07-21-2016, 03:12 PM | #99 |
Drives:
07-22-2016, 08:38 PM | #100 |
I'll keep that in mind when the time comes. Where are you located? You should add that info to your profile on the left.
07-22-2016, 08:47 PM | #101 |
Drives:
The Following User Says Thank You to 08stiguy For This Useful Post: | gravitylover (07-23-2016) |
08-19-2016, 01:57 AM | #102 |
Drives: Asphalt
Pro tip: Mark the reverse lockout plate before removal so that you don't have to play a guessing game once you put it back together. It's slotted.
08-19-2016, 09:39 PM | #103 | |
Drives: 2014 BRZ Limited [6MT/SWP]
Also curious about that rubber boot that covers the bottom of the shifter where the cotter pin is... exactly how important is this piece? lol
09-21-2016, 09:56 AM | #104 |
Drives: 2013 Scion FR-S Firestorm Red
Just installed an ACT 4 puck clutch due to a worn throw out bearing.. I followed these steps and install to a day! Thanks so much.. Only problem I have is now I have a CEL (maybe coincidence) and it's for a bad crankshaft position sensor.. I don't remember removing this or doing anything with it.. I don't even know where the sensor is but I am wondering if I have to pull the trans again?
Sent from my Nexus 6P using Tapatalk |
10-23-2016, 02:20 AM | #105 |
Drives: 2015 Subaru BRZ
I'm wrapping up the install, but I'm having issues with the shifter. It doesn't want to go into gear. The only direction it will move is to the right as if its in neutral but wont move to the left. Also it seems like it is only going into 3rd and 5th but its a very short throw. Any idea on what could be the issue?
11-09-2016, 03:23 PM | #106 | |
Drives: 2016 Halo FRS
11-16-2016, 06:15 PM | #108 |
Last Starfighter
Drives: 2016 FR-S Series 2.0
Thank you for putting together this howto, it helped out immensely with the install. I've done lots of little things but this is the first time I've attempted a clutch swap. Some of my notes.
I didn't remove the interior and decided to undo the three pins from the underside of the shifter linkage instead. It was no big deal and pretty easy to do. The upper portion of the linkage does hang by the boot and may be something you want to watch out for if you go this route. Subaru left out my retaining pin on my shift linkage from the factory and I had to wait several days for a replacement part. Seems like something pretty major to leave out. There isn't much holding the linkage together without it. Subaru cross thread my overpipe bolt from the factory and it was a %#!@# to get off. This seems like a common problem. I just forced it back on with anti-seize and will be replacing the entire exhaust soon anyway. It would help out quite a bit if the first post could be edited to have the torque values in line with the parts. I had a hard time translating all the text to which bolt or nut it was referring to. The starter motor housing does not align perfectly with the bellhousing. I didn't notice this removing it but was very odd when I put it back. Probably a generic part fit I guess? The trick for getting the trans back in is the engine tilt. Read this thread and LISTEN to the advice. Playing around with the lift on the engine made the trans slide in without any issue. Put your mtec springs in BEFORE you put your transmission back in your car (duh?) Don't smack yourself in the face trying to torque your drivetrain back together, it hurts. Wear gloves, cutting up your hands hurts and there is an absorbent number of sharp edges on this car. If you decide to fill the diff at the same time you are changing your trans oil you may want to get a pump. It's a ^@#$!@# to get enough of a bottle into the diff from just the bottle mechanism itself. I spent two full days on this going slow and learning. What I decided to accomplish with this: ACT XT Street Clutch "Normal" streetlite flywheel (SB7-XTSS) Velox Carbon Driveshaft TRD Short Shifter MTEC Springs I'm happy with the setup so far. The pedal feel is definitely firmer but not annoyingly so. I haven't spent a lot of time in stop and go traffic but IMO it is not too firm. There is very little, to no noise from the flywheel (it is a streetlite afterall) or other discernible noise that I've detected so far (30 miles). Taking off from a dead stop is different from stock, obviously, but I didn't find it difficult to adjust to. |
The Following 4 Users Say Thank You to djwishbone For This Useful Post: |
11-27-2016, 07:34 AM | #109 |
Drives: 2013 BRZ Premium MT
Torque values.
I just went through the process last weekend (took 2 full days by myself), so, in case it helps anyone...
All values are from 2013 BRZ service manual. * Under Cover (front-section -- aluminum). * 8x 12mm bolts 30 Nm (22.1 ft-lb)* Under Cover (mid-section). * 7x 10mm bolts 7.5 Nm (5.5 ft-lb)* Exhaust Pipe Assembly (FRONT). * To the exhaust manifold, toward the engine. * 2x nuts 42.5 Nm (31.3 ft-lb) * To the exhaust pipe bracket attached to the bottom rear of the transmission mount, through a V-shaped attachment on the exhaust pipe. * 1x nut 50 Nm (36.9 ft-lb) * To the rear exhaust, toward the muffler. * Propeller Shaft.* 2x nuts+springs+bolts 18 Nm (13.3 ft-lb) * Mid-section mount to the chassis. * 2x bolts 52 Nm (38.4 ft-lb) * Mating to the differential. * Manual Transmission Oil.* 4x bolts+washers+nuts 74 Nm (54.6 ft-lb) * Filler Plug & Drain Plug 37 Nm (27.3 ft-lb)* Shifter Lever Assembly. * Adjustable Stopper Plate to guide 1st & 2nd gear selections, and to block reverse. * 4x 10mm bolts 7.5 Nm (5.5 ft-lb) * Main Plate (over the big rubber boot) * 4x 12mm bolts 18 Nm (13.3 ft-lb) * The interior trims are screwed over plastic components, so just use a screwdriver and don't over do it.* Starter. * Ground cable. * 1x bolt 14 Nm (10.3 ft-lb) ***this disagrees with the 13 Nm value from the transmission section*** * Electrical connections to the magnet starter switch assembly. * 7.5 Nm (5.5 ft-lb) * Starter is attached to the engine block, through the transmission using 2x bolts. See transmission to the engine below.* Manual Transmission. * Shifter retainer connection to the chassis. The upper rear most part of the transmission, right under the shifter assembly. * 2x bolts 18 Nm (13.3 ft-lb) * Exhaust pipe bracket to the transmission. * 2x nuts 23 Nm (17 ft-lb) * Rear mounting insulator (black piece) to the transmission. * 4x bolts 40 Nm (29.5 ft-lb) * Rear mounting member to the mounting insulator above. * 2x nuts+washers 55 Nm (40.6 ft-lb) * Rear mounting member to the chassis. * 4x bolts 65 Nm (47.9 ft-lb) * Clutch slave cylinder. * 2x bolts 37 Nm (27.3 ft-lb) * Ground cable. * 1x bolt 13 Nm (9.6 ft-lb) ***Starter section says 14 Nm instead*** * Transmission to the engine. * Clutch.* 6x bolts 50 Nm (36.9 ft-lb)* Includes the two that will hold the starter.* 2x nuts 50 Nm (36.9 ft-lb) * Release fork support (if replacing with Velox Billet or equivalent). * 1x release fork support thingy 16 Nm (11.8 ft-lb) * Clutch cover. * Flywheel.* 6x bolts 16 Nm (11.8 ft-lb) * 8x bolts 85 Nm (62.7 ft-lb) Last edited by catsspat; 11-27-2016 at 07:43 AM. Reason: Fixed indentation. |
The Following 9 Users Say Thank You to catsspat For This Useful Post: | Asian (04-01-2018), BigFatFlip (11-27-2016), H1C (10-27-2018), pgranberg11 (11-28-2016), sly (01-08-2020), smg1138 (04-05-2017), ssyed (05-18-2017), strat61caster (03-26-2019), SuperTom (04-22-2020) |
04-05-2017, 02:48 PM | #110 |
Drives: 2013 Raven FR-S
I'm going to be replacing my clutch with the Exedy OEM unit tomorrow. Just to be clear, it is possible to do this without removing the shifter, right? I'll be using a lift, so would rather do everything from under the car if at all possible.
04-05-2017, 04:35 PM | #111 |
Last Starfighter
Yup. Completely possible and easy to do.
Sent from my SM-G930T using Tapatalk |
The Following User Says Thank You to djwishbone For This Useful Post: | smg1138 (04-05-2017) |
05-10-2017, 01:26 PM | #112 |
Does this have to be done on flat floor?? My parking space is slightly sloped to the side. Maybe 3 to 5 degree slope. I would appreciate for any advice.
Similar Threads | ||||
Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
Chase Bays Clutch Line, Full Replacement | Chase Bays | Transmission and Driveline | 1 | 02-11-2013 02:57 PM |
Clutch/flywheel replacement? | bucket | BRZ First-Gen (2012+) -- General Topics | 1 | 11-19-2012 12:25 PM |
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
