12-30-2019, 04:49 PM | #169 | |
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Definitely would give it a shot. |
12-30-2019, 05:59 PM | #170 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
01-25-2020, 08:39 PM | #171 |
Drives: Raven black manual transmission
It looks very nice. So about how much power are you getting out of this yellow brz ??
01-25-2020, 08:43 PM | #172 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
Probably more than your FR-S.
The Following User Says Thank You to KR-S For This Useful Post: | ROFL it's Waffle (01-29-2020) |
01-25-2020, 09:01 PM | #173 | |
Oh no not you.... Idk about power since I haven't dyno'd it.
The Following 2 Users Say Thank You to weederr33 For This Useful Post: | KR-S (01-25-2020), ROFL it's Waffle (01-29-2020) |
01-25-2020, 09:05 PM | #174 |
Sporadic Member
In before this guy tells you what you should put in your car.
01-26-2020, 02:26 PM | #175 |
While changing my oil, I finally installed a fumoto drain valve! I was very hesitant at first as I could not determine the clearance of the valve to the skid plate. But there is roughly a 1/4" of space. And while I do have some scuffs on my plate, they are all from a single extreme moment of evading an object. I look forward to seeing how this does on my next oil change!
01-29-2020, 06:15 AM | #176 |
This drain valve definitely looks like it fits within the skid plate clearance space.. It also looks nicely installed.. Good job.
01-29-2020, 07:33 AM | #177 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
I will say, my first time using it, I forgot to close the valve, so I dumped a quart of new oil into my drain pan before I realized it "man, this car is thirsty..." Also, that plastic piece that "secures" the valve lever, this is a new addition (my Lexus has this too). I never had a problem with the valve "just opening up." I think Fumoto did this just to pacify some of the skeptics. |
01-29-2020, 10:12 AM | #178 | |
I also look forward to draining my oil now! I'll probably get the drain tube before I do it.
03-23-2020, 04:32 PM | #179 |
I did it! I waited a little over a month to get it but it came in this afternoon by surprise. The ACE CS400 ^^
The Following User Says Thank You to weederr33 For This Useful Post: | Elliotw (03-23-2020) |
03-23-2020, 06:05 PM | #180 |
Weight Weenie
Drives: 15 FR-S
Nice. Looking forward to your review
The Following User Says Thank You to new2subaru For This Useful Post: | weederr33 (03-23-2020) |
03-24-2020, 12:11 AM | #181 | |
Drives: 2017 BRZ (Sold), 2023 GR86
Even though I've had some issues with the OP flange bolts coming undone on track (tricky design), my A350 is still my favorite modification on my car. Curious to hear how you like the 400. |
The Following User Says Thank You to mistople For This Useful Post: | weederr33 (03-24-2020) |
03-24-2020, 12:31 AM | #182 | |
I choose the CS400 since it has a little more down low and I daily my car. As well, the cost was a little more justifiable than getting a coated A350 with the sacrifice of a few ponies up top. I should be getting it installed later in the week and then begin data logging with Zach @ CSG. I have something else I'm wanting to install since I'm on lock down thanks to the SARS-Cov-2 virus going around.
Similar Threads | ||||
Weederr's Cosworth Supercharged Raven | weederr33 | Member's Car Journals | 232 | 03-25-2024 10:09 PM |
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 | leoh007 | Audio/Visual, Electronics, Infotainment, NAV | 0 | 05-12-2015 12:14 PM |
10 Series / Series.Blue rear view mirror | 86-ADL | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-16-2014 07:32 PM |
BRZ series.blue/FRS Series 1.0 photos | Johnny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-25-2014 11:23 PM |
