Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
04-24-2019, 11:13 PM | #1 |
Drives: 2013 MT Asphalt FRS
Blinkers not working
My blinkers only work when my headlights are off and when i put the left turn blinker, both front blinkers go on. At night when my headlights are on, my left turn blinker in the back stays on! Emergency lights only work when my headlights are off and when they blink so does my license plate light! lmao.
Any one know what might be the problem? |
04-25-2019, 12:15 AM | #2 |
Tell us about any lighting modifications or repairs that have been done prior to the lights acting up.
Have you checked all the appropriate fuses? humfrz |
04-25-2019, 12:27 AM | #3 | |
Electric modifications- OLM HEADLIGHT LOW BEAM 35W LED trunk lights I noticed the blinkers started acting up weeks after when I installed my aftermarket steering wheel. |
04-25-2019, 12:28 AM | #4 |
[insert cool phrase here]
Drives: BRZ Premium
Simple and quick fix is put new bulbs in.
If that does it, problem solved. If not, set car on fire, buy a new Civic.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
04-25-2019, 12:45 AM | #5 | |
First off, here is how you can check the fuses: [ame]https://www.youtube.com/watch?v=PF5G4llnvQs[/ame] There are two fuse boxes; one under the dash and a larger one under the hood. The one under the hood has a fuse puller in it. The owners manual shows which fuse controls which circuit. As the old civic salesman, @Mr.ac ,up above, pointed out, it could be one or more bad bulbs. Or it could be a short in the wiring or a bad ground. After checking the fuses, I would suggest you go back the last piece of lighting you messed with and check your work. If your car is under warranty, a nice dealer may "fix" it for you. If someone else did the electrical work, I suggest you take the car back to them and ask them to fix it. humfrz |
04-25-2019, 12:59 AM | #6 |
ProCrastinationConsultant
I would reinspect the work that was done with the steering wheel. My money is on something getting buggered with that alteration.
I would expect all the fuses to be fine, though always inspect them anyways, because they're easier to fix.
04-25-2019, 01:01 AM | #7 | |
And the dealer is likely not going to do anything once they see that aftermarket wheel
The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (04-25-2019) |
Similar Threads | ||||
DIY side marker blinkers | boonFRS | DIY (Do-It-Yourself) Guides | 112 | 06-08-2020 01:45 AM |
Any clear BRZ side marker / blinkers that don't leak? | Kauf | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 06-05-2016 05:35 PM |
LED side markers cause dim blinkers | rileymcmuffins | Issues | Warranty | Recalls / TSB | 0 | 07-28-2015 11:53 PM |
I just got these Smoked Taillights on Ebay! Blinkers All Messed Up! HELP! | HueyLooie | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-11-2015 09:53 PM |
black housing blinkers | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 09-02-2012 04:07 AM |
