Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-23-2014, 09:36 PM | #15 |
Your diff is on it's way
The Following User Says Thank You to CSG Mike For This Useful Post: | dp1 (05-23-2014) |
12-18-2016, 05:56 PM | #16 | |
Drives: Blue BRZ
Looks like i have the same problem. I have dss axles and kaaz 1.5way diff.
12-19-2016, 10:34 AM | #17 | |
In a FWD gearbox, I can totally see that. Probably a copy/paste error more than hard requirement.
12-21-2016, 04:37 PM | #18 | |
Suspension Nerd
Drives: 2019 Mazda MX-5
For instance, the ND manual gearbox differential is significantly sized differently than the automatic. Its safer to clarify what the unit was designed around than for a customer to find out the hard way. |
12-21-2016, 05:31 PM | #19 | |
Drives: Subaru BRZ Limited
02-06-2018, 06:34 PM | #20 |
Wise old man
Drives: 86 GTS
Did you ever determine the cause if the circlip failure?
02-08-2018, 08:37 PM | #21 |
Wise old man
Drives: 86 GTS
I am having the same issue, but what is causing the axle to move in and out anyway? my circlips arent broken. i have tried 3.
for me its the right axle only. i replaced the diff with a new one and its still happening. the axle goes in just fine and clips in, but after a short drive it has popped loose again. DSS 600HP axles. |
02-20-2018, 07:56 PM | #22 |
Wise old man
Drives: 86 GTS
an update for this.
i emailed photos of my axle to driveshaft shop and they agreed that they will replace the inner shaft that goes into the diff for me. i tried a new DSS 600Hp axle and now the car is perfect |
03-19-2019, 02:49 AM | #23 |
Drives: 2013 Black FR-S
If you don't mind... what was the issue with the inner shaft? I have been plagued with this same issue of axle leaking/popping out for 2 years now.
03-19-2019, 04:03 AM | #24 | |
Drives: Blue BRZ
I just went back to oem. Sent from my iPhone using Tapatalk
04-16-2019, 01:16 AM | #25 |
Wise old man
Drives: 86 GTS
i dont know what was the issue, and i actually just deleted the photos last night. but they sent me a new one for free. i got it put in, and all was right with the world.
09-28-2019, 11:03 PM | #26 |
Drives: Asphalt 2013 FR-S
Diff was leaking fluid from both axles. There was some play in both axles where I could slide them in and out. I took out the diff and it looks like maybe the clips for both axles are broken? I'm not sure, but the clips have a pretty good gap. Does this look broken to anyone?
https://photos.app.goo.gl/WL2C7e1BoEMFs4r19 I'm having trouble embedding an image from my phone. If the link doesn't work work I'll try something else.
Similar Threads | ||||
OSGiken vs. KAAZ Super Q LSD | FutureFT86 | Engine, Exhaust, Transmission | 11 | 03-29-2017 05:36 AM |
FS: 2013 BRZ Limited | Random interior bits from track build | DatApex | Interior Parts (Incl. Lighting) | 28 | 09-08-2014 02:49 PM |
JRZ, Cusco, Tomei, Moonface, HKS, Volks, and OSgiken, UPDATE 2/23/14 | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 32 | 03-31-2014 11:47 PM |
When to replace street tires used for the track? | ayau | Tracking / Autocross / HPDE / Drifting | 4 | 07-23-2013 11:45 AM |
Scion's Explanation of BRZ FR-S Limited Slip Differential | stalon320 | Engine, Exhaust, Transmission | 5 | 06-22-2012 11:26 AM |
