07-31-2014, 08:37 PM | #29 |
Drives: orange fr-s MT
Thanks for the tip. I guess this would make a difference. Every help counts. Detaching front license plate decreased max cooland temp from 104c to 102c for me. I will update if I have a chance to measure difference.
07-31-2014, 11:08 PM | #30 |
rainy day can be good for testing .
07-31-2014, 11:52 PM | #31 |
Shadetree Project Ratchet
Drives: series.Blue
Wool tuft testing should suffice.
The Shadetree Project: I turn wrenches
The Following User Says Thank You to Hyper4mance2k For This Useful Post: | DAEMANO (01-29-2016) |
08-01-2014, 06:35 PM | #32 |
Drives: 93 MR2 Turbo; 2014 BRZ
The engine bay should be slightly pressurized from air coming in through the radiator/condenser. Through our CFD research, it appears that the area around the vents are near ambient air pressure. I would think these vents function.
Well executed. I have been wanting to something like this but my balls aren't nearly large enough to cut into my new car. |
The Following 12 Users Say Thank You to eric6 For This Useful Post: | avishenoy1 (10-14-2015), B-R-Z (08-01-2014), GotBRZ1691 (10-22-2015), Gunman (08-02-2014), Hostile_Kittens (10-22-2016), Hyper4mance2k (05-10-2015), Joveen (11-07-2019), Lonewolf (12-10-2016), mx5 2nr (10-14-2015), sato (04-04-2018), xkalelx (09-15-2016), YamahaR86 (09-21-2014) |
08-01-2014, 07:45 PM | #33 |
Why is the grill opening solid in the model? Are the underbody panels in the model?
08-01-2014, 07:57 PM | #34 | |
No hard feelings, just wanting to keep the thread on track . |
08-02-2014, 12:09 AM | #35 |
The big question is where does the air go from the grill to determine if the side vents would work. I guess your CFD model doesn't address that. Need to know if most of the air go out the bottom or out the trailing edge of the hood?
If most of the air goes out the bottom, the side vents probably won't do anything. If there is a low pressure area behind the trailing edge of the hood, it might just draw through the side vents and straight out the trailing edge of the hood, also making them useless. The quickest way to determine if the vents work or not is to wire up a couple of thermocouples just on the inside of the vent and also wire up one to measure the outside air temp. If the vent TC measures ambient temp, it's pulling air in. If it is higher than the OAT, then it is venting the engine heat. |
08-02-2014, 01:01 PM | #36 |
Drives: 2013 DGM BRZ Ltd
when you stand next to the car you can feel warm air with your hand
08-02-2014, 06:47 PM | #37 |
Drives: Moped
I don't know if you guys have seen this member's functional vents yet:
http://www.ft86club.com/forums/showthread.php?t=71065 |
08-16-2014, 08:38 PM | #38 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Well, this is cool.
- The Ancient BRZ Sacrament by Zaku |
09-19-2014, 08:54 PM | #39 |
Drives: '13 Subaru BRZ Limited
Just finished one of my fender trim pieces. I don't have much free time, and the fender isn't prepped yet, but here's a picture...
The Following 4 Users Say Thank You to J-W For This Useful Post: |
09-20-2014, 12:37 PM | #40 |
Do you have any pictures of where you cut the metal on the fenders?
09-20-2014, 12:38 PM | #41 |
09-20-2014, 02:11 PM | #42 |
Similar Threads | ||||
Want to trade my white Frs fender vents for Brz fender vents | White0utFrs | Exterior Parts (Aero, Lighting, Etc.) | 0 | 09-23-2013 03:17 AM |
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright | ill roller | Exterior Parts (Aero, Lighting, Etc.) | 6 | 09-22-2013 10:49 PM |
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents | BlueLeader | Exterior Parts (Aero, Lighting, Etc.) | 0 | 03-18-2013 02:55 PM |
Functional front fender vents | JohnATL | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 01-25-2013 11:58 AM |
Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents | DC-FRS | Exterior Parts (Aero, Lighting, Etc.) | 15 | 11-01-2012 11:41 PM |
