Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
11-24-2011, 03:30 PM | #1 |
Drives: MR2
Aftermarket battery
One of my first mods to this car will be a lightweight battery. I have had good luck with Odyssey batteries in the past, but I haven't bought one in several years. I'm curious what other lightweight batteries people have used that are a good combination of weight savings, reliability, and reasonable cost.
11-24-2011, 03:53 PM | #2 |
Softparker
Drives: 2002 Mazda Miata
Brailles are pretty light. I've never had a good battery experience from units I purchased, though the original Panasonic in my Miata lasted 8 years in Arizona heat. What if... the stocker's decent?
11-24-2011, 03:56 PM | #3 |
Drives: MR2
That would be great. Worth keeping for a while anyway.
I've seen Brailles in several Lotus.
11-24-2011, 04:30 PM | #4 |
2 wheel member
Drives: JZA80, 997.1, Taco
The Brailles are overpriced. You can get the Deka/Magnapower batteries for a lot less and are essentially the equivalent. I remember seeing a thread on the VW and Honda forum about guys using lawnmower/ATV/motorcycle batteries as long as the CC amps were the same and putting them on tenders when parked.
11-24-2011, 04:35 PM | #5 | |
Grumpy Old Man
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Ghetto fabulous
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
11-24-2011, 04:41 PM | #6 |
2 wheel member
For guys who own motos with lightweight batteries, it's more common than you think.
My bike is actually connected to one as we speak and here is another Duc on a tender. That's the tradeoff for going with a smaller battery.
11-24-2011, 11:11 PM | #7 | |
Rocket Surgeon
Drives: PSM GGA OMG
EDIT: OP, take a look at Ballistic Performance. They're a bit spendy, but light as hell. Their batteries are intended for motorcycles, but they make one for big displacement, high compression Harleys that has more than enough juice for a 2.0L four cylinder. It weighs 3lbs and has more CC Amps and Amp Hours than a 18lb Braille AGM battery for only $60 more ($270 total). For comparison's sake, the lightest battery Braille makes, with similar capacity, weighs 9 lbs and costs $2000. Last edited by old greg; 11-24-2011 at 11:27 PM. |
11-24-2011, 11:15 PM | #8 |
Site Moderator
Drives: Stuff
Depends on the usage of the car. For a street car I agree, but for a race car it's just fine.
Speed: Since the battery on this car is right against (or basically against) the firewall on the passenger side a light battery will make a much smaller difference compared to a car that has a front mounted (right behind headlights, etc.. in front of the axle) battery. Same weight difference on both battery locations, but the effects on handling are different. Just as I've done with my Hondas that have a similar placement (except literally against the firewall) I'll be leaving it alone.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
11-25-2011, 12:58 AM | #9 | |
Drives: WRB BRZ limited 6MT
http://www.solomotoparts.com/product...0&cat=0&page=1 $242.95...for the 3 pound 16 cell EVO 2 lithium battery |
11-25-2011, 02:28 AM | #10 | ||
2 wheel member
Damn 242.95 for 3 lbs!! You can shit out 3 lbs and that won't cost you anything! Anyone looking at the Braille, it's the same as the Deka and around under a $100. http://forums.vwvortex.com/showthread.php?2353060 http://www.dekabatteries.com/default.aspx?pageid=510
11-25-2011, 02:56 AM | #11 |
Drives: Bugatti Veyron
Cayman R battery
11-25-2011, 03:16 AM | #12 |
Drives: Impreza GC8
On my previous car, I had a Deka battery that was approx 11lbs. Forgot the model and specs on the battery, but the results surprised me. I did not think changing to a lightweight one would have that much effect on handling. Lost about 35lbs under the hood, but the downside was that I had to switch back to OEM battery for winter. The Deka just didn't do well at temps below 10 degrees celcius and it won't crank the car at anything below 5 degrees celcius.
Overall if you're into making your car handle good, then it's a good modification. Switching batteries wasn't a big hassle for me. |
11-25-2011, 03:36 AM | #13 | |
Lude Dude
Drives: 1998 Honda Prelude
11-25-2011, 07:32 AM | #14 |
Tags |
battery |
Similar Threads | ||||
Aftermarket wheels chopped onto Modellista 86 | JDM-dono | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 32 | 12-20-2011 04:20 AM |
What Aftermarket parts would you like to see for the FT86/FRS | mkivalex | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 11-14-2011 10:50 AM |
Toyota FT-86: a goldmine for aftermarket parts | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 12-27-2009 10:16 AM |
