Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Marketplace > Commercial Classifieds > Wheels and Tires
Old 11-04-2019, 10:10 PM   #1
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
► APEX 2019 BLACK FRIDAY - 20% OFF Lightweight 17” ARC-8 Wheels
Black Friday Starts Now at APEX!
Our big sale is now live! Save 20% OFF our popular lightweight 17” ARC-8 wheels for your 86/BRZ. Plus, add Michelin PS4S max performance summer tires or Nitto NT01 r-compound track tires to your order and get free mounting & road force balancing ($100+ value).
Our ARC-8 17x9” 5x100 wheel optimized specifically for the 86/FRS/BRZ community is designed to be strong, lightweight, and functional, and to top it off it clears the factory Performance Package/TRD Brembo brakes as well as a variety of aftermarket BBK’s. Whether you are are a street customer looking to upgrade your stock wheels, or a hardcore track enthusiast/racer who needs wheels that can withstand track abuse, we have you covered.
Don’t wait to place your order, these won’t last long.
These deals are valid from Wednesday, November 27th through Monday, December 2nd @ 11:59 pm Pacific.
Specs: 17x9" ET42 5x100
Weight: ~17.8 lbs
MSRP: $269 ea. / $1,076 set of four
20% OFF SALE PRICING: $215.20 ea. / $860.80 set of four
Visit Our Website to Order
Designed For The Performance Enthusiast
Fit Matters
An optimized car setup begins with the perfect wheel and tire fitment. The 17x9.0” ET42 ARC-8 configuration was built with feedback from very well know industry leaders to meet the needs of the hardcore performance enthusiast. That means the right fit and the most grip possible, for the flexibility to work for street enthusiasts and racers alike.
Spokes
The spokes of the ARC-8 were designed to be robust where they need to be, and extra lightweight where they should be. In each iteration of our ARC-8 design, the split spokes are carefully evaluated to ensure lightweight and remarkable strength. The lack of a deep front lip, and implementing spokes that connect directly to the barrel’s lip create a rigid wheel, with very even load distribution. These features help reduce one of the most common concerns with aftermarket wheels — bending.
Lug Recess
Unlike the narrow lug recesses of many other wheels, the ARC-8 wheel boasts a completely wide-open wheel hardware recess that easily fits race lug-nuts and the beefy adapters or impact sockets used to fit them. This allows for quick and easy wheel changes at the track, or just as a bonus; prevents chips and scratches from tools upon install or removal.
Hub Centric
Centering rings are never required for a direct fit with APEX wheels. For this application, a 56.1mm center bore is utilized. Rings might not sound so bad until one rolls away during a wheel change, or gets seized onto a wheel hub!
Open-Hub Center
Race wheels can't just be light, they need to function in a high-performance environment. Unlike the narrow lug recesses of most other wheels, the ARC-8 wheel boasts a completely wide-open design that easily fits over-sized race lugs and beefy impact sockets. This allows for quick and easy wheel changes at the track, and as a bonus prevents chips and scratches from tools for those just running these wheels on the street.
Brake Clearance - Spokes
APEX wheels properly clear all OEM brake calipers including many bolt-on BBKs. Our wheels are targeted at the serious performance-minded owner knowing many will elect to upgrade the basic OE caliper and disc setup as they get more serious with mods. If you do go with a big brake kit (BBK), most big brake kits that clear 17” wheels will fit behind our low profile spokes without spacers, although some applications may need a thin spacer due to the added width of aftermarket calipers.
Confirmed BBK clearance on our 17x9.0” ET42 ARC-8 wheel include: Stoptech ST40 328mm, Essex-AP Sprint & Endurance, AP Racing 330mm, Wilwood's kits, RacingBrake 4045, STi 4 Piston, 300ZX 4 Piston, Alcon 334mm, Sparta 355mm kit (3mm spacer is recommended), Tarox B32-6 326mm kit, RR Racing Stage I through IV Competition kits. If you have any questions, you can contact us to confirm brake clearances for your specific application.
Brake Clearance - Barrel
Spoke clearance is only half the problem. The barrel opening on a wheel also needs to be large enough to clear the sides of your caliper. Many wheels on the market make aesthetic compromises to their design that have a major negative impact on barrel clearance. Those wheels may work with stock brakes and smaller diameter big brake kits (BBKs), but larger brake kits can pose major clearance problems. Our barrel opens up wider and earlier than most aftermarket wheels. This creates the largest possible inside diameter to accommodate a wide range of BBKs.
The APEX Standard
1. FEA Optimization
Various design features were implemented to ensure that the ARC-8 wheel design was as light and durable as possible. We began with a strong one-piece design featuring an open hub center and reliefs in the mounting pad to remove weight between lug holes. The design was then run through Finite Element Analysis (FEA) to further optimize the spoke and barrel design. The result is a light weight wheel with extra strength in all the right places, while keeping weight to a minimum.
2. Always Flow Formed
All APEX wheels feature Flow-Formed construction tha utilizes rotary forging to produce a strong and lightweight barrel. The ARC-8 is no exception.
3. True JWL & VIA Certification
Strength needs to be certified. Our wheels were not simply FEA tested in a computer simulation, or in-house tested to an unregulated standard. We conduct real-world crush-testing and all of our wheels conform to Japan’s JWL standard, as well as being 3rd-party tested by the VIA. All of our wheels carry a 690KG load rating.
Tire Mounting & Road Force Balancing Service
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable 86/BRZ Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively. All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
*Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be canceled and refunded.
Fitment Questions? We know what fits.
From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error.Click here for a one-on-one consultation with one of our product experts
Lifetime Warranty
All APEX wheels come with a lifetime structural warranty and 1-year finish warranty, so you can be confident in your purchase. Learn more
APEX360° Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX360° Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more
Contact Information
APEX Race Parts is offline   Reply With Quote
Old 11-04-2019, 10:13 PM   #2
APEX Race Parts
The Following User Says Thank You to APEX Race Parts For This Useful Post:
pinoy_dorifto (Today)
Old 11-09-2019, 06:02 PM   #3
APEX Race Parts
Old 11-14-2019, 02:42 PM   #4
APEX Race Parts
Save 20% off a new set of 17" ARC-8 wheels. All finishes are currently in stock and ready to ship.
Old 11-27-2019, 02:55 PM   #5
APEX Race Parts
The BLACK FRIDAY sale starts now at APEX. All finishes are in stock, but they won't last long at 20% off!
Old 12-02-2019, 03:37 PM   #6
APEX Race Parts
FINAL HOURS - Take advantage of CYBER MONDAY pricing before it is too late! This sale ends tonight at 11:59 PM PST
Old 12-02-2019, 06:24 PM   #7
J1Avs
Drives: 2018 BRZ tS
https://www.youtube.com/watch?v=MZv46v16FW0
Is Free Shipping an option OR is there a coupon code?
J1Avs is offline   Reply With Quote
The Following 2 Users Say Thank You to J1Avs For This Useful Post:
APEX Race Parts (12-03-2019), chickunfut (12-03-2019)
Old 12-03-2019, 03:40 PM   #8
APEX Race Parts
This sale has officially come to a close. Thank you for all the orders, we look forward to getting wheels into your hands!
I appreciate your interest. Free shipping was not part of the promo, as we decided to offer a substantial discount on the wheels themselves at 20% off.
Old 12-03-2019, 10:00 PM   #9
J1Avs
Drives: 2018 BRZ tS
Not a problem! I placed an order either way! I just wanted to make sure I didn’t miss something.
Very excited for my new track wheels!
The Following User Says Thank You to J1Avs For This Useful Post:
► APEX | ARC-8 Lightweight Track Wheels APEX Race Parts Wheels and Tires 16 04-08-2019 12:42 PM
► APEX | 17" ARC-8 FT86/BRZ Wheel Group Buy 2019 - Up to $250 OFF + Free Shipping APEX Race Parts Groupbuys 19 02-25-2019 10:59 AM
► APEX | 17" ARC-8 FT86/BRZ Wheel Group Buy 2019 - Up to $250 OFF + Free Shipping APEX Race Parts Wheels and Tires 11 02-13-2019 09:23 PM
► APEX | Black Friday & Cyber Monday Sale / 10% OFF ALL Wheels & More! APEX Race Parts Wheels and Tires 1 11-26-2018 04:52 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
