Old 01-16-2024, 07:14 PM   #1
SlowCarFast
Drives: 2015 BRZ Limited
OFT Turn off O2 Sensor Codes?
So I am fixing to install a JDL UEL header with no pre-cats. I already have an OFT and have been running it's canned tunes for years. I will be switching to the stage 2 (or whatever) tune for OEL headers after the install.
Does the OFT included tunes turn off the emissions codes set by not having pre-cats? Do I need to use antifoulers on the O2 sensors when I install or can I just install them normally?
Sent from my Pixel 7 Pro using Tapatalk
SlowCarFast is offline   Reply With Quote
Old 01-16-2024, 08:28 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Tune disables cat related codes. You are fine with just tune.
RToyo86 is online now   Reply With Quote
The Following User Says Thank You to RToyo86 For This Useful Post:
SlowCarFast (01-16-2024)
Old 01-17-2024, 10:11 AM   #3
Compelica
Compelica's Avatar
Drives: 86 GT
OFT tunes for the facelifts (K00G, K01I) actually have an additional DTC (P2270) that is not found on the A01G/A01I series, which reports the post cat O2 sensor stuck lean.
That DTC may possibly trigger with aftermarket headers or preinstalled spacers, but it is not in the provided OFT definitions so it can't be disabled with RomRaider - but it apparently can be disabled using Ecutek.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
2013 Scion frs speed sensor/codes loganmarston9696 Engine, Exhaust, Transmission 10 12-29-2018 08:43 PM
OFT & Rear O2 Sensor Failure - Can I Temporarily Disable Codes? nofferman Software Tuning 6 07-09-2017 11:37 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
