Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 10-06-2019, 03:51 PM   #631
Suparu
Drives: 2013 BRZ Ltd Turbo
This is a great post, the interior’s metal ticking noises have been driving me nuts. I did what OP showed to do and it helped but it wasn’t the main ticking sound I was chasing. I’ve read every related post that I could find on here and here’s my story:
* I used a flathead screwdriver to pry the areas shown in the trunk/boot (source #1 in the TSB) as OP showed. Then used white lithium grease in those areas. I did this to every metal seam in the upper part of trunk. It helped but apparently wasn’t the main ticking sound I was hearing.
* I removed the rear deck shelf with the help of this video: https://youtu.be/oNh-oLAKa6I
* Starting with source #2 in the TSB and OP’s post, I would wedge a flathead screwdriver into the opening then I slowly pulled up on the screwdriver until the cracking sound stopped happening. I didn’t put all my muscle into it, don’t want to break the weld, just enough to make the metal stop creaking/cracking for side of each opening.
* Then I’d spray a plentiful amount of white lithium grease into each opening.
* I did this for every metal seam opening that I could fit my flathead screwdriver into, not just source #2 in the TSB.
The rear deck shelf had more problematic areas and louder metal-ticking noises than the trunk/boot had and my car is quieter than ever now. So quiet that I’m hearing additional little annoying sounds that I never noticed before cuz they are much quieter than the rear deck shelf area/trunk noises were.
The wireless receiver on the rear deck shelf seems snug and quiet in my case. The current sound I’m chasing sounds like it’s coming from somewhere back there, up by the roof liner. Maybe behind the B pillar, I need to take a look there next.
All this time I thought it was one noise coming from one problem area but it turns out it’s actually many noises happening at the same time (from bumps/vibrations/etc) giving me the false impression that it was just one annoying noise.
The problems seem to vary for different people but start with the easy to reach spots like source #1 in the TSB and bending that wireless receiver’s metal clip down to tighten it. If that doesn’t do it then do what I did and also check that wireless receiver that’s on the rear deck shelf’s metal which was fine in my case but is a noise source due to it being loose for other people.
Suparu is offline   Reply With Quote
The Following User Says Thank You to Suparu For This Useful Post:
bcj (10-07-2019)
Old 10-13-2019, 02:57 PM   #632
Suparu
So that last metal ticking sound that I thought was coming from the B pillar actually was the wireless receiver that’s on top of the rear deck shelf even though it seemed snug and quiet. I unbolted it with a 10mm socket wrench and put 2 pieces of foam weatherstripping under it. One piece with a hole in it that went under the metal plate, the hole was for that 10mm bolt to go through. The other piece went under the actual black wireless receiver box itself although this might be unneeded, overkill. A piece of rubber or anything to cushion it or dampen it would work fine, I just used weatherstripping cuz I had some on hand.
Now there’s no more unwanted sound at all, finally! I suspect the noise from the wireless receiver is just the metal plate that the 10mm bolt goes through but best to do the whole wireless receiver area to be sure :/
Old 10-14-2019, 04:30 AM   #633
LancePower
Drives: 2016 FR-S Rs2.0
Originally Posted by Suparu View Post
So that last metal ticking sound that I thought was coming from the B pillar actually was the wireless receiver thatís on top of the rear deck shelf even though it seemed snug and quiet. I unbolted it with a 10mm socket wrench and put 2 pieces of foam weatherstripping under it. One piece with a hole in it that went under the metal plate, the hole was for that 10mm bolt to go through. The other piece went under the actual black wireless receiver box itself although this might be unneeded, overkill. A piece of rubber or anything to cushion it or dampen it would work fine, I just used weatherstripping cuz I had some on hand.
Now thereís no more unwanted sound at all, finally! I suspect the noise from the wireless receiver is just the metal plate that the 10mm bolt goes through but best to do the whole wireless receiver area to be sure :/
Do you have any pictures of the area in question?
LancePower is offline   Reply With Quote
Old 11-01-2019, 01:27 PM   #634
Suparu
Iíve put everything back together now so I donít have a pic but hereís a thread with a pic with it. I call it a wireless receiver but in this post they call it a wireless transmitter, at any rate itís the black box with a 10mm bolt holding it in place:
http://www.ft86club.com/forums/showthread.php?p=358267
Old 11-01-2019, 06:37 PM   #635
LancePower
Thank you, good sir.
Old 11-15-2019, 09:13 PM   #636
Suparu
You’re welcome. I took the rear deck shelf cover back off and snapped some pics while I was at it. You’re probably already good from the last post’s link but here’s mine, it’s in the 3rd picture. If you zoom in you can see the squished up foam weatherstripping I put under it. You’ll see some foam sticking out of the left of that black box too, I cushioned the whole area. It was a bit of a pain getting the black box and it’s bolt back into place cuz it was snug. But once it was bolted back in, there was no problem getting the rear deck shelf’s carpeted cover back on.
That black box + it’s metal clip + bolt were the major source for me... then to a lesser extent the weld spots throughout the entire rear deck shelf area were partially responsible. Even the white plastic clips that are seated in the metal, directly behind the rear seat (they can be seen in the 2nd pic and one of them can be seen in the 3rd pic, bottom center of the pic) they were a problem too lol.
The car got quieter with each issue I addressed, allowing me to hear quieter noises I couldn’t hear before cuz they were quieter in comparison. It was a wild goose chase for a few weeks. Which is why I ended up Dynamat’ing it to absorb resonance from the metal, that was probably overkill though.
https://www.ft86club.com/forums/show...9&postcount=27
Odometer Functions - "S" & "G" What are they? kablammo Subaru BRZ General Forum 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku Subaru BRZ General Forum 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
