05-22-2015, 07:42 AM | #211 |
Drives: '15 Halo FR-S
Pretty sure the blinker fluid in the Porsche is going to be far more expensive than on the FR-S. When I had my first oil change done, the dealership told me my blinker fluid needed replacing and they only charged $20. Imagine how much it would be at a Porsche dealership!
The Following User Says Thank You to Bergen23 For This Useful Post: | Tcoat (05-22-2015) |
05-22-2015, 08:52 AM | #212 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Bergen23 (05-22-2015) |
05-22-2015, 12:52 PM | #213 | |
Drives: 13' Scion FRS MT
My current plan is to get some serious seat time in the Cayman S and see how much of an improved FR-S it really is.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport 13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook | |
The Following 3 Users Say Thank You to Re~Mix For This Useful Post: |
05-24-2015, 01:17 PM | #214 |
I get 18-19mpg instead of 25-26mpg now... so there's that. It's $300/yr more expensive to insure (your results may vary). Consumables do cost more and you'll want to find a good independent Porsche technician to work on it if you're not handy turning your own wrenches. Obviously you shouldn't trust it to the minimum wage teenagers at Jiffy Lube (not that you should trust your FR-S/BRZ to them, either!)
If you buy a 996/997.1 or Cayman/Boxster with the port injected engine you will want to replace the IMS bearing if it hasn't been done already. The part itself is ~$800 and to pay someone to do it you should budget $2000 including the part. You shouldn't need to do it to the 996/997 Turbo or the 997.2/Cayman/Boxster with the direct injected engine. They are also known for cracking the plastic coolant expansion tanks which can be a bit of a PITA to replace; they turn yellow and crack with age. It's usually good to replace it, the water pump and thermostat all at once if you're dealing with a ~10yr old model. They're also known for having a wire off the alternator that's too small to provide sufficient grounding and it causes voltage drop and hard starting when hot. My car has this problem; it's $99 to fix through Suncoastparts.com Had my 997 for three weeks now and I haven't looked back (I do miss the gorgeous Galaxy Blue color vs Arctic Silver, but that's it). I got invited to a Porsche driving experience at Thompson Speedway this past week where I got to thrash my 911 and a brand new Cayman S and Carrera 4S on the track; it totally validated my purchase! I have autocrossed my BRZ and driven a GT86 on the Nurburgring before and needless to say the 911 was much more satisfying to drive at the limit (assuming you have the driving skill - the BRZ is a better beginner's car). That being said, the consumable costs associated with racing a 911 are going to be higher than an FR-S/BRZ, stock-for-stock and mod-for-mod. You'll find that mods for the 911 cost as much as double, sometimes triple what they would cost for your average Japanese tuner car (I have no plans to modify mine like I did the BRZ; perhaps a set of OEM X51 headers, Fabspeed cold air kit and a Eurocharged ECU remap to bump the power up to ~380hp). The 911 is also a much more pleasant car to daily drive. It has a slightly quieter cabin, considerably better stereo, less-notchy shifter, nice exhaust note, better steering feel, and of course, more power and torque. It's less twitchy on the highway and the suspension is slightly more composed although the fat rear tires do crash over bumps and tramline slightly on uneven surfaces. No bluetooth, nav, or satellite radio sucks but I plan to upgrade the head unit in the future. I don't like the key being on the left hand side of the wheel, though! It's much more logical to insert the key on the right while you close the door with your left hand... Oh well; that's not going away anytime soon
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 05-24-2015 at 01:32 PM. |
The Following 2 Users Say Thank You to Turbowned For This Useful Post: | Re~Mix (05-26-2015), sprintertrueno86 (05-24-2015) |
05-25-2015, 01:32 AM | #215 | |
Drives: 2012 WRX, 2003 RSX Type S
The Following User Says Thank You to blackhawkdown For This Useful Post: | WolfpackS2k (05-26-2015) |
05-25-2015, 03:41 AM | #216 |
Junior
Drives: a car
Ive always been a fan of the Cayman's. I knew of the 987.1 IMS problem, which was why I was looking at an 09 for the dreams. Since they haven't been around as long as the 911, I keep hearing that the Cayman hasn't lived up to the Porsche stigma of reliability, which is a good thing. Although yes, consumables are considerably more expensive. But for the car you're buying (3x the price of the 86 when it was new) is understandable. There's even 987.1/2 single(?) turbo kits that make it a GT3RS fighter, but that's a whole different ball game.
05-25-2015, 03:40 PM | #217 | |
That being said, you can modify parts to increase power in a Cayman or Carrera all day long but you can't make a Mid-Engine Carrera. The RR layout on the Carrera is a turn off for me but a 996 Turbo is one hell of steal. Now only if I can afford the GT4 Cayman. |
The Following User Says Thank You to blackhawkdown For This Useful Post: | cdrazic93 (05-25-2015) |
05-25-2015, 04:25 PM | #218 |
Drives: '06 AM V8V Coupe
I think the best bang for the buck right now is the 987.2 base Cayman. I saw a 100k mile 2009 for something like 25k! More typical is like low 30s. The 981s look more high-end but for 30k, the exoticness per dollar is pretty high.
The 2.9L engine isn't DFI but it's the new architecture and makes solid power. It probably can make 280hp easily with light mods. Belt driven PS pump probably should be thrown out and replaced with an electric pump for reliability and some extra horsepower but other than that I couldn't find anything bad about those cars. Plus, if you want to, you can make it extra lightweight by putting the aluminum Cayman R doors on or some similar replacement. |
05-26-2015, 02:28 PM | #219 | |
Drives: '12 C63 P31, '23 GRC
As to OEM pricing, every Porsche owner should be aware of the following two resources: www.http://sonnenporscheoemparts.com http://www.suncoastparts.com/ Wholesale prices for OEM parts. Either of these resources will beat the pants off the average local Porsche dealership.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
The Following User Says Thank You to WolfpackS2k For This Useful Post: | cdrazic93 (05-26-2015) |
06-08-2015, 11:05 AM | #220 |
My starter failed this weekend. I knew it was on its way out as it would take a while to start, but I was hoping I could hold out until I brought it in for the IMS bearing upgrade. Looks like I'm getting the IMS bearing done now! Luckily my indy tech has the parts in stock and the starter won't be much or any extra labor considering he's already in there. $250 for a new Bosch starter (Porsche wanted $1,100 for their starter; get f**ked!), $120 for the updated alternator/starter wiring harness, and a bit under $2,000 for the IMS bearing upgrade. My work gave me a rental in the meantime, so all is well.
$2,000 for the IMS bearing upgrade is cheap insurance against a $20,000 engine replacement.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
06-09-2015, 01:36 PM | #221 |
Drives: Subaru BRZ 15, 997 Turbo 08, BMW 5
you should keep both. Actually I just bought both BRZ and 997.1 turbo just last week!
Since the roads around here are all messed up, I like to drive the BRZ more often that the 997. There's no need to be super careful about driving the BRZ, where as with the 997 turbo, I have to plan ahead of time about where I'm going to make sure I don't damage the car. |
06-18-2015, 03:05 PM | #222 | |
3,000 miles in 1.5 months of ownership; I need to stop driving this thing so much!
07-01-2015, 10:28 PM | #223 |
FWIW.....my Cayman S is for sale ! ( post 63 )
(dont ask what I want to get to replace it) Myles |
07-02-2015, 02:35 AM | #224 |
Drives: WRB BRZ Series.Blue
Similar Threads | ||||
GT 86 beats Porsche 911 Carrera | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 08-12-2014 02:08 AM |
2014 Porsche 911 Carrera Opti Coat PRO | Hamza7 | CANADA | 0 | 05-27-2014 11:43 AM |
DetailersDomain.com - revives an 05 Porsche Carrera S | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 02-19-2014 06:38 AM |
BRZ vs Porsche 911 Carrera S (Mile high mashup review) | daiheadjai | BRZ First-Gen (2012+) -- General Topics | 1 | 06-04-2013 03:57 PM |
Scion Fr-S vs 25K 2002 Porsche 911 Carrera | FR | CANADA | 13 | 05-18-2012 11:16 AM |
