Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-10-2012, 08:22 PM | #1 |
Drives: BRZ/E30/IS300/LS400
Stance Super Sport coilover install/review
I've only had my car 2 weeks, but as far as I'm concerned that's two weeks too long to be riding around on stock suspension... It's not that the car didn't ride fantastic from the factory, because it did, but I can't stand the look of wheelgap.
A few days after I picked my BRZ up I started researching coilovers. I've owned lots of different coilovers in the past, Ground control, Tein, and H&R. And I've driven/rode in lots of friend's cars with Megan, KW, Bilstein, Moton, Fortune, etc. As of lately though, my last few cars I've run Stance GR+ or Stance Super Sports on, and loved them, as seen here: Prior to using Stance coilovers on these cars, I was a huge supporter of Tein Monoflex coilovers because they rode great, and handled even better. The downside was that they didn't ever go as low as I wanted without getting rid of some of the preload on the springs, which in turn ruined the ride and the handling that I loved them for... This was one of the biggest things that got me interested in Stance coilovers, everyone that I knew who had used them said they went LOW and retained a good ride... And it turned out they did. It also didn't hurt that Stance is a company that is local to me, which meant that their already great customer service would be even better since I could deal with them face to face. So when the time came to pull the trigger on coilovers for this car, the Stance Super Sports were at the top of my list. I would have loved some KW v3's, but the cost was out of my budget, and the car is just my daily driver/occasional drift car, so I wanted something that would improve handling, let me slam the car, and keep the ride as close to stock as possible. There were other options that were cheaper, and other options that may have looked as good on paper for the same money, but past experiece, and my trust for Stance to both make and stand behind a quality product meant that they were getting return business from me... It also doesn't hurt that they had them in stock, and I went to pick them up in person instead of having to deal with some shady 3rd party business and wait for shipping. As for the coilovers themselves, their rates are 6K front and 6K rear, 15-way dampening adjustable, inverted monotube, adjustable camber plates, and they come with adjustable swaybar endlinks to avoid binding once the car is lowered. So, on with the install: BRZ Stance Coilover Install by AJ Gillett, on Flickr The stock rear suspension was a piece of cake to remove on this car for anyone that's done coilovers before. One bolt on the bottom, two up top, and once everything is unbolted you either have to unbolt the control arm or have someone of a decent weight stand on the hub to get the stock suspension free. There is one piece of very important information that I wish I had known ahead of time though. On the drivers side of the trunk there's a trunk pop button on the liner that needs to be unplugged in order to peel the liner away enough to get to the suspension bolts. If you unplug this, DO NOT CLOSE YOUR TRUNK. I lucked out that I had the taillights out of the car to paint them, because I closed the trunk, and could not get it to open until I reached in the tail light hole and pulled the emergency release. Stock parts coming out: BRZ Stance Coilover Install by AJ Gillett, on Flickr BRZ Stance Coilover Install by AJ Gillett, on Flickr The two side by side: BRZ Stance Coilover Install by AJ Gillett, on Flickr That's with the coilover at max low by adjusting the lower mount, but with a good amount of preload on the spring. I could probably reduce the preload a bit without drooping the springs and get the car to sit lower still. And the coilovers are in just as easy as they came out, just slip them in, tighten three bolts, and you're done: BRZ Stance Coilover Install by AJ Gillett, on Flickr BRZ Stance Coilover Install by AJ Gillett, on Flickr The front was a little bit trickier, but still a very straightforward removal/install. Three nuts on the strut towers, two attaching the coilover to the knuckle, a swaybar endlink, and a series of bolts and clips attaching brake lines and wiring to the coilover. I was warned by the guys at Stance that the clips would be somewhat annoying to remove in one piece, but even that didn't prove to be too much hassle. BRZ Stance Coilover Install by AJ Gillett, on Flickr BRZ Stance Coilover Install by AJ Gillett, on Flickr Here are the front coilovers with the adjustable swaybar endlinks. I opted to not put these all the way down since I wanted to avoid rubbing with the tire size I currently have. BRZ Stance Coilover Install by AJ Gillett, on Flickr Installing the fronts went as seemlessly as the factory stuff came out. At this height it was a two man job to get the knuckle to line up with the coilovers. All of the holes for the bolts and clips lined up perfectly, and popped right in. The swaybar endlinks left me scratching my head for a minute. They were both set to the same length, but once the endlink was installed on one side, the other wouldn't line up. We realized that there was load on the sway bar, and we had to jack up the opposite side up to get the holes to line up... And just like that, the job was done. I was really impressed with the ease that everything fit back together in front even with the coilovers this low. I figured at a certain height things may start to not line up so good, but I guess they planned for people like me. BRZ Stance Coilover Install by AJ Gillett, on Flickr BRZ Stance Coilover Install by AJ Gillett, on Flickr BRZ Stance Coilover Install by AJ Gillett, on Flickr BRZ Stance Coilover Install by AJ Gillett, on Flickr Complete! BRZ Stance Coilover Install by AJ Gillett, on Flickr Having been driving on these for the last couple days, I couldn't be happier. More than anything I'm blown away by the ride, especially at this height. It rides about as good as stock over normal bumps and such, over really big bumps you can feel that it's more firm, but it is by no means going to shatter your hip like some coilovers I've driven on. Handling feels great from what I've felt so far, but I also have a wheel/tire change to take into account, so I can't be sure how much the coilovers are doing, and how much the bigger tires are doing. Regardless, the car feels much more flat around turns, and much more planted with quick direction changes. It seems very ideal for someone like me that just wants to street drive with occasional track days... They may not be the ultimate performer, but not everyone wants that. What's important is that no one attribute of the car's suspension has been comprimized in order to make another better. They feel awesome, they seem to handle great, and they go nice and low.
RISKY DEVIL // ILL PHOTOGRAHY
The Following 23 Users Say Thank You to ill roller For This Useful Post: | Ammunition (12-21-2015), Baldoak (05-12-2015), buzznasa (07-22-2013), camelflage (12-12-2012), clickfiveZ (12-19-2012), Evilbrz151 (12-19-2012), giraffee (01-16-2013), Guff (12-11-2012), hippari (12-20-2012), ijuliusx (10-15-2013), JPxM0Dz (12-14-2012), larryw (12-13-2012), lucchesi423 (08-16-2013), Mark Slide Squad (12-19-2012), melon (08-31-2013), NJA (12-13-2012), Rayme (12-13-2012), RRnold (12-13-2012), TouchMyHonda (12-12-2012), Touge Factory (12-11-2012), vividracing (10-08-2014), whataboutbob (01-01-2013), wlwarfield (11-18-2013) |
12-10-2012, 08:23 PM | #2 |
Looking great. We got these in as well and really like the quality and ride.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | Touge Factory (12-11-2012) |
12-10-2012, 11:04 PM | #3 |
Drives: fr-s
how low can you go?
12-11-2012, 12:09 AM | #4 |
86-er
Drives: BRZ tS
Wow man looks great.
Wheel and Tire specs? How much did you get the Coilovers for? you can PM me
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
12-11-2012, 12:26 PM | #5 | ||
Not low enough just yet, but we'll see! Quote:
Coilovers MSRP is $1435... Hit up FT-86 Speedfactory, I believe they're offering them at a discounted price.
The Following User Says Thank You to ill roller For This Useful Post: | FT-86 SpeedFactory (12-11-2012) |
12-11-2012, 03:20 PM | #6 |
Drives: BMW M3
Great review and as always, nice photos!
I had the Stance GR+/Super Sports on my E46 M3 and former G35. The guys at Stance USA are always a pleasure to work with. |
12-13-2012, 02:50 PM | #7 |
Did you set the endlink length to the OEM length?
If not, how did you decide what length to adjust them too? |
12-13-2012, 03:15 PM | #8 |
2 wheel member
Drives: JZA80, 997.1, Taco
Excellent writeup! I'm sure the member who posted a poll for a DD looking for coilvers could benefit from your post.
12-13-2012, 05:11 PM | #9 |
No, I put the coilover and adjusted the endlink so that it was a couple mm short of fitting, then lifted the hub and slipped it in... Gotta keep a little tension on them.
The Following User Says Thank You to ill roller For This Useful Post: | NemeGuero (12-13-2012) |
12-13-2012, 08:29 PM | #10 |
Drives: Supercharged Saturn ION
very informative post and nice pics
12-16-2012, 01:03 PM | #13 |
The Answer
Drives: Mazda 2
Wow. Interesting price for sure...I might have to put those on my first mods list.
12-17-2012, 04:41 PM | #14 |
Drives: frs or brz
Stance coilovers are the best bang for buck coilover on the market currently
Similar Threads | ||||
D2 RS/K-Sport Kontrol Pro Coilover Review | DarrenDriven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 62 | 04-08-2016 01:32 PM |
Stance Super Sport Coilovers | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-28-2015 08:59 PM |
►►Stance Super Sport Coilovers◄◄ Free Shipping - Photos and Video | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 43 | 01-31-2013 09:17 PM |
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers | Diego@lutzperformance | Brakes, Suspension, Chassis | 1 | 10-04-2012 01:43 PM |
