Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
10-10-2019, 01:09 PM | #1 |
Emperor McDuck
Drives: 2019 86 GT; 2018 BMW S1000RR
Unusual Tire Wear - Test
Just got my 86 serviced and the dealer noted with confusion that my front tires were significantly more worn than my rear. They had not been rotated. Who knows why?
10-10-2019, 01:16 PM | #2 |
Rust bucket enthusiast
Rear tires get changed much more frequently than the fronts ,and you have scrubbing from toe out for turn on response?
This is my final answer. Definitely am expecting increased wear from autocross usage - I know my fronts get hammered quick compared to the rears Last edited by DarkPira7e; 10-10-2019 at 01:26 PM. |
10-10-2019, 01:21 PM | #3 |
Country Boy 4 Life
Your alignment is off?
I LIKE TIRES! |
10-10-2019, 01:24 PM | #4 |
Drives: '23 BRZ
I suspect track or autoX use + possibly sub-optimal setup.
My car wears fronts WAY more quickly than rears at the track. But my setup is not optimal... Bottoming on cut-down front bump stops results in heavily loading the outside front in corners. Lost a ton of front bump travel due to camber plates and -1.25" ride height with springs... Last edited by ZDan; 10-10-2019 at 01:41 PM. |
10-10-2019, 03:07 PM | #5 |
Drives: 86, 981S, RX8, 2500HD, GenesisV8
10-10-2019, 03:21 PM | #6 |
Drives: '23 BRZ
10-10-2019, 03:21 PM | #7 |
Drives: '13 FRS - STX
I too fail to achieve 'slow in, fast out' far too often.
10-10-2019, 03:29 PM | #8 | |
Emperor McDuck
Correct! No power and understeer (no front camber adjustment), the fronts get lots of abuse and the rears get very little. I found it kind of funny that the service techs didn't recognize why.. I mean my RE-71rs look like I put a blow torch to them they are so melted... Can't imagine I am the only 86 that comes in this way.
10-10-2019, 03:42 PM | #9 | |
Country Boy 4 Life
I LIKE TIRES! |
10-10-2019, 03:46 PM | #10 | |
Emperor McDuck
I have a set of camber bolts in the glove box.... Doesn't seem to help
10-10-2019, 04:00 PM | #11 | |
Country Boy 4 Life
How much camber do you get from them in that location?
I LIKE TIRES! |
10-10-2019, 04:09 PM | #12 | |
I'm still wearing the fronts faster with -4° but that's a nut behind the wheel problem... well at least my setup changes haven't moved the needle a bunch yet. |
10-10-2019, 05:32 PM | #13 |
Drives: '23 BRZ
Not to mention 55/45 weight distribution! Doesn't seem that terrible until you realize that the fronts carry ~20% more weight than the rears do There should be a cab-rearward 2-seat version of this car, with rear wheels shoved about 10"-12" forward for 50/50 distribution!
10-10-2019, 07:49 PM | #14 | |
Emperor McDuck
Have noticed a strange rattling noise coming from the glove box though ever since I put them in. Super easy install though.
The Following User Says Thank You to xdavidx For This Useful Post: | Leonardo (10-10-2019) |
Similar Threads | ||||
How does my tire wear look? | R_E_L | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-08-2018 07:34 AM |
tire wear | oppiee | Tracking / Autocross / HPDE / Drifting | 9 | 08-29-2017 12:55 PM |
Tire Wear? | Flo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-10-2017 03:19 PM |
Tire Wear Help | babykwiss | Tracking / Autocross / HPDE / Drifting | 10 | 07-14-2014 11:31 AM |
Unusual tyre wear? (pics included) | jourdanc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 05-09-2014 06:34 AM |
