02-13-2014, 07:51 PM | #141 |
I completely forgot about this thread.
Best. Build. Evar. |
The Following User Says Thank You to wheelhaus For This Useful Post: | Nico TURBO (03-16-2014) |
03-16-2014, 10:10 PM | #142 |
Drives: 1986 Subaru LEONE TURBO
got lots of parts coming in for my toy very excited to fix the little problems and add some new updated bits to make this car more fun a race track this year.
I found a nice GL-10 Turbo cross member from the local scrap yards had it sand blasted and powder coated black for that long lasting effect. also did the USMB washer weld on trick to re locate the control arms a bit further out so I wont have rubbing binding problems any more with the XT6 control arms. here you can see the old hole with new hole my spare Bosch 044 came in (might use this for my other build going on will see) and my arp head studs 625+ for the spare motor, still waiting for the new subaru crankshaft to come in from subaru japan to build the block which wont be much longer. |
03-24-2014, 06:38 PM | #143 |
So I been collecting parts for my car now do to everything being Super RARE or no longer available (NLA) from Subaru any more.
just in case I bend something or I need to replace something, some of the stuff is still getting sand blasted and powder coated. front control arms bushings XT6 only white line # W51458. you must melt out the XT6 bushing and re use the shell for this to work. top corner in Pic is bushing and shell there rear mustache bar on the older Subaru's also have a bushing that can be replaced with a white line part number # W91379. this part fits on all new Subaru's T bar holding the diff up. to make this bushing work you must burn out your old metal shell that the bolt goes into, then drill out the white line bushing to the same size as the bolt shell. pic bushings is in center XT6 control arms you can see them. there will be more bushing's coming to firm up the ride on my car, I need to measure them still and cross fit from a newer Subaru once all stuff comes in. |
03-25-2014, 11:04 AM | #144 |
today my Nolathane bushings came in for my Subaru XT6 control arms, for people that never heard of Nolathane, there the owner of Whiteline which is more popular in north america then in Australia but the boys down under know all this all ready lol.
Now I'm waiting for my other bushings from SuperPRO which should cover the rest of my underside bushings and give me that firm more responsive ride around the race track this year. Nolathane # 46200 direct swap made with the shell |
The Following User Says Thank You to Nico TURBO For This Useful Post: | SkAsphalt (03-25-2014) |
03-25-2014, 11:39 AM | #145 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
It always makes my day when ever this thread pops up with updates. Keep it up!
The Following User Says Thank You to BigFatFlip For This Useful Post: | Nico TURBO (03-27-2014) |
03-25-2014, 02:29 PM | #146 |
35r + 35r = 70rr ?
Drives: Subaru BRZ Time Attack S13
This is so far beyond awesome.
The Following User Says Thank You to itwillboost For This Useful Post: | Nico TURBO (03-27-2014) |
03-27-2014, 08:15 PM | #147 | |
i get to pull the car out of storage soon and work on it very excited this year for new toys and lots of power coming. thank you.. I got my 2015 Subaru Impreza STi shift knob, looks good in red match my horn button now. |
03-27-2014, 08:19 PM | #148 |
Drives: Asphalt FRS
This is the dopest car thread, even over all the BRZ/FRS car threads. Sorry guys...
The Following User Says Thank You to CodyFRS For This Useful Post: | Nico TURBO (03-31-2014) |
03-31-2014, 09:53 PM | #149 |
here is the drain back for the dip stick for the Mann Hummel Provent 200 set up I have made... this is for a friend of mine which has a built Subaru also, same design as my original one I made for my Leone.
ill also be making a easy adapter for the inlet on the Provent 200, so its easy to connect the block vent and valve covers all in one tube with out making back pressure free flowing for better movement of air. used a stand grinder then cleaned up with a file and deburring tool. ill weld this up and paint it so it stays nice and clean rust free. |
03-31-2014, 10:39 PM | #150 |
when building a subaru motor fuji bond or fixing the brakes RX2 grease and servicing the cv axles and cv boots you got the proper grease from subaru !
04-01-2014, 07:50 PM | #151 |
well I finished the welding the dip sticks for the return line for the Provent 200. I also made a adapter piece because I have had a couple say the pipes inlet are to big and hose will not fit this and that...
the pipe I made is for the block vent and both valve covers, came out ok should do the trick and not block as much air as T ing the tubes up.. more air you can move the better. all the under side of a GL / XT / XT6 / Loyale sand blasted and powder coated to last a long time... Turbo cross member, XT6 arms front rear, XT6 20mm sway bar, XT6 5mt or 6mt cross member. I'm just missing the rear cross member which I need to find a spare to work with. Whiteline & Nolathane bushings in place now got to do new wheel bearings and there done. |
04-03-2014, 06:48 PM | #152 |
with the help of Franz @ DieboldAutosport he pointed me in the direction of Karim @ Lachute Performance for this Aim Fuel level adapter for a Subaru.
the Aim dash needed a converter to give it proper signal on a factory fuel sending unit. The sending unit is for the OEM subaru Analog dash in the 1986 ~ 1994 Subaru GL or Loyale, my Oem unit was a digital dash so it need to be changed to the different Ohm unit. |
04-03-2014, 06:55 PM | #153 |
Can't wait until these start going on the car!
The Following User Says Thank You to BigFatFlip For This Useful Post: | Nico TURBO (04-10-2014) |
04-03-2014, 08:52 PM | #154 |
Drives: 2013 BRZ, 1979 Scirocco 16v
Wow. Speechless!
The Following User Says Thank You to Fleischwagen For This Useful Post: | Nico TURBO (04-10-2014) |
Similar Threads | ||||
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 350 | 02-02-2013 01:52 PM |
My 1986 Toyota corolla!! | El Diablito | Other Vehicles & General Automotive Discussions | 15 | 07-26-2012 01:34 AM |
Fr-s with subaru turbo? | Afdad120108 | Engine, Exhaust, Transmission | 46 | 05-19-2012 05:10 AM |
Assumption: Subaru=Turbo / Scion=NA | ftw-86 | Scion FR-S / Toyota 86 GT86 General Forum | 159 | 06-20-2011 03:28 PM |
