Old 01-14-2020, 05:53 PM   #127
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by durtdonthurt View Post
if I should wait to see if they have a new 2020 model that comes out here in the states.
2020 model of Kenwood? I wouldn't wait for it, even 918 is "all the goodies you can think of for Android Auto", as long as you install and wire it correctly; and probably 919 if you have iPhone and really need CarPlay to be wireless.
timurrrr is offline   Reply With Quote
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
durtdonthurt (01-16-2020), Spankopotomous (02-15-2021)
Old 01-18-2020, 03:47 PM   #128
durtdonthurt
Drives: White series.blue / CWP tS
So I noticed the ddx919ws comes with a harness that works with most Toyota head units which I think the BRZ uses... Has anyone installed one of the 919 units and used the provided harness? Wondering if I would need a different harness to use the factory usb ports and backup cam...It comes with a Toyota steering wheel control harness as well...
Thanks!
durtdonthurt is offline   Reply With Quote
Old 01-19-2020, 12:14 AM   #129
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
I installed the DDX919WS in my 2018 BRZ Limited a few months ago.
I couldn't get the factory dual USB to work (the blue & pink plugs under the AUX black box) so I replaced it with the dual unit from Beuler. Works perfectly now, plus it lights up in the same red as the interior lighting.
https://www.ebay.com/itm/BEULER-USBD...-/362568281982
Also, I couldn't get the factory rear view camera to work either. I tried everything, even the PAC Volt 39. So I replaced it with a $40 aftermarket camera from Amazon and now it works perfectly!
I used the custom harness from carboncarsystems.com. I'm not sure if other harnesses from Crutchfield or autoharnesshouse.com would work any better or differently.
BA9092 is offline   Reply With Quote
Old 01-21-2020, 10:10 PM   #130
TheRoops
Drives: 2015 Subaru BRZ Series.Blue
Is this the new US model?
https://www.kenwood.com/usa/car/excelon/dnx996xr/
TheRoops is offline   Reply With Quote
Old 01-23-2020, 10:27 AM   #131
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by TheRoops View Post
That model is only 152mm wide, the DDX91#WS is 200mm wide.
tehShirt is offline   Reply With Quote
Old 01-25-2020, 08:45 PM   #132
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Does FM radio work on these head units as they imports? Debating doing this to my 18' or if I should wait to see if they have a new 2020 model that comes out here in the states.
Thanks!
Fm radio works just fine, as others said.
The only thing that wouldn't work is DVDs. You can wait to see if they release a 2020 for the states, but I doubt it. Why don't they? I have no clue.
FWIW, the reach on the 2019 RHD unit isn't far at all. I don't lean to hit any of the buttons on the right. In fact, the distance is more comfortable for my arm than if they were on the left side. Moreover, if you have steering controls for volume and skip then you may not need to touch the headunit very often.
The headunit is already a capacitive HD display with AppleCarplay and AndroidAuto, and they are bluetooth wireless, so I can't imagine what features they would add for 2020.
It was entirely plug and play with the factory harness, so it was a no brainer to install. I really couldn't be happier with the headunit.
Old 01-30-2020, 11:36 AM   #133
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Are this Kenwood line and the Pioneer AVH the only known 200mm headunits that’ll work seamlessly without the use of an ugly spacer kit?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 01-30-2020, 01:25 PM   #134
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I'm afraid so
The Following User Says Thank You to timurrrr For This Useful Post:
the new guy (01-31-2020)
Old 03-06-2020, 12:21 PM   #135
MarylinPurtill
Drives: Toyota GT86
Kenwood is a good brand but I never used it. I am using Alpine and no doubt, it is the best. Pioneer could also be a reliable option.
MarylinPurtill is offline   Reply With Quote
Old 04-24-2020, 01:43 PM   #136
Meepoau
Meepoau's Avatar
Drives: 2013 Toyota 86
KENWOOD DDX917WS security code
Hi guys, was working on the 86 today and was removing the battery. Now I am getting this code for the KENWOOD unit. I bought the car second hand from a dealer and the car didn’t come with a card within the book of permits and car manual document book either. Asked the dealership and they do not know and check online for the passcode and there is nothing online that works!! It’s crazy that this can happen. The last resort is to give KENWOOD a call but I doubt they will give me a code because I don’t have a receipt of purchase for the head unit. I mean I have a massive receipt for my car but not sure that would be acceptable.
I suppose I am asking, does anyone on here have the code to unlock this head unit or has had this issue in the past so I can seek guidance in just unlock the head unit so I listen to music again?
Kind regards guys!
Meepoau is offline   Reply With Quote
Old 04-24-2020, 01:54 PM   #137
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
"Security code" seems like something the previous owner has set, and I really doubt Kenwood would be able to provide it for you.
I think your options are either
a) somehow ask the previous owner for the code (the dealership might be able to help with that)
or
b) find a way to factory reset the HU (check the owner's manual if it's possible to reset the HU, there might be a button on the back or something)
Old 06-26-2020, 08:29 AM   #138
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Wired my 919 last night & loving it. Daniel at Carbon said he would sell me the harness but stopped responding Wednesday and has gone silent.
For now using it without the camera but loving it!
e30cabrio is offline   Reply With Quote
Old 06-26-2020, 11:30 AM   #139
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Does anyone know which wire to tap for the speed sensor?
I looked at the wire harness and it seems it's pink/green at the ECU but I am not comfortable tapping it there.
Figured it & reverse out.
Houston we have backup camera!
I guess Carbon did me a favor blowing me off, I did 'er myself & saved $.
The Following User Says Thank You to e30cabrio For This Useful Post:
wolffbite (11-04-2020)
Old 06-26-2020, 05:07 PM   #140
gpvecchi
gpvecchi's Avatar
Pin 17 in remote controls connector, if I remember. The one distant from remote control wires.
gpvecchi is offline   Reply With Quote
Search this Thread:
Advanced Search
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 10:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 05:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
