12-19-2014, 04:26 PM | #2325 | |
Drives: 10 Series Scion FR-S
12-19-2014, 05:00 PM | #2326 |
I have to point out that AFR between stock and full exhaust + drop-in + manifold spacers isn't altered dramatically. Right now I have stock cat back, but the dyno was done when I had a Q300 catback on.
Stock Full bolt ons + stock tune. Just for the heck of it... Full bolt ons minus header. Header provided almost no gains... Last edited by Cartman; 12-19-2014 at 05:17 PM. |
The Following User Says Thank You to Cartman For This Useful Post: | kodyo (12-21-2014) |
12-21-2014, 05:59 PM | #2327 | |
Drives: Sci FR-S, Fer F355, Toy Highlander
Good to know. I have been running OFT Stage 2 UEL on my FR-S since getting the FT86 SF catted UEL header (I was one of the first 10 sold). I'll switch to OFT Stage 1 as you suggested. (S2D4, No I do not have any logs ... ) . Shiv mentioned that the Stage 2 UEL OTS tune would be okay for the catted header when I asked him, but don't want to affect my warranty. |
12-21-2014, 10:40 PM | #2328 |
Drives: Scion FR-S
12-23-2014, 01:47 AM | #2329 | |
This header could have great potential, but only if you go catless. If you're gonna go with the catted version, leave everything else stock to take advantage of it. For science, a local guy has this header as well His car has: FT86SF catted header, 3" Catless FP, 2.5" perrin cb, 3" overpipe, Intake manifold spacers, Supertek pipe + drop in, HKS Intake duct Managed to get 170WHP with a tune on that dyno, and 180whp on a dynojet with 93 octane. My car did 170WHP as you can see from the dyno sheets wiith the header, Perrin 3" catted FP, 2.5" overpipe, Manifold spacers, K&N drop in filter, invidia Q300 catback, and stock tune on 91 octane. It did 181WHP on a dynojet with 93 on stock tune and 186WHP tuned with the stock catback. But like I said, I'm pretty sure I would have gotten those same numbers with stok header with better low end tq, although having the dip at 3K vs a flat tq curve. |
The Following User Says Thank You to Cartman For This Useful Post: | kodyo (12-23-2014) |
12-30-2014, 04:44 AM | #2330 | |
Drives: Toyota 86 GTS Storm Black
FT-86 SpeedFactory Catted UEL Header
Not to high jack the conversation but I have the catted ft86sf header and catted front pipe of another brand with a full resonated exhaust, what tune should I be using out of the ofts? I am also from Australia if it helps. |
12-30-2014, 06:40 AM | #2331 | |
Is you secondary cat hi-flow ? you might try out the stage 2 uel, but your going to have to log for knock and afr to see what it look like. it probably worth the expense of an e-tune at least. |
12-30-2014, 07:49 AM | #2332 |
Drives: GT86
Stage 1. Original header is also slightly UEL and this header is a mild UEL with a ceramic cat.
12-30-2014, 01:43 PM | #2333 | ||
Drives: Yes
To quote the developer himself: Quote:
So let's stop asking whether we should run Stage 1 or 2 with this header; the answer is pretty obvious.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post: | FT-86 SpeedFactory (12-30-2014) |
12-30-2014, 11:47 PM | #2334 | |
Drives: Scion FR-S
Not perfect, but I think it's pretty close (and I messed up the bottom tail of the HP curve). |
The Following User Says Thank You to kodyo For This Useful Post: | Cartman (12-31-2014) |
12-31-2014, 12:26 AM | #2335 | |
12-31-2014, 04:11 AM | #2336 |
Drives: GT86
What I keep seeing here is that people like Cartman spend quite some money on several harware mods that each of them by themselves warrant a proper tune (spacers, header, full exhaust) or at least in combination with one of the before (intake). But you run them all together without any(!) tune or without getting a proper one, yet still seem it worthwhile to do several dynos. And then if it doesn't work out as expected you blame the header?
I would at first hand blame the lack of a proper tune, there is NO way a stock tune can accomodate for all those mods AND give more power for each of them. It just doesn't exist. And a stage 2 generic tune isn't suitable either if you did any research and problems are to be expected. This isn't new, it has been stated over and again in this thread. So, please explain how you can spend thousands on hardware and several dynos, and then not spend a few hundreds on a suitable tune?? It's like buying a sniper rifle and not buying scopes and complaining you keep missing your target... Sorry if I misunderstood your situation but as of now, I really don't understand what you expected. |
12-31-2014, 07:49 AM | #2337 | |
12-31-2014, 08:16 AM | #2338 |
SLO NO MO
That's essentially what the FT86SF Catted UEL Header was designed for - people were asking for a UEL catted header that wouldn't need a tune.
By FT86SF's own admission, as soon as you introduce any other mods to the intake/exhaust, all bets are off and you'll need a tune to avoid issues. |
Tags |
catted uel header, ft86speedfactory header, is my order ready yet? |
Similar Threads | ||||
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 10:48 AM |
catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 12:50 AM |
Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 12:01 PM |
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 10:12 PM |
