Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-26-2012, 11:11 PM | #29 | ||
Drives: Matte Black STI
Manual tranny cars have no problems. Put it in 6th gear, take the bolt off and in about 10minutes its installed. For auto customers, its a little trickier. You will need to lock down the flex plate. This is very easy using a pry bar in the port on the engine located on the top behind the intake manifold. This may take two people, but its makes it very simple on the FA and FB engines. |
06-27-2012, 06:10 AM | #30 |
Drives: 23 BRZ
What's the recommended torque for that bolt? Loc-tite required?
Also, Kronos mentioned that the FR-S stock pulley is 1 lb heavier than the BRZ. Is that true? |
06-27-2012, 11:11 AM | #31 |
The TQ spec is ft-lbs and then an angle. So you tighten it to 14.8ft-lbs, then 90 degrees more beyond that. It ends up about 90ft-lbs.
Regarding the FR-S pulley being heavier. We have both cars sitting next to each other and looking over both of them, they look exactly the same. The OD, the ID, the thickness and pretty much everything I could measure appears to be the same. I didn't remove the FR-S part, but I would be surprised if it was different. |
06-27-2012, 12:08 PM | #32 |
Drives: no
What size is the bolt?
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2 |
06-27-2012, 01:14 PM | #33 |
Its just like an EJ engine bolt. I think M16, but about 4" long. I can get the exact info if necessary. If is regarding TQ spec, I hate to say, but we always TQ them to "Tight" or 100ft-lbs and never have problems.
07-03-2012, 02:35 PM | #34 |
Driving Coach
Anyone install one of these on their car yet? I want to know if you could tell a difference. I don't have my BRZ yet, but I may go ahead and buy a pulley while they're on sale! I'd like to think that this would help offset drivetrain loss via the increase in rotational mass by putting on 18x8" wheels and tires that may be a little heavier than stock.
07-03-2012, 03:18 PM | #35 |
Drives: 2013 BRZ Limited
In process (literally) of doing my BRZ 6AT. I'll advise accordingly with Pix. Use the Company23 Subaru tool. Should make the job a snap for anyone!
The Following User Says Thank You to xcelir8brz For This Useful Post: | StarsGarrador (07-03-2012) |
07-03-2012, 03:56 PM | #36 | |
Driving Coach
EDIT: Is the tool even necessary for the pulley install on a 6MT? |
07-03-2012, 04:59 PM | #37 |
Gangnam Style Guru
Drives: Suzuki GSXF650, WRB BRZ
I just left my dealership asking a few questions.. Apparently anything besides cosmetics, will void my warranty with Subaru. When I said I thought they have to prove with out a doubt any aftermarket part was the cause they said all Subaru has to do it prove you had that part on. :/ oh well, my Perrin pulley and HKS exhaust are still going on -.-
http://www.ft86club.com/forums/showthread.php?t=10270 <---- My Build Log
07-03-2012, 05:10 PM | #38 |
Installed. Company23 tool helped greatly. $50 shipped directly from web site. Took a little more than 30 minutes on the 6AT because I took pictures. Was 'VERY' easy in my opinion.
Top notch quality Perrin! Here's the pix: |
The Following 2 Users Say Thank You to xcelir8brz For This Useful Post: | MarkRacerX (07-05-2012), PERRIN_Jeff (07-04-2012) |
07-03-2012, 05:12 PM | #40 |
Now for the test drive...
07-03-2012, 05:13 PM | #41 |
07-03-2012, 05:21 PM | #42 | |
Similar Threads | ||||
Perrin Crank Pullies now available @ Kronos! | KronosPerformance | Engine, Exhaust, Bolt-Ons | 39 | 08-30-2012 12:53 PM |
