Old 01-03-2020, 07:35 PM   #15
Dondo Yonderboy
Drives: 2020 Toyota 86 - Hakone Edition
Originally Posted by Jedifar View Post
Hey guys, success!!!
Was able to install BRZ 18 buttons on my 17 base model and the buttons work!! All i need now is the LCD cluster which is on the way. Wrapped my trim too while i was at it. Check it out!
Your image links appear to be broken. Do you have some more details about what you did? Did you replace the whole wheel or just add the buttons? I’m really interested in doing the same to my new 2020 86.
Dondo Yonderboy is offline   Reply With Quote
Old 01-04-2020, 04:23 AM   #16
gpvecchi
gpvecchi's Avatar
You can fit 2017 BRZ remote control, you'll replace the buttons with the silver things. This will work just with aftermarket HU. 2018+ remote has one button less.
gpvecchi is offline   Reply With Quote
Old 01-04-2020, 10:24 AM   #17
Dondo Yonderboy
Hmm, just with an aftermarket HU? That’s a bummer. My stock HU has the voice response button and I’m trying to get that on the wheel. Don’t want to replace the HU to get it, tho.
Old 01-04-2020, 12:57 PM   #18
gpvecchi
gpvecchi's Avatar
Yes, I tried, and the resistor values of every key is different, so it's not recognized by the HU. Even going from 2018 to 2017 on BRZ doesn't work. Aftermarket HU have the possibility to map the buttons...
Old 01-08-2020, 09:27 AM   #19
Jedifar
Drives: 2022 Toyota GR86
Sorry not sure why my images didn't upload but qpvechhi is right, to fully utilize every button on the controls you'll need an aftermarket HU as theres no guarantee it'll work with the stock HU.
I have an Atoto A6 and I have mapped every button on it even though the logos don't match (I've got the voice button mapped as the back/cancel button)
For install, simply find some buttons by itself otherwise you'll have to buy the entire wheel as some people don't want to sell separately. I was fortunate enough to find someone in the forums that sold theirs separately. It is a simple plug and play as in disconnect your battery, remove the airbag by unclipping the 3 prongs on the side of the wheel base, and remove the bag. You don't have to completely remove the bag but for safety I recommend you do. Then unscrew the 2 screws on the silver trim and the buttons should just 'pop' out
I am really surprised the 2020 model still has turn-key, I thought they were going to ditch turn key with all 2020 models going forward
Jedifar is offline   Reply With Quote
Old 07-01-2020, 09:41 PM   #20
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
BRZ to 86 Button Swap Success
Just another confirmation that swapping steering wheel controls (non-Nav) from a late model BRZ to a 2017 86 (860 SE) works - with the aforementioned caveats. Mainly, you need an aftermarket HU that allows the buttons to be remapped. Also, the plastic trim in the 860 is black, not silver. This isn't a problem as the button assemblies are easy to remove from the trim. The following link shows how to remove the airbag from the steering wheel but you don't need to disconnect the wiring from the airbag. The switch/trim assembly can be removed over the airbag.
Two things:
1. There are three (not two) clips securing the airbag.
2. The later model vehicles don't have the two access holes on the back side of the steering wheel. Instead, there are two 1.5" square panels that pop out which makes releasing the clips easier.
https://www.ft86club.com/forums/showthread.php?t=28364
LimitedSlip is offline   Reply With Quote
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
My steering wheel is stuck: Cusco steering wheel norcalpb Cosmetic Modification (Interior/Exterior/Lighting) 4 01-01-2017 04:48 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 06:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) -- General Topics 125 04-09-2012 08:46 AM
