Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-13-2019, 10:49 AM | #113 | |
Drives: 2017 toyota 86
Mocal Thermostatic Oil Sandwich Plate Service Kit | M-OTSP1-SK92 Options: Thermostat Temperature: 92°C Thermostat Raises it to 197F helped a little bit when i swapped but not much. A 100C or 212F would be perfect if you find one let me know. From my understanding. They all have 10% flow no matter what and at about 30F below full open temp they start to open, so a 180F thermostat at 165F would have approximately 55% flow still. But also the oem oil temp sensor is post cooler, so the deviation from pre and post temps will start to become greater beyond the 150F as your cooler is cooling more and more as the plate opens. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | MotoX16 (11-13-2019) |
11-14-2019, 10:55 AM | #114 | |
Drives: 2017 Subaru BRZ
I went ahead and ordered the Tstat you listed, that combined with blocking off the coolers core should get me pretty close to 100C. Thanks for the help! EDIT: I found a website listing the 95C sandwich plate for sale. Its quite a bit more expensive though as it is the whole plate. https://www.lojkits.com/products/moc...nt=23456645126 Last edited by MotoX16; 11-14-2019 at 11:03 AM. Reason: New link added |
11-14-2019, 11:28 AM | #115 | |
Similar Threads | ||||
Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
You want it, you got it: PERRIN Oil Cooler GB | JoeBoxer | Groupbuys | 96 | 06-16-2013 03:10 PM |
Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-21-2013 11:36 PM |
