Old 07-22-2019, 09:58 PM   #1
SakeBomb Garage
FT86Club Official Vendor
Drives: BRZ/FRS
SakeBomb Garage: WILWOOD TRACK-DAY BRAKE SYSTEM
Introducing the NEW SakeBomb Garage Wilwood Track Day Kit for the BRZ/FT86!
Building on the success of our similar brake kits for our SCCA and NASA winning S2000 and RX7's. We produced this brake kit with the intention of bring race engineering to the broader motorsports market with an affordable but potent brake solution. We call this our endurance Track-Day brake kit! We have designed an affordable, light weight, and heavy duty brake system, which has great thermal capacity with extremely thick (20mm) pads, making it both a great thermal barrier between the caliper and rotor (preventing boiling fluid) while also giving a great value with so much pad to go through vs the other options out there. A true racing caliper, directional curved vanes in an affordable package with wide pad selection make this BBK a no brainier on the track or street!
Our new Wilwood Track-Day Brake System, for the BRZ is available with introductory pricing for a limited time! We have put together a competition inspired brake system, utilizing lightweight, high-efficiency components. We're sure you'll agree this "Light-Track" BBK a fantastic option for high performance braking, at fantastic price points.
Ultra-lightweight Forged Wilwood Calipers with stainless steel pistons and high temp seals, paired with your choice of our light-track two-piece SBG 325x32mm Premium Rotors (32 directional curved vane) This kit utilizes the same quick-change 20mm thick pads as our AP Racing Competition Kit, and the same rotor size, providing you with amazing bang for buck.
The benefits of the Wilwood caliper are quite clear, with almost 3lbs of unsprung weight saved at each caliper when compared to other big brake kits, while still retaining excellent caliper stiffness. Put mass into what matters... the rotor, not the caliper
This is the perfect package for customers looking for the maximum bang for their buck when it comes to braking performance. These brake calipers utilize one of the most common racing pad shapes, and accommodate a full 20mm thick pad. Not only does this provide additional thermal insulation for the calipers, but with a massive 50mm of useable anulus, wear on the face of the rotors, as well as the pads, is greatly reduced compared to smaller profile brake kits. This results in much more robust lifespan for both the rotors and brake pads, and maximizes your dollar per braking compound/use.
Our Package Includes:
Wilwood Forged Superlight Calipers (hard anodized or powdercoat options available)
SBG 6061 Billet Caliper Mounting Brackets
SBG 325x32mm Solid Mount Premium Brake Rotors [B]
*]SBG Designed Race Grade Aluminum Rotor Hats
SBG DOT Approved Stainless Steel Brake Lines with dirt/abrasion sleeves
Full Pictorial Installation Guide
This kit has everything you need to overhaul your aging, undersized stock brake system. From stock cars to high horsepower builds, this brake setup is a fantastic match with outstanding braking performance that will not break the bank.
Wilwood Forged Superlight Calipers:
Ultra-Lightweight Forged Aluminum Construction
Durable Hard Anodized Finish (optional powdercoat available)
Stainless Steel 4 Piston Design
20mm Thick Brake Pad for Caliper Heat Transfer
Thick Pads Provide Extremely Long Life and Reduce Frequency of Replacement (cost effective for track use)
DOT Rated SakeBomb Stainless Lines included!
SBG Brake Rotor Features:
Endurance Sized 325mm x 32mm High-Performance Rotor
Light-Weight 2-piece Brake Hats
SBG Rotors feature 32 Directional Curved Vanes
Proprietary High Temperature Alloy Rings
SBG Slot Pattern engineered to increase pad bite,
Race Grade Hard Anodized Aluminum Rotor Hats
See Product page for more details!
Click here.
SakeBomb Garage
SakeBomb Garage is offline
Old 07-22-2019, 10:36 PM   #2
toast
Drives: 14 BSP Edelbrock BRZ
In to see how long it takes a moderator to close this...
toast is offline
SakeBomb Garage: Track Day BBK Kit for the BRZ/FT86 SakeBomb Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-23-2019 09:20 PM
SakeBomb Garage: Track Day BBK Kit for the BRZ/FT86 SakeBomb Garage Brakes, Suspension, Chassis 6 05-23-2019 09:19 PM
Wilwood Big Brake Kit mitim3 Brakes, Suspension, Chassis 10 11-28-2016 04:45 PM
Wilwood 6/4 Big Brake Kit phatpanda Brakes, Suspension, Chassis 2 03-12-2014 02:44 AM
