01-30-2015, 01:47 PM | #85 |
Drives: 1966 Mustang, 2013 FR-S
@The_Understated
This is where I got mine. It came with the harnesses, fogs, bezel button, and plate. http://www.scionpartsmall.com/2013-S...2013-Scion-FRS |
03-06-2015, 03:31 PM | #86 |
Drives: Sc10n Series FR-S
Wondering if I can get some help here.
I have wired in my WinJet set with the supplied switch and harness but I would like to use the switch harness that is already in the car (the grey one with white tape on it behind the trunk button). This will fit in my switch. The question I have is about wiring. Currently the fogs are wired as so: Red wire from Fog --TO --> Battery + terminal. then on the other side Ground to Chassis Red Wire from Fog --TO --> Yellow wire on Harness INSIDE Vehicle On the inside, from the switch harness I have: Yellow Wire from switch --TO --> Red wire to fogs through FW Black Wire from switch --TO--> Ground Brown Wire from switch --TO--> Purple ACC wire on other harness Now, this all functions, but I'd rather keep it clean and use the already wired switch harness so I can also see the light on the dash. I am assuming I'd need to rewire either one of both of the red wires from my fogs. Where should I put them so that they have power when the lights are on and the switch is activated? Thanks!
I figure as long as you smile while driving the car, you're doing it right.
03-07-2015, 05:42 PM | #87 | |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
http://www.ebay.com/itm/FOG-LIGHT-LA...3e77be&vxp=mtr and u need to connect your fogs to factory wiring this way you will get the green fog indicator on the dash
03-08-2015, 08:32 PM | #88 | |
Drives: Whiteout FR-S
03-08-2015, 11:31 PM | #89 | |
Space for Rent
[IMG][/IMG]
The Following User Says Thank You to 1GiantTurtle For This Useful Post: | PopaNolie (10-15-2022) |
03-09-2015, 07:59 AM | #90 |
I was actually referring to the very small wire connector that goes between the button and the white OEM connection inside the dash panel.
And thanks by the way for posting your progress on recreating the rest of the OEM fog light harness, I'm hoping to tackle this project this summer. |
04-03-2015, 03:41 PM | #92 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
04-20-2015, 08:21 AM | #93 |
Drives: 1992 Nissan Skyline GTS-t Type-M
I picked up the switch itself from a local dealer and the bezel for $15 off eBay. Would also be interested in knowing where I can get that small adapter-like cable that goes from the switch to the factory harness so I don't have to mangle anything oem for a diy I'm working on.
Trying to wire up the boomerangs on my spec-d lights on the fog light switch. http://www.ebay.com/itm/221668295760...%3AMEBIDX%3AIT I'm not sure what the below adapter is even for, since it's got the same connector as the oem harness that's taped up under the dash. All I know is I want/need one for my project. Last edited by FyeaFRS; 04-22-2015 at 07:27 AM. |
04-21-2015, 12:45 PM | #94 |
Drives: 2013 Scion FRS
I installed my fog lights recently. OEM fog ligh bezels and Valeo fogs lights. I am sure I didnt do any mistakes on the install as per my install look exactly like in the photo posted ealier in the thread.
Here is the issue
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
04-21-2015, 03:01 PM | #95 |
Drives: 2014 FR-S
The gap is by design, it's because the mounting bracket moves the fog light housing back. Supposed to prevent melting or something. You don't actually need the bracket, you can always mount the fog light directly to the bumper.
The Following User Says Thank You to kbye For This Useful Post: | FRSToyota86 (04-22-2015) |
04-22-2015, 04:15 PM | #96 |
Good Idea I will try that
04-25-2015, 03:52 PM | #97 |
Didn't feel like finding that pigtail that seems to come with the kits, so I just cut the factory harness. I see the oem fog light switch has a red led in it like the dimmer. Does anyone know it there is a pair thats just for the switch part. I'm trying to use the switch as an on/off for the boomerang in the spec-d lights.
*UPDATE: So multimeter readings look like the two outside wires are switched and I didn't get anything from the inside pair. I'll probably have to take the meter out to the car and get readings. Last edited by FyeaFRS; 04-25-2015 at 04:43 PM. |
05-18-2015, 12:28 PM | #98 | |
Updates on this test? I'm assuming that the white and black/yellow then must be the relay for the fogs. The Purple should be 12v power to ignition? Which then means black/white must be ground? Let me know, I need to use these for my fogs. Thanks
Similar Threads | ||||
TOYOTA emblem... JDM vs USDM | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 89 | 08-15-2013 03:00 PM |
Has anyone install a light weight flywheel? | 20valvewynn83 | Engine, Exhaust, Transmission | 44 | 08-08-2013 09:52 PM |
Custom Third Brake Light Install (incl. Pics) | Skorov | AUSTRALIA | 14 | 07-27-2013 04:04 AM |
Glovebox LED light Install | Tech | DIY (Do-It-Yourself) Guides | 0 | 03-26-2013 07:21 AM |
OEM Fog Light install! ON and working! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 38 | 07-04-2012 07:11 PM |
