Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-13-2022, 10:00 AM | #239 | |
LMGTFY
Drives: 13 FRS, 91 Miata
You stated that the service tech said they didn't have to remove the ECU which is true. You need to specify. And I'm sure you asked about them removing the ECU and not the DI ECU. 10k after the recall and it could have been a number of things. which is why they aren't helping you. Like was said above if it was something they did it should have started way sooner. Bolts do work themselves loose sometimes. Mine did. |
The Following User Says Thank You to x808drifter For This Useful Post: | Erroneous (01-13-2022) |
01-13-2022, 01:46 PM | #240 | |
Drives: Mitsubishi Eclipse
My issue is that the DI ECU was fine for 60k miles. Then it was removed, reattached, and failed within 10k miles. If it failed within 10k miles from factory, it wouldn't be acceptable. That said, I don't think their work is warrantied for that long so ultimately if they don't want to take responsibility, whatever. BUT it's pretty terrible customer service to shift blame and not acknowledge the reality that they probably didn't tighten the DI ECU properly, especially when a Toyota service center said as much. A simple reimbursement of the cost to correct their error seems like a small ask, IMO. |
The Following User Says Thank You to Erroneous For This Useful Post: | x808drifter (01-14-2022) |
01-13-2022, 02:29 PM | #241 | |
Drives: '13 Whiteout
01-13-2022, 02:38 PM | #242 | |
Drives: Crapcan
Similar Threads | ||||
Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 105 | 09-25-2020 02:10 PM |
Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
