Old 09-19-2017, 12:02 PM   #253
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Originally Posted by michaelmil View Post
Hi All,
I'm getting the 18x9.5 all around and wanting to do research on tires. For right now Planning on wearing out stock suspension. I don't want to have to stretch the tires and have excess wheel showing, rather I'd like to get tires that covers the whole rim, preferably even giving some excess sidewall for wheel protection.
However of course with stock body and suspension what's the widest tires can these fit?
A.) For size 255: seems to be the neutral not too narrow - too wide. What height? 255/35...255/40? What brand of tires, recommendations, experiences, pics?
B.) Would 265 width fit? what height treadwall...265/35? Would it fit stock? don't mind if have to roll fenders, doesn't seem like its that hard?
This setup will not fit on stock suspension or lowering springs. It will require coilovers.
You can run the 18x9.5 all around but with a 235 or smaller tire stretched. Otherwise if you run any bigger of a tire it will hit/rub against your suspension in the front.
An option is to get 5-10mm spacers and then you can run the optimal 255 tire. But at that point the wheels will be sticking out from the fenders and not look good at all.
Long story short. Anyone wanting to run an 18x9.5 square setup on an FRS/BRZ it is best to have coilovers.
Kami Speed is offline   Reply With Quote
Old 10-27-2017, 04:02 PM   #254
godzuki
godzuki's Avatar
Drives: frs
Perfect fit tires for 18x8.5"
finally had a chance to put 255/35 on my 18x8.5 42 57xtremes and this combination makes the protruding lip totally disappear!
unfortunately i strongly suspect a 255/35 tire will make make the front poke out a lot. will know over the weekend and post pics.
pics of michelin pss 255/35/18 on 18x8.5x42
https://gyazo.com/511a1de27064bbd4d26fcd432aa0f65d
https://gyazo.com/82d6e4920d32bb3c6681ae6871daa894
pics of front 18x8.5x42 with kumho 235/40/18 tires (note how much the lip sticks out)
https://gyazo.com/b958465a3657a8eceb72400d46fb46f0
godzuki is offline   Reply With Quote
The Following User Says Thank You to godzuki For This Useful Post:
Kami Speed (10-27-2017)
Old 11-06-2017, 09:40 PM   #255
godzuki
godzuki's Avatar
Drives: frs
Update: So I had my front tires replaced with a pair of Michelin Pilot Super Sports and the fitment was all off. The lip poked out a bit (not as much as with the 235/40 kumhos) and the sidewall had a little bulge to it. My first thought was the pair of 57xtreme front wheels were slightly different from the rears (since I bought them about a year apart from each other), but on closer inspection turns out it was the tires themselves that were different. Tire Rack sells (at least) two different Michellin Pilot Super Sport tires. Everything is the same, reviews, name, price, rating, but one is "TPC Spec" and one is not. The TPC Spec version is the better looking fitment (the one I posted pictures of). I called up Tire Rack and they spoke to Michelin and replaced the non-TPC Spec tires.
I am on Tein coilovers with about a 3/4" drop and no camber in front and there is absolutely no rubbing.
Yes, there's a bit of poke on the front but not that big a deal.
Old 01-04-2018, 08:53 AM   #256
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Hi guys
Im thinking of getting the 57 xtreme 18x9.5 +40 for my car and i have D2 coilovers installed,my coilover has camber setting in the front,im thinking of 255/35 or 255/40 because our roads arent that good, im scared of the rubbing problem,can anyone help and tell me should i use 35 or 40?
Thanks
Mehrshad is offline   Reply With Quote
Old 01-04-2018, 02:19 PM   #257
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Mehrshad View Post
Hi guys
Thanks
Use 35 series, it's diameter is 25". (1.7% diff from stock)
24.6 stock diameter. 255/40 has a 26" diameter, which is 6% larger. Generally you don't want more than a 3% +/- difference.
I LIKE TIRES!
Old 01-12-2018, 07:16 AM   #258
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Hi guys
Where can i buy the 57xtreme for a good price? if you know tell me in PM please
And whats size lugnut should i get?
Is it M12x1.25 & M12x1.5 ?
Old 03-20-2018, 03:51 AM   #259
zz_
Drives: FT86
To run an 18x9.5 square setup on FRS/BRZ with a coilover and 255/35/18 tyre, do you need adjustable LCA too?
zz_ is offline   Reply With Quote
Old 03-20-2018, 11:29 AM   #260
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Yes, it is recommended to get rear LCAs to get your camber back to or close to within OE spec. Since when you lower your car the geometry will be much different and these cars do not have any adjustment from the factory.
Old 04-23-2018, 04:08 AM   #261
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Hi guys
I finally got my 57xtremes in Matte Graphite, i got the 18x9.5 +40 , im running them on Michelin Pilot Sport 4 , 255/35/18 square fitment and Rays Dura-Nut L42 Straight type lugnuts,with 65/56 hubs,and i have D2 Racing Coilovers,i dont know how much i lowered it ,i think its an inch.i got a little rubbing on full lock
these are some photos of my car.
https://ibb.co/dWcyWx
https://ibb.co/iz85Bx
https://ibb.co/kM7bJc
https://ibb.co/eCHyWx
https://ibb.co/hfWxPH
https://ibb.co/n8gaBx
https://ibb.co/kqLrjH
gramlights 57xtreme, toyo tyres
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 05:57 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 MVJ1975 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 10-05-2013 02:29 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 12:44 PM
