Old 03-04-2014, 04:41 PM   #99
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by whitefrs View Post
Color wont match tho
I love boost!!!!!!
It's close enough and if it's too "off" to me I have both coats of swp mixed and I can have it repainted for free
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-04-2014, 04:42 PM   #100
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
sounds legit
Old 03-04-2014, 09:54 PM   #101
Lonewolf
Lonewolf's Avatar
Drives: Moped
Come on vendors...this is the last good, cheap aesthetic mod that isn't available that could really sell well...
Old 03-06-2014, 11:32 AM   #102
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Received mine today
Omar GC
Instagram: 2jzus
Old 03-06-2014, 12:28 PM   #103
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Originally Posted by markmatley View Post
This is true! Its much easier to install the FRS antenna electronic module into the G37 case.
So if you take apart the FRS antenna, you get:
If you try to pull the antenna wire after you unscrew the circuit board, you'll notice that a copper sheath (the ground of the antenna coax) is soldered directly to the metal frame of the antenna base: (the metal tab with the purple or red ink is the tab you need to desolder off the board before you can have access to desolder the ground from the antenna base)
Heres a front view after desoldering the tab:
Once this tab is gone, you can desolder the ground copper sheath off the antenna base, pull back prongs that hold the antenna wire to the base, and slip the wiring through.
Next take apart the G37 antenna. The hardest part about disassembly is getting the metal base off the painted shell. I used a small plastic tab remover and worked my way around it prying from the pointed end of the antenna. take your time or you might snap a tab (which I did) and then you'll have to superglue the bad boy back to keep the antenna assembly from rattling.
Heres what it looks like disassembled:
Finally you can save or chuck the G37 antenna module, and then place the FRS one into the slot but you have to screw it down a different angle. But it fits!
Reassemble and fire up the radio! Enjoy!
Functionality is perfect once you ground the outer copper sheath to the G37 metallic frame.
Do you mind rehosting the images?
Omar GC
Instagram: 2jzus
Old 03-06-2014, 01:09 PM   #104
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
Received mine today
Mine too, but it's at home and I'm at work
How's the white compared to the car?
fatherfork is offline   Reply With Quote
Old 03-06-2014, 02:04 PM   #105
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
My cars not completely clean, however... There's more metallic flake on the g37 antenna cover and definitely more reflective with light because of this... So it's it's a brighter white to sum it all up, not extremely noticeable.
Omar GC
Instagram: 2jzus
Old 03-06-2014, 02:08 PM   #106
fatherfork
Fears Hiccups
fatherfork's Avatar
Oh wow, I thought it wasn't a metallic white. I'm happy to hear it is. Should match more closely than flat white.
Old 03-06-2014, 02:11 PM   #107
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
It's the oem pearl/metallic from Infiniti that I actually prefer over swp lol. I had a g37 coupe in it before.
Omar GC
Instagram: 2jzus
The Following User Says Thank You to OmarGC For This Useful Post:
fatherfork (03-06-2014)
Old 03-07-2014, 04:53 PM   #108
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Just finished my install... Question to the guys that have there's installed already...
Do you/did you have any gap between the front of the antenna and the roof? I'm worried about water coming past the front section of the seal.
Omar GC
Instagram: 2jzus
Old 03-07-2014, 09:55 PM   #109
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Sorry Omar about the late reply. I see you already installed it, but does anyone else need me to re-up them?
As for me there are no seal issues. If you hand tightened the antenna nut you will get leakage. If anything you can smear some rvt grease or some other high temp grease on in the inside. Hope that helps.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 03-08-2014, 02:11 AM   #110
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
The front of my seal definitely isn't seated flush to the chassis... Clueless as to why.
Omar GC
Instagram: 2jzus
Old 03-08-2014, 09:36 PM   #111
fatherfork
Fears Hiccups
fatherfork's Avatar
I installed mine today too. No issues with gap, but I tightened it down pretty good to be sure there was no gap. Man, this thing looks good. The white is only slightly more sparkly and it's unnoticeably different.
The Following 3 Users Say Thank You to fatherfork For This Useful Post:
DAEMANO (04-09-2014), Lonewolf (03-09-2014), racecat (03-09-2014)
Old 03-31-2014, 02:24 AM   #112
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Yup looks good. Damnit why no ones made these yet specifically for our cars... (mind blown)
The Following 2 Users Say Thank You to OICU812 For This Useful Post:
Lonewolf (04-02-2014), Travisty75 (03-31-2014)
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 12:44 PM
Flat black BRZ BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 06-27-2012 03:23 PM
Flat Black BRZ Toods BRZ First-Gen (2012+) -- General Topics 4 06-20-2012 12:25 AM
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! xcelir8brz Electronics | Audio | NAV | Infotainment 2 06-04-2012 11:44 PM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 07:46 PM
