09-16-2013, 08:32 PM | #1849 | |
Drives: Over the hill WRX
http://www.valeo.com/en/page-transve...ercharger.html |
09-16-2013, 08:47 PM | #1850 | |
I was thinking the same thing about Toyota writing him a check lol and using it |
09-16-2013, 09:56 PM | #1851 |
You could use an innovate ot-2. It has an api you can use to listen for what are basically pids from the obd2 over wifi, really fast if necessary. They have examples and docs on their site.
09-16-2013, 10:02 PM | #1852 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
09-17-2013, 01:39 AM | #1853 |
Atoning Unifex
Drives: '13 BRZ Premium, WR Blue
@mid_life_crisis: The throttle switch (+5VDC) can be pulse-width modulated with a transistor to vary the compressor motor speed, however I've been repeatably told the current system is not designed for constant operation.
There's no need to 'smooth-out' boost onset at WOT with a ramp-up, the boost addition feels natural there; it would be nice and reasonable to run lower boost when climbing a hill, for example. If we're WOT climbing a hill holding steady at 3.5k RPM for 5 minutes (Colorado?), it would be better to run at lower PSI for the whole climb than to reach the thermal limits and have the controller shut off the system to cool and recover. Constant operation all the time will cause more drag on the alternator, increased wear of the compressor motor, greatly increased thermal management issues of both the compressor motor and the controller, as well as complicating the tune since it could engage when not the ECU was open loop... and probably other things that Rob has already thought through that I'm not educated enough to realize. Really, the system feels awesome as-is; now that I have really gotten to play with it, I don't see the need to add much more complexity. |
09-17-2013, 09:16 AM | #1854 | |
I'm looking for a seamless way to limit boost at low rpm when the system is engaged (switch on, pedal to the floor) to protect the engine's bottom end and make it possible to run without a tune.
09-17-2013, 09:31 AM | #1855 | |
Drives: DGM BRZ limited
It should be a pretty simple circuit, Id love to see what you come up with :happy0180: |
09-17-2013, 10:19 AM | #1856 |
Atoning Unifex
09-17-2013, 10:22 AM | #1857 | |
I haven't done circuit design in eons. This will be interesting. I agree that this should be a simple circuit. So I just send a pulsed 5 volt signal. I'm assuming that a continuous 5 volts is "full throttle" and as the pulses get shorter the thing slows down. Is there a particular frequency range it expects?
09-17-2013, 03:24 PM | #1858 |
Drives: VW
Thatruth dyno. Boost from 1800 rpm. 180 ft-lbs @ 2800 rpm Similar gains to other dyno runs, best @ 4200 rpm Wonky boost plot. Nice AFR's Bob!! |
The Following 10 Users Say Thank You to Robftss For This Useful Post: | bfrank1972 (09-17-2013), brichard0625 (09-18-2013), DAEMANO (09-17-2013), dnavas (09-17-2013), Drift-Office (09-18-2013), neutron256 (09-17-2013), NoChance (09-18-2013), raven1231 (09-17-2013), Sportsguy83 (09-17-2013), sw20kosh (09-17-2013) |
09-17-2013, 04:10 PM | #1859 | |
Drives: 2013 FR-S Argento
Any theories on the oscillating boost curve in the upper rpms? |
The Following User Says Thank You to bfrank1972 For This Useful Post: | raven1231 (09-17-2013) |
09-17-2013, 04:56 PM | #1860 | |
Sent from my HTC One using Tapatalk 4 |
The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (09-17-2013) |
09-17-2013, 05:03 PM | #1861 |
Drives: 2018 BMW M240i
Im interested but skeptical.
This goes against myth busters and countless other videos that have proven its impossible for an electric motor (in a cars engine bay, running on batteries) to produce boost. |
09-17-2013, 05:04 PM | #1862 | |
A side thought - would this system partially compensate for altitude? The thing is trying its hardest to force as much air as it can into the engine - if the air is thinner my intuition says it would at least partially make up for the deficit from altitude - in other words I'm wondering if you guys at altitude will see bigger gains than us at sea level? If that's the case, would the dyno's altitude compensation be optomistic? I'll be interested to see some low altitude dynos soon! |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
