02-15-2015, 06:21 PM | #15 | |
Drives: 2019 Mazda Miata RF
The Following User Says Thank You to Gunman For This Useful Post: | fika84 (02-16-2015) |
02-15-2015, 07:04 PM | #16 |
Drives: scion
The wing alone, with its experimental endplate, at 120kph, makes 201.2lb lift and 49.6lb drag. I have yet to run simulations across different speeds to produce a reliable graph depicting L/D ratio.
The Following User Says Thank You to MRE For This Useful Post: | Gunman (02-15-2015) |
02-15-2015, 07:36 PM | #17 |
Drives: 2014 BRZ - 2004 GLI
And what does this do to the vehicles calculated CD?
The Following User Says Thank You to Createddeleted For This Useful Post: | fika84 (02-16-2015) |
02-15-2015, 07:40 PM | #18 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
Might be useful IF it confirms with the regulations of an actual competition series. However, for the general public, it's probably not worth it.
Looks like the only real "difficulty" is getting the mounting bracket made. nothing a plasma cutter and a sheet of aluminum can't solve though. The wing itself, you can get carbon or aluminum pre-fabbed straight wings anywhere. End plates are as easy as mounting brackets. If you make it, post pics. But I highly doubt there is a market for this... Perhaps you can look of some regulations of actual race series, then market this to the teams there?
'14 BRZ LTD MT DGM
02-15-2015, 07:48 PM | #19 | |
Drives: scion
I have not performed simulations of the wing on the car yet. I don't have the proper 3D model to conduct the experimentation yet.
02-15-2015, 07:49 PM | #20 |
No rice, no life
Drives: 2013 Asphalt FR-S
This car can't get going fast enough to necessitate a wing.
02-15-2015, 08:05 PM | #21 |
The Antiriced
Drives: women wild
How much will it unload the front end? Have you considered what effect your wing will have on the front?
02-15-2015, 08:08 PM | #22 |
Drives: scion
That statement is not true. Aerodynamics affects all speeds. Going beyond an arbitrary speed does not create a binary condition for when a wing functions or not. The efficiency of my wing allows much more noticeable effect in increased turning speeds and reduced braking distance, compared to the competing wings in the market. The biggest factor dictating the downforce goals I've set is the mass of the car. The wing, being shaped and sized the way it is, is a by-product of the performance goals I've set.
The Following User Says Thank You to MRE For This Useful Post: | Tgionet (02-16-2015) |
02-15-2015, 08:50 PM | #23 |
02-15-2015, 08:52 PM | #24 |
100% guaranteed to have people look at you and point!
02-15-2015, 08:55 PM | #25 |
Drives: 2013 Civic Si
Money talks...Bullshit walks...
02-15-2015, 09:33 PM | #26 |
Drives: scion
02-15-2015, 09:36 PM | #27 |
Drives: scion
Not meaningless at all. I've done experimenting on the wing on its own, and the wing on another vehicle. Because of that and the results I got from it, I can confidently say my wing will improve perform better than competitors—even without the more direct evidence of live-testing and CFD with the FRS. The flow dynamics and interaction of the wing from that test can be translated and extrapolated as a starting ground for the mount and wing place you see here now.
02-15-2015, 09:44 PM | #28 |
Similar Threads | ||||
Rear Wing | White64Goat | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-05-2014 11:52 AM |
Sti rear wing? | steveoexige | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-16-2014 11:30 AM |
What rear wing is this? | switchlanez | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-08-2014 08:17 PM |
Wing or no wing? (rear spoiler) | quik1987 | Scion FR-S / Toyota 86 GT86 General Forum | 123 | 12-12-2011 06:11 PM |
