11-08-2017, 04:06 PM | #211 | |
Drives: FRS
My thoughts anyways, I'm not an expert, just a hobbyist
11-14-2017, 11:52 AM | #212 | |
Drives: Brz
The Following User Says Thank You to TOLM For This Useful Post: | Chimera (11-14-2017) |
01-10-2018, 12:07 PM | #213 |
Drives: 2017 BRZ Premium
Great writeups, Already installed my infinity components in the IP/Doors, Will be wiring my Amp tonight for the sub (Hifonics Brutus & Kicker L7(8")) never had to deal with high level inputs before so all this info was great for tapping in to the OE amp. Ill be replacing the OE amp/headunit this summer sometime
01-18-2018, 08:08 PM | #214 |
Drives: Burz
Thank you guys for the help.
First harness I bought I destroyed since the push pins mostly decided to self destruct. Second harness (only $4) I took my time and it went great. Here is my harness mostly completed |
The Following User Says Thank You to daskaman For This Useful Post: | rixter145 (05-23-2021) |
03-21-2018, 04:36 PM | #215 |
Drives: 2017 86
If i want to retain the stock amp and add a lc2i for a sub out, straight through with 3/9 and 4/10 T offs to the lc2i (plus remote, 12v) the best option? full signal? a few different methods in this thread. i have both the male/female harness adapters ready, just need to solder it up.
03-21-2018, 06:05 PM | #216 | |
Drives: FRS
I think 3/9 and 4/10 would T so you get stereo (L+R) summed into the LC2i (it has 2 channels in) 3/9 and 4/10 are full signal for left and right sounds like you have a good idea of whats going on
03-22-2018, 10:32 PM | #217 |
Drives: 2017 86
Looking at the harness adapters i got, i'm not confident i know which are 3/9 and 4/10. I haven't repined them.
from the back of the female plug, 4 pin row on top, 3/9 is pink / blue(looped from 8) and 4/10 would be yellow / orange+white? does anyone have a picture of the amp inputs/harness labeled for reference? i'll skim this post again and see if i can find it myself. Also, which are the power/remote? 7 / 8? edit: found this, looks to be the factory male connector (so reversed to the above) for the amp Last edited by Ellis86; 03-22-2018 at 10:57 PM. |
03-23-2018, 10:18 AM | #218 | |
Drives: FRS
post #1 has the pinmap with mages. But on your image you have it correct.
08-23-2020, 11:51 PM | #219 |
Drives: Red FRS
Has anyone figured out how to eliminate the static from the KTP-445U ?
08-24-2020, 01:11 PM | #220 |
Drives: 2014 BRZ
03-23-2021, 07:35 PM | #221 |
Drives: 2020 BRZ LIM/SP
05-23-2021, 10:20 PM | #222 |
Sleep Chomper
Thanks for all the info shared so far, have a few questions since I'm quite an audio noob:
My goal is to have a better soundstage while keeping weight gain to minimum. I already have an aftermarket head unit (an android headunit) so there's already good gains on my tweeters and rear speakers. I am looking at class d amps to give more oompf to the stock stereo speakers. So far I am looking at the JBL Stage A 6004 amp which is 4 channel. Will be using the metra harnesses for less wire cutting For a 4 channel amp, can I use 2 channels for the front door speakers and bridge the remaining 2 channels for a subwoofer later? If not, is it better to just get a 2 channel amp since I might need to get another amp with the subwoofer? |
05-23-2021, 11:43 PM | #223 |
ProCrastinationConsultant
first, i would not recommend using the oem amp wiring for that amp. definitely run your own new line off the battery to power it.
as far as that amp, i don't see any immediate documentation on jbl's site indicating it can be bridged, so it most likely can't. meaning that you could run a sub off it, but it will need to use only 1 channel, and won't get any more than 60w, which is pretty weak for a sub. the 3 options are really, use that amp, because i assume you've already got it, and let the chips fall where they lie. get a different bridgeable 4-channel amp and run as you'd like in the first place. get a 2 channel amp, and setup oversized power wiring with fused splitters and everything to eventually add the sub amp later.
The Following User Says Thank You to soundman98 For This Useful Post: | rixter145 (05-24-2021) |
05-24-2021, 12:10 AM | #224 |
Master Collaborator
You might be interested in the D4S JP23⁴. It's a four channel amp with a lot of power and it also has high pass, low pass, all pass and band pass filtering capabilities. The band pass filter would come in handy in these audio systems. Here's a review from Williston Audio Labs
If I didn't already have the amps that I'm installing in my system, I might have chosen this amp due to its band pass filter. You can run it in 4-channel, 3-channel or 2-channel mode. |
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | rixter145 (05-24-2021), soundman98 (05-24-2021) |
Similar Threads | ||||
Wideband LC-1 wiring. | MattF | Forced Induction | 9 | 07-09-2013 09:33 AM |
Wiring a sub in a BRZ | Shizuma | Electronics | Audio | NAV | Infotainment | 22 | 06-08-2013 01:02 PM |
So is there a DIY yet for BRZ headlight wiring for the FR-S? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-25-2012 09:24 PM |
x940bt wiring help | encity5 | Electronics | Audio | NAV | Infotainment | 10 | 08-31-2012 04:08 PM |
Is foglight wiring in the car? | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-26-2012 11:54 PM |
