Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-25-2013, 11:45 PM | #29 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
There's a chart around here somewhere...
I'm actually serious. Think I'm probably going to do it. Eventually. And yes, first gear's going to be bananas.
12-02-2013, 04:48 PM | #30 |
Drives: 86 GT
I can confirm that the M22 diff thats in the australian/european is300s fit the 86/frs/brz with no issues
Just got the 4.55 gears installed as well. its a good improvement but may look into 4.7 or 4.88 in the future. so thankyou PantsDants and Jeff Lange for your help on this. |
The Following 3 Users Say Thank You to uncivilised For This Useful Post: |
12-08-2013, 03:05 AM | #31 | |
Drives: GT86
12-12-2013, 01:55 PM | #33 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Anyone know the going rates in SoCal for FD install? (both gear install and removing&reinstalling of pumpkin). Tranny Shop recommendations in the LA/OC area welcome Worse comes to worse and if it really costs that much, I think I would just drop the pumpkin myself and just drive it to the tranny shop so they'd just do the install of the gears (but I like the convenience of them having do it all..only if the price is decent of course). I know the actual gear install would cost a bit and requires special tools/skill; but swapping just the pumpkin itself is pretty easy and should only take an hour (or 2 at the very most if you're taking your sweet time). I swapped a junkyard Infinity(iirc) LSD into my S13 before; and I remember it was easy and fast. |
12-15-2013, 04:48 PM | #34 |
Drives: 86 GT
12-15-2013, 04:56 PM | #35 |
WOW! GREAT post! Saving this for future reference.
12-15-2013, 06:10 PM | #36 | |
Aside from wheels/tires & coilovers, I think a short FD would be my very first modification. I don't think there's any other better engine/drivetrain mod for less than $1k that would yield such a big and noticeable difference/improvement over stock. |
12-15-2013, 06:58 PM | #37 |
Drives: 86 GT
I would recommend it, its a good improvement. I gave the car to my friends to drive without telling them I did this mod and they all noticed the difference.
01-08-2014, 12:53 PM | #38 |
Drives: 2010 MS3
Thanks for the awesome thread. So much valuable stuff in here.
So, just to confirm.. if we can source the rear differential carrier of an IS300, we can basically swap it with our stock rear differential, yes? |
The Following User Says Thank You to JS + BRZ For This Useful Post: | jcw99 (03-06-2016) |
01-09-2014, 03:20 PM | #39 | |
Drives: Scion FR-S A/T, Whiteout
...but JUST to make certain, you're talking about just swapping carriers right? Like drop pumpkin #1 from your car, install pumpkin #2 into car, done? If you're talking about swapping the actual differential out of the carrier, I can't say with 100% certainty that that will work. It SHOULD, considering the IS300 and 86 carriers both contain T2 Torsen differentials, I'm just not 100% on if they bolt up the same internally. |
01-09-2014, 03:42 PM | #40 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
@PantsDants what was your reasoning for using he IS carrier? Was it solely to limit down time? It just seems to me if you were paying a shop to do it, why incur the extra cost of the carrier instead of just buying a ring and pinion for the FRS. The setup time for uninstalling and reinstalling wouldn't be more than an extra day or two. Or did you have another reason for doing so?
01-09-2014, 06:08 PM | #41 | |
01-10-2014, 04:17 PM | #42 | |
But yeah, it also served to limit my time without the car. Considering it took the shop around two weeks to actually get my ring and pinion installed in the IS300 carrier, I think I made the right choice there. Additionally, I sold my FR-S carrier to another member here and made my money back, so it didn't cost me anything extra in the end. |
Similar Threads | ||||
Final Drive Discussion | JimmyMac | Engine, Exhaust, Transmission | 118 | 08-07-2017 10:18 PM |
Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 10:44 AM |
Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
Change FD ratio to 4.56 by changing only pinion | peachch | Engine, Exhaust, Transmission | 1 | 08-31-2013 01:25 PM |
Correcting drive ratio for accurate speed | AlexTheGreek | Engine, Exhaust, Transmission | 25 | 12-05-2012 01:13 AM |
