09-21-2012, 02:19 AM | #15 |
Drives: Frs,civic
Nice.
09-21-2012, 02:29 AM | #16 | |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
http://www.v-leds.com/Vehicle-Specif...-p9809064.html They work perfect. Kinda makes them look like fog lights while driving, but they still blink amber.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
09-21-2012, 12:35 PM | #17 |
1337
Drives: 2013 BRZ WRB S/C
Is there any way to wire it so they blink at the same time?
09-22-2012, 08:50 PM | #18 |
Drives: 2013 BRZ Limited
Mine blink at same time.
10-05-2012, 01:28 AM | #19 |
Drives: scion fr-s
i just ordered a pair of nokya hyper yellow bulbs to replace the turn signals to give it a faux fog light look. i'll see how that goes when they get in.
10-05-2012, 02:00 AM | #20 |
Now w/ over 400 womprats!
Drives: BRZ LZR
- The Ancient BRZ Sacrament by Zaku |
03-29-2013, 10:22 PM | #21 |
Drives: 2013 SWP Limited BRZ - Manual
Does anybody think this will work with LEDs in the side markers? I know people had issues with rapid blinking when moving to LED turn signals. Am I right to believe that this would not be the case if the you piggyback the LED side marker off of an incandescent turn signal? Is there something I am missing in relation to line voltages/currents on LED bulbs that will cause problems?
04-01-2013, 09:20 AM | #22 |
No info?
The Following User Says Thank You to cmspooner For This Useful Post: | Kids Heart (10-17-2013) |
04-04-2013, 12:42 AM | #23 |
Drives: 2013 Scion FRS whiteout
I'm not an light expert but from what I read, you can use led but it cause hyper flashing. Last I check which is about 4 month ago, a few vendors on here were selling led bulbs with built in relays(?) to prevent the bulb from hyper flashing.
I have yet to change mine out for led so I can't help you there. |
04-05-2013, 12:41 PM | #24 |
If you get hyper blinking just replace the turn signal flasher relay that has the resistance built in. This will prevent any hyper blinking and only requires one thing to be installed.
Ill be doing this mod today. Thanks for the DIY. |
04-06-2013, 01:29 PM | #26 |
They should be off if you are only hooking up to the blink circuit.
Sent from my SCH-I535 using Tapatalk 2 |
04-06-2013, 06:11 PM | #27 |
Drives: scion fr-s
04-06-2013, 06:54 PM | #28 |
Not sure. Grab a volt meter and see wuich one it is and let us know.
Similar Threads | ||||
clear side marker part number | NOBROWS | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 09-11-2017 09:12 PM |
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 | nigel-jdmparts | Exterior Parts - The Rest | 524 | 02-28-2016 10:24 AM |
Converting side marker to turn signals | ayau | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 12-13-2015 03:41 PM |
does your car come with side door marker light? | excited86 | CANADA | 12 | 08-02-2012 06:07 PM |
Raven blacked out side marker before and after | Roadstercycle | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-24-2012 10:52 PM |
