Old 01-03-2013, 09:43 AM   #57
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by ayau View Post
Yeah. Now we just need to figure out how to easily adjust the rear camber without having to install those Whiteline bushings or a rear lower control arm.
Getting camber in the rear doesn't seem to be a problem as lowering the car will gain you a lot of negative camber in the rear; it's fine tuning/balancing both sides that seems to be the issue.
What's wrong with the control arm?
JoeBoxer is offline   Reply With Quote
Old 01-03-2013, 10:43 AM   #58
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Nothing is "wrong" with it really, except the track changes (albeit slight). I'd prefer an upper adjustment instead.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-03-2013, 02:31 PM   #59
wparsons
wparsons's Avatar
I would also prefer an adjustable upper arm instead of a lower arm. I'm a bit surprised there isn't one out yet.
flickr
Old 01-04-2013, 08:48 AM   #60
mla163
Overthinking it
Drives: BRZ in CS
The twist is that I'll be getting sticky tires soon, so I wasn't sure if I would need a second alignment shortly after getting my first alignment. However, it appears that new tires won't affect alignment specs.
Changing wheels (or swaybars for that matter) does not affect the alignment.
Changing crash bolts, struts and or springs will require an alignment since you are undoing alignment bolts.
mla163 is offline   Reply With Quote
Old 08-31-2013, 12:13 AM   #61
Wepeel
Drives: '13 BRZ Ltd
I just installed the OEM crash bolts. Prior to doing so, I checked alignment, and then checked alignment after installation (using the string method). The front toe may have barely changed, if at all - it was easily within range of measurement uncertainty using a mm tape measure.
I measured the factory alignment to be toe-in on all 4 corners. Actually, it was very similar to Dezoris first alignment in his Alignment FAQ, with the driver rear showing about 2x more toe in than the rest. Both fronts and passenger rear were ~0.12deg toe in, driver rear was a little less than 0.24 deg toe in.
Wepeel is offline   Reply With Quote
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
Coil Install + alignment in Bay Area? BlaineWasHere Southern California 21 08-27-2012 12:10 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
