10-15-2014, 12:35 PM | #253 | |
Drives: 16 CBS WRX Limited
10-15-2014, 12:57 PM | #254 |
10-15-2014, 02:26 PM | #255 | |
Drives: 2013 FRS Whiteout
Coolant Disappearing
Save yourself the headache it will fluctuate between low and full. I had my car pressure checked and double checked at the dealer, if it goes below low then have it checked if not forget it!! It's like the idle dip and the crickets!! There's no fixing it!! I completely understand it shouldn't be at low, that means it's low duh but this car functions that way. BTW- not interested in starting a war but for the sake of others later on reading this as a guide. Check coolant when cold, when hot the level may be over the full mark.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
The Following User Says Thank You to yomny For This Useful Post: | AznBRZer (10-15-2014) |
10-15-2014, 02:27 PM | #256 | |
The waterproof tape is Teflon tape, used in plumbing.
10-16-2014, 04:23 PM | #258 |
10-16-2014, 06:28 PM | #259 |
Drives: 86
10-16-2014, 06:50 PM | #260 | ||
I love peanut butter
Drives: 2013 SWP BRZ Limited
10-16-2014, 07:16 PM | #261 | |
I'll probably just refill it and send my oil in for lab results. If it doesn't drop or any trace of coolant in the oil then i'll stay away from the dealer. |
10-17-2014, 09:38 AM | #262 |
Drives: BRZ and NA
10-17-2014, 11:20 AM | #263 | |
In any case I don't think I've seen anyone with proof that the coolant is leaking out in a dangerous way, a top off every couple of months isn't the end of the world, you should be checking it roughly monthly anyway. |
10-17-2014, 11:59 AM | #264 |
Drives: Asphalt Scion FR-S
If you seal the area around the hose to tank interface, are you also sealing the breather hole at the top of the tank?
10-17-2014, 12:03 PM | #265 |
10-17-2014, 12:36 PM | #266 |
Similar Threads | ||||
FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 06:34 AM |
Coolant Question | boredom.is.me | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-15-2013 07:50 PM |
Engine Coolant? | L3P47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-13-2013 11:33 PM |
Alright to use 5-6 old coolant? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-11-2013 08:47 PM |
Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
