Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine Swaps
Old 08-25-2017, 05:24 PM   #15
Shit Luck
Drives: red frs
I have power out of the clutch switch....
I have checked everything I can think of.
Shit Luck is offline   Reply With Quote
Old 08-26-2017, 03:58 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Shit Luck View Post
I am not sure what you are asking.
The entire body harness is bone stock, so the factory relays and stuff.
You need to connect that white/blue wire directly to starter to trigger it, that's what Dustin is saying. That means you need to de-pin/splice that white blue cable and run it directly to your starter (please correct me if wrong @DustinS)
What standalone are you using?
Old 08-28-2017, 06:34 PM   #17
wooly35
Drives: 2014 Scion FR-S LS3
Splice into the white/blue wire.. worked for me.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Sportsguy83 (08-28-2017)
Old 08-28-2017, 08:21 PM   #18
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I messaged him yesterday. ECM wasn't sending signal through. By-Passed the ECM and it cranked over.
I'm interested in what is causing the ECM not to pass the signal. I didn't have to touch mine at all and it worked. Glad he it it though.
Old 08-28-2017, 10:22 PM   #19
kurty85
Drives: 2014 FRS LS Swap
Request how you bypassed the ecm? Been working for many days and cannot figure this out.
kurty85 is offline   Reply With Quote
Old 11-02-2017, 11:14 PM   #20
Merc
Drives: Subaru brz 2013 LS1 swap
I'm going to be starting an ls 1 swap this month. The car was originally an automatic (another reason for the swap). Going to a manual T56. Will I need to switch to a manual ecu?
Merc is offline   Reply With Quote
Old 11-03-2017, 02:32 PM   #21
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
I got my starter working simply by using a jumper wire in the fuse box. Really easy solution, no splicing required. No safety switch though, turn the key and the starter cranks regardless of ECU or clutch state.
If anyone wants to know about this solution I can post a photo, I did it two years ago so I can't remember which ones I jumped without looking at it.
Basically you just bypass the relay that the ECU uses (pull it out and jump two pins) so the key switch is directly connected to the starter.
2015 Scion FRS w/ Turbo 6.2L V8 & 7 Speed
wutsaiu is offline   Reply With Quote
Old 11-03-2017, 05:19 PM   #22
Merc
Yes please sir, I'm hoping this should work for an auto ecu as well.
Old 11-04-2017, 06:31 PM   #23
wutsaiu
wutsaiu's Avatar
Old 11-05-2017, 01:57 AM   #24
Merc
Perfect picture! May the car gods bless you with a never ending tank of gas.
The Following User Says Thank You to Merc For This Useful Post:
wutsaiu (11-05-2017)
Old 11-19-2019, 04:02 PM   #25
zakman16
Drives: 2013 subaru brz
can someone please explain how to do this im having this issue with a stock fa20 in a brz?
zakman16 is offline   Reply With Quote
Old 11-20-2019, 10:29 AM   #26
wparsons
wparsons's Avatar
Your issue won't be anything like the original post... I would start a new topic, not in the engine swap section.
flickr
Old 11-20-2019, 10:33 AM   #27
He who smelt it...
Drives: 14 FRS Hot Lava
He already did.
https://www.ft86club.com/forums/show...00#post3275400
wparsons (11-20-2019)
Starter swap? Wil Engine, Exhaust, Transmission 1 07-27-2016 07:50 AM
Pulled the trigger... Stewie Subaru BRZ General Forum 1 01-01-2015 03:16 AM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 07:12 PM
6 MT Swap, Complete: Transmission,Starter, Flywheel, Clutch, Driveshaft, Pedals, Hydr ecda Transmission and Driveline 2 01-30-2014 11:45 PM
Just pulled the trigger Trobinson CANADA 5 04-08-2013 10:48 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
