Old 06-08-2015, 06:33 PM   #505
meWant
Drives: '16 BRZ Limited
Originally Posted by zman View Post
Has anyone used "plasti dip smoke" on this tail lights?
Originally Posted by eggncheese View Post
You don't wanna do that. The plasti-dip smoke is very translucent and does not transmit a lot of light. I don't think you would be able to see the turn signals very well during the day.
I had used the plasti dip smoke on the tails with a couple coats of glossifier over it. It comes out nice but it hazes the led's in brake lights this bugged me so I ordered taillight overlays from @Bluebatmobile. Overall though, if you don't go close to a pitch black then you should be fine as our turn signals are bright enough imo. In for pics if you do go with the plastidip
meWant is offline   Reply With Quote
Old 06-09-2015, 02:24 AM   #506
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
I sprayed 2 light dusting coats and then 2 medium coats and then 1 heavy coat. The more coats= the darker red. After VHT I did 3 layers of clear coat and then wetsand. Now they look as dark as TOM's tail lights.
KungFuWaffle is offline   Reply With Quote
Old 06-10-2015, 02:17 PM   #507
Bluebatmobile
Drives: 1997 Acura NSX
nice!
B@t™
Bluebatmobile is offline   Reply With Quote
Old 07-10-2015, 05:11 AM   #508
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Is a week too long to wait before clear coat? I got an amazing finish but forgot to get clear! I want spraymax 2k but would have to wait for it to ship. Putting me at 7 or 8 days after ive painted the tails. Is that too long? If so ill have to settle for a different brand that I can get locally. Any suggestions on another good brand if a week is too long to wait?
Jolt182 is offline   Reply With Quote
Old 08-31-2015, 03:11 AM   #509
eric2523
Drives: Subaru BRZ '13 Limited
What does wet sanding the lights do?
eric2523 is offline   Reply With Quote
Old 08-31-2015, 08:17 AM   #510
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
It smooths everything down so the light doesn't feel or look rough. If you wet sand, the final product will be smooth and even looking, not chunky or blotchy.
Bobblehead is offline   Reply With Quote
Old 09-14-2015, 03:03 AM   #511
eric2523
Originally Posted by Lawnik View Post
Followed it with the results below. I did smoked outside, with a red with smoke in the center. This is my attempt at FRS concept-like tails.
Could be clearer, but happy with them. Might try to add some coats of clear.
This looks sick! Mind giving specific instructions on how to do it like this?
The Following User Says Thank You to eric2523 For This Useful Post:
Lawnik (09-16-2015)
Old 09-16-2015, 10:49 PM   #512
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Thanks, I would if I could recall the details.
Pretty sure I taped off the pattern that looks red in the center area matching to the lines inside the light. Put down 2-3 coats of dark midnight tint then pulled off the tape, a little wet sanding then red tint the whole thing 2-3 coats. Then wet sanded and cleared to taste.
Hope that helps,
Lawnik is offline   Reply With Quote
Old 12-01-2015, 08:35 PM   #513
axelo
Drives: Whiteout frs
Mine
Simple if you have painting skills...i have so... Red vht and last coat is a medium gloss coat, buff, shine and install back...whiteout frs looks amaizing in my opinion with red tails... Btw my turns are red colored leds!!! Looks so good at night
Thanks to evryone who wrote on this thread!!!!!
axelo is offline   Reply With Quote
Old 12-01-2015, 08:38 PM   #514
axelo
Hell yeahhh
Took me a long time to make the change...i enjoyed my stocks, i think its a great looking tail light in the frs
Old 01-06-2016, 04:33 PM   #515
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Did this a while ago, but I forgot to post a photo. Used Duplicolor Red Metalcast, 2 light layers, 3 medium, 1 semi-heavy. Wet sanding when necessary. Then, 3 medium coats of Duplicolor Acrylic Clear Coat. After that, I polished and waxed them.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 01-06-2016, 04:41 PM   #516
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Looks good!
Joe-G is offline   Reply With Quote
Old 01-06-2016, 04:42 PM   #517
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Anyone have advice for taping off the signal lights? Any specific method? Or just use tape and cut to shape?
Tape > Cut shape > Spray Tint > Remove Cutout (Dry) > Clear Coat
Sound about right?
Old 01-06-2016, 06:43 PM   #518
Manic
Is not fast.
Manic's Avatar
Thanks! As for the taping, all I know is that you need to be in a really clean environment and be really meticulous about the painting. When I had to wet sand any imperfections, the masking tape I used to seal the taillight would get a little wet and start to come off.
A friend of mine tried to do the signal cutouts and ended up having asymetric patterns
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
