09-27-2014, 04:28 PM | #71 |
I have found three. Each time the seller wanted $23-25K firm and would not back down on the price. One of them has been for sale for like 8 months and the seller just won't drop the price (car is immaculate, completely stock, and has under 23K miles on it). I think the seller is not in a hurry and he is waiting for the right buyer to come along.
09-27-2014, 05:32 PM | #72 | |
09-27-2014, 05:34 PM | #73 | |
Take a look at your oil pressures at 250F with 0w20. You may have second thoughts.
09-27-2014, 05:37 PM | #74 | |
And since this is mentioned because the S2000 basically can with as little as pads and alignment its more geared for it out of the box. (As is miata)
09-27-2014, 06:13 PM | #75 | |
Drives: Slow
How many people have had motor catastrophes by tracking hard? I take what you say as solid info to go by. What kind of damage has happened? Does the car just pull timing and go in a limpish mode, or is that "luxury" not happening before it's too late? |
09-27-2014, 06:32 PM | #76 | |
Drives: Whiteout 2014 Scion FR-S
Post of the year. Sent from my StarTrek communicator using Tapatalk
I had an M3 once...and barely missed it. Barely
"what I'm driving here...is an ending." Jeremy Clarkson |
09-27-2014, 09:36 PM | #77 |
Drives: bmw
are you fighting for a tight line in the last turn? it looked like turbowski drifted further out and i thought that was the better line to take. been to ab but am not fast there so don't put too much stock in my comments though.
what oil temp were you getting? why considered too hot? some of me at full abcc [ame="http://www.youtube.com/watch?v=CL5OeHDvIHc"]Subaru BRZ at Autobahn race track in joliet with mvp track time - YouTube[/ame] temp up to 279. have since put in koyo radiator and the forester oem style cooler kit but not been back to a track yet. did gingerman after this vid (before the install of those goodies) and it hit 279, and i sent it in to blackstone. here is the oil analysis - http://www.ft86club.com/forums/showp...&postcount=128 speculating it will be 230/240s with the goodies in and... good enough? next time i get some data i'll post it. (may be abcc full 10/6?) |
09-27-2014, 10:39 PM | #78 | |
Those are skills easy to take for granted, we're talking about guys showing up in Porsche's and Corvettes that struggle to run a 2 minute lap at Laguna Seca, (Pobst ran 1:51 in a stock BRZ) let alone complain about brake fade or even know the definition of camber. |
09-27-2014, 11:09 PM | #79 |
Drives: 2014 Whiteout Monogram FR-S M/T
I feel as if the FR-S was expected to be modified from the get go. Wheels and tires suck, brakes suck, engine is slow but Crawford Performance knows that it likes to make power ( The S2000 is known for being reluctant to make more power).
I plan on fixing all these things on my FR-S. Power, brakes, wheels, & tires. I have no desire for suspension changes, camber is to hardcore for me. Just cooling in the only concern, but oil cooler, radiatior & maybe an oil/radiatior heat exchanger will help with the Texan heat. I am happy with my car, unfortunately I wouldn't fit in a S2K at 6"3 good thing I'm satisfied then haha. |
The Following User Says Thank You to Pegasus For This Useful Post: | Dezoris (09-28-2014) |
09-27-2014, 11:22 PM | #80 | |
Drives: Slow
09-27-2014, 11:39 PM | #81 |
Drives: 14 SWP BRZ, 07 SWP STI, 05 LGT
I love that you feel the same way in that the 2005 s2000 was the apex of that car.
The Following User Says Thank You to w.k.s. For This Useful Post: | Dezoris (09-28-2014) |
09-27-2014, 11:43 PM | #82 | |
Drives: Moped
09-28-2014, 02:20 AM | #83 | |
We ran 0w20 switched to 10w30 then 10w40. 220F was the limit on 0w20 redline before we saw 45psi (oil pressure) at 7000RPM 250F was the limit on 10w30 on redline before we saw 45psi at 7000rpm And 265F was limit of 10w40 on redline 45psi at 7000rpm. Now I want to say first and foremost mechanically speaking the motor technically is supposed to have 80psi at 7000rpm per service manual. But in the real world as oil heats we typically only see 60psi. But when you drop into the 40psi range its asking for trouble skimming bearings and such. Now I have ran 0w20 to 265F and had clean UOA. BUt the motor is fresh. I wont do that again its too risky namely if you do it under higher lateral load.
The Following User Says Thank You to Dezoris For This Useful Post: | strat61caster (09-28-2014) |
09-28-2014, 02:36 AM | #84 | |
Honestly if you track the car hard or have FI you need an oil temp and pressure gauge. We have not seen total failures yet but we dont have guys running motors with over 50k miles on track yet namely on 0w20. Running in the 40psi oil pressure on the track at high RPM is a ticking time bomb. And hot oil running out of spec will get you that just have to watch it. Again I have done it several times on 0w20 at 265F with 40psi oil pressures at 7000RPM and had clean UOA. But the motor has less than 20k on it. Ask any subie shop they would not recommend it.
Similar Threads | ||||
S2000 vs FR-S BRZ Review | Video Part 1 | Dezoris | FR-S / BRZ vs.... | 115 | 07-15-2015 12:11 PM |
Vortech Finale Review Video | Track Testing | Part 4 of 4 | Dezoris | Forced Induction | 75 | 04-12-2014 12:45 PM |
The Sad Truth | Vortech Autocross Review Video Part 3 | Dezoris | Forced Induction | 19 | 07-24-2013 04:18 PM |
My track day video at Willow Springs 1-19-13 vs S2000/FR-S/RX8 | Mark Slide Squad | Tracking / Autocross / HPDE / Drifting | 18 | 02-04-2013 07:26 PM |
Track Video: BRZ Passes worked Miata, unable to be passed by prepped s2000 | gmookher | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-06-2012 01:01 PM |
