 4 all the same.
2 more
Old 11-20-2019, 12:05 AM   #25
thinkV
Drives: BRZ Turbo
I double checked the bracket and it was tight. No movement at all. The connectors on the back were all also completely seated and locked in place.
Connectors: https://i.imgur.com/VRWgCsM.jpg
Bracket: https://i.imgur.com/FmrgCLO.jpg
Just FYI there's another hidden bolt on the left of that backet quite far down that goes straight into the block, that one in particular is the grounding bolt, so check that one too.
thinkV is offline   Reply With Quote
Old 11-20-2019, 12:10 AM   #26
localhost
Yep, all 3 bolts are nice and tight.
Reading through these comments I'm fairly certain my catless header with a tune that isn't expecting one is the root cause of these issues. I'm going to swap back to the OEM ones this weekend and see if it gets better.
Old 11-20-2019, 12:29 AM   #27
solidsnake11
Drives: brz
Hope it fixes your issues.
Anybody here ever have the O2 sensor 1 go bad? Because that would defiantly throw things off.
O2 sensor 2 may be throwing things off without the cat. Ecutek says something about turning it off for boosted application IIRC.
Injector driver defiantly needs grounded. My car came without the bracket and was doing very weird stuff before I grounded it.
Old 11-20-2019, 12:50 AM   #28
localhost
Is there a way to verify that its correctly grounded other than just checking the tightness of those bolts? I'm guessing checking if there's low resistance between the injector ECU housing (or that bracket) and the battery negative should be good?
CELs and not cranking 86 driver Issues | Warranty | Recalls / TSB 8 09-28-2017 01:08 PM
Odd CELS. Karl07 Issues | Warranty | Recalls / TSB 4 10-08-2016 07:53 PM
Unichip stock map to avoid CELs pwells Software Tuning 3 12-28-2013 03:57 AM
Engine Mods and CELs Captain Snooze Engine, Exhaust, Transmission 2 04-08-2013 10:13 PM
Cam Gear Related CELs - How many miles? uspspro Issues | Warranty | Recalls / TSB 16 10-22-2012 02:57 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
